Java error Windows Server 2008
thingy
Post Wed Dec 22, 2021 1:21 pm
When installing the last version (2.2.1) on Windows 2008 I get the following error when trying to start it.
As a service:
2021-12-22T13:57:38,699 INFO [MediaServer] ------------------------------------------------------------------------
2021-12-22T13:57:38,699 INFO [MediaServer] Serviio DLNA media streaming server v 2.2.1 (rev. 7dfe9e60ec4aa7e219630fa16aecf232e8b7bef0)
2021-12-22T13:57:38,699 INFO [MediaServer] Petr Nejedly 2009-2018
2021-12-22T13:57:38,699 INFO [MediaServer] http://www.serviio.org
2021-12-22T13:57:38,699 INFO [MediaServer] Java 1.8.0_242-BellSoft x86
2021-12-22T13:57:38,699 INFO [MediaServer] OS Windows Server 2008 6.0
2021-12-22T13:57:38,699 INFO [MediaServer] File encoding: windows-1252
2021-12-22T13:57:38,699 INFO [MediaServer] Headless mode enabled: true
2021-12-22T13:57:38,699 INFO [MediaServer] User: SERVER$
2021-12-22T13:57:38,699 INFO [MediaServer] User home dir: C:\Windows\system32\config\systemprofile
2021-12-22T13:57:38,699 INFO [MediaServer] Temp dir: C:\Windows\TEMP\
2021-12-22T13:57:38,699 ERROR [MediaServer] An unexpected error occurred. Ending the application. Message: Could not initialize class sun.management.ManagementFactoryHelper
java.lang.NoClassDefFoundError: Could not initialize class sun.management.ManagementFactoryHelper
at java.lang.management.ManagementFactory.getRuntimeMXBean(ManagementFactory.java:350) ~[?:1.8.0_242]
at org.serviio.MediaServer.runtimeParameters(MediaServer.java:297) ~[serviio.jar:?]
at org.serviio.MediaServer.printInformation(MediaServer.java:280) ~[serviio.jar:?]
at org.serviio.MediaServer.main(MediaServer.java:123) [serviio.jar:?]
at sun.reflect.NativeMethodAccessorImpl.invoke0(Native Method) ~[?:1.8.0_242]
at sun.reflect.NativeMethodAccessorImpl.invoke(NativeMethodAccessorImpl.java:62) ~[?:1.8.0_242]
at sun.reflect.DelegatingMethodAccessorImpl.invoke(DelegatingMethodAccessorImpl.java:43) ~[?:1.8.0_242]
at java.lang.reflect.Method.invoke(Method.java:498) ~[?:1.8.0_242]
at com.exe4j.runtime.LauncherEngine.launch(LauncherEngine.java:62) [exe4jlib.jar:?]
at com.exe4j.runtime.WinLauncher$2.run(WinLauncher.java:96) [exe4jlib.jar:?]
And the bat file under Serviio\bin
2021-12-22T13:57:24,111 INFO [MediaServer] ------------------------------------------------------------------------
2021-12-22T13:57:24,111 INFO [MediaServer] Serviio DLNA media streaming server v 2.2.1 (rev. 7dfe9e60ec4aa7e219630fa16aecf232e8b7bef0)
2021-12-22T13:57:24,111 INFO [MediaServer] Petr Nejedly 2009-2018
2021-12-22T13:57:24,111 INFO [MediaServer] http://www.serviio.org
2021-12-22T13:57:24,111 INFO [MediaServer] Java 1.8.0_311-Oracle Corporation x86
2021-12-22T13:57:24,111 INFO [MediaServer] OS Windows Server 2008 6.0
2021-12-22T13:57:24,111 INFO [MediaServer] File encoding: windows-1252
2021-12-22T13:57:24,111 INFO [MediaServer] Headless mode enabled: true
2021-12-22T13:57:24,111 INFO [MediaServer] User: administrator
2021-12-22T13:57:24,111 INFO [MediaServer] User home dir: C:\Users\Administrator
2021-12-22T13:57:24,111 INFO [MediaServer] Temp dir: C:\Users\ADMINI~1\AppData\Local\Temp\2\
2021-12-22T13:57:24,111 ERROR [MediaServer] An unexpected error occurred. Ending the application. Message: Could not initialize class sun.management.ManagementFactoryHelper
at java.lang.management.ManagementFactory.getRuntimeMXBean(Unknown Source) ~[?:1.8.0_311]
I tried to install Oracle jre 1.8.0.311, thinking it could be some issue with the included java package, but I still got the same errors when starting Serviio.
On version 2.1 I get this error:
2021-12-22 14:11:35,880 ERROR [MediaServer] An unexpected error occurred. Ending the application. Message: C:\Program Files\Share\Serviio\jre\bin\management.dll: The specified procedure could not be found
java.lang.UnsatisfiedLinkError: C:\Program Files\Share\Serviio\jre\bin\management.dll: The specified procedure could not be found
*The last working version is 2.0, the small blessings that reverting a failed upgrade works.
Post Wed Dec 22, 2021 5:40 pm
Re: Java error Windows Server 2008
Windows Server is not a supported operating system for Serviio. Yes, it will sometimes work, but there are things in the server version of the OS that cause problems for Serviio.
thingy
Post Fri Dec 24, 2021 7:08 am
That's too bad, considering it's exactly what a server is supposed to do.
Well, it's been a good run I guess, every version up to and including 2.0 worked fine. But as the developer it is your discretion to decide what's supported or not.
Post Fri Dec 24, 2021 4:51 pm
I'm not the developer, just another user like yourself. :D
Users browsing this forum: No registered users and 126 guests
