v 2.2.1 won't run on windows 10
mattg
Post Sat Dec 18, 2021 9:41 pm
I just installed v 2.2.1 and Console won't run (Cannot connect to the server, it doesn't seem to be running...). No problems with prior version 2.2.0 running and I haven't changed anything in windows. Any ideas what happened? Thanks.
Post Sun Dec 19, 2021 12:43 am
Re: v 2.2.1 won't run on windows 10
I have 2.2.1 on both of my servers. I generally just use the web interface for the console, but I just tried the included console on one of my installs and it worked fine. Does the web console work? Does the Serviio log show any issues? If you open the Windows services applet, does it show the service running?
mattg
Post Thu Dec 23, 2021 2:23 am
I don't know where the log file is stored. My network is still set to private and there were several windows updates earlier in December. Reinstalled v 2.2.0 which is running ok.
Post Thu Dec 23, 2021 6:25 pm
Log file is located in C:\Progam Files\Serviio\Log. There's two files, serviio.log and derby.log. We only need to see the Serviio log.
Did you try opening the console via the web interface, instead of the console app? On the Serviio computer, open http://localhost:23423/console. On any other computer on the network, change localhost to either the Serviio computer name or its IP address.
One thing I've noticed is that older versions of Serviio had a different menu item for opening the console, as if there was a change in the method of opening the console. So under the Start menu Serviio has more than one shortcut to open the console. I'm wondering if your computer has both the old and new menu item and you're trying the older one.
Users browsing this forum: Google [Bot] and 155 guests
