YouTube
it.x
Post Thu Aug 05, 2021 3:36 pm
Re: YouTube
fast and nice way to bring the Serviio YouTube plugin back to life, is to replace the lines <106..132> (YouTube.groovy rel.09.02.2020/14005B) with this code:
// body of youtube.groovy rel.09.02.2020 (14005B)
// lines <0..105>
      for (elType in ['&el=embedded', '&el=detailpage', '&el=vevo', '']) {
            // ver.1 blocked by Google  ca. 01.05.2021 def videoInfoUrl = "https://www.youtube.com/get_video_info?&video_id=$videoId$elType&ps=default&eurl=&gl=US&hl=en"
            // ver.2 blocked by Google  19.06.2021 def videoInfoUrl = "https://www.youtube.com/get_video_info?html5=1&video_id=$videoId$elType&ps=default&eurl=&gl=US&hl=en"
            // ver.3 blocked by Google  30.07.2021 def videoInfoUrl = "https://www.youtube.com/get_video_info?video_id=$videoId&eurl=https%3A%2F%2Fyoutube.googleapis.com%2Fv%2F$videoId&html5=1&c=TVHTML5&cver=6.20180913$elType&ps=default&eurl=&gl=US&hl=en"
            def videoInfoUrl = "https://youtubei.googleapis.com/youtubei/v1/player?key=AIzaSyAO_FJ2SlqU8Q4STEHLGCilw_Y9_11qcW8"
            def TmpPost = new URL("https://youtubei.googleapis.com/youtubei/v1/player?key=AIzaSyAO_FJ2SlqU8Q4STEHLGCilw_Y9_11qcW8").openConnection();
            def TmpBody ='{"context": {"client": {"hl": "en",  "clientName": "WEB", "clientVersion": "2.20210721.00.00",  "mainAppWebInfo": {"graftUrl":  "/watch?v='+"$videoId"+'"}}},  "videoId":  "'+"$videoId"+'"}'
            TmpPost.setRequestMethod("POST")
            TmpPost.setDoOutput(true)
            TmpPost.setRequestProperty("Content-Type", "application/json")
            TmpPost.getOutputStream().write(TmpBody.getBytes("UTF-8"))
            //org def videoInfoWebPage = new URL(videoInfoUrl).getText()
            def videoInfoWebPage = TmpPost.getInputStream().getText()
            //org def parameters = [:]
            //org videoInfoWebPage.split('&').each { item -> addParameter(item, parameters, '=') }
            def jsonSlurper2 = new JsonSlurper()
            def parameters = jsonSlurper2.parseText(videoInfoWebPage)
            // org def playerResponse = parameters['player_response']
            def playerResponse = parameters['responseContext']
            if(playerResponse) {
                //org def pr = new JsonSlurper().parseText(URLDecoder.decode(playerResponse, 'UTF-8'))
                //org def streamingData = pr['streamingData']
                def streamingData =  parameters['streamingData']
                if(!streamingData) {
                    continue
// lines <133..322>
Changes:
- 13.10.2026/ YT video info/ POST body/ "clientName": "WEB" -> "ANDROID"
- 13.10.2026/ YT video info/ POST body/ "clientVersion": "2.20210721.00.00" -> "21.02.35"
Fyi:
- cause of a problem: YouTube API v3 "/get_video_info" issue (looks like step blocking by Google in 2021)
- solution: change groovy URL.GetText() method to REST POST request to symulate native YouTube player and then test new JSON response
- JSON response: property "player_response" has been changed to "responseContext"
- fully modified and functional version of plugin attached
- please remember to manage your own API key ( line 53/55 acc. to file version)
- 17.06.2022: reformatting comments and testing original Serviio API key (at this time works fine)
- 13.10.2026: plugin is working at this time - new changes by Google and direct links are again available and accessible :)
Always check other variants:
viewtopic.php?f=20&t=3276&hilit=you+tube&start=580#p137216
viewtopic.php?f=20&t=3276&hilit=you+tube&start=580#p137448
Thanks to:
- https://stackoverflow.com/questions/676 ... -not-found
- https://stackoverflow.com/questions/256 ... ttp-client
Enjoj :) and You're welcome with requests, questions or suggestions: http://itx0.cba.pl?s=Serviio
Regards and good luck to Serviio Team :)
Youtube.groovy
(15.3 KiB) Downloaded 1 time
bmn
Post Thu Sep 02, 2021 3:25 pm
Re: YouTube
it.x wrote:Hello,
Doesnt work (anymore?).
[WebResourceParser] Plugin YouTube returned no value for resource item 'null'
EDIT : btw, returns HTTP ERROR 410
it.x
Post Thu Sep 02, 2021 7:30 pm
Re: YouTube
It works fine and stable for many weeks.
I non stop use searches and channels like this:
SEARCHES:
 https://www.googleapis.com/youtube/v3/search?q=YOUR_STRING_TO_FIND&order=date
CHANNELS:
https://www.googleapis.com/youtube/v3/channels?forUsername=YOUR_STRING_TO_FIND
Maybe you have a problem with the right Google API key: line 53.
Good luck.
bmn
Post Fri Sep 03, 2021 2:34 pm
Re: YouTube
it.x wrote:I
The key is in line 55 and Im using mine. Still got [WebResourceParser] Plugin YouTube returned no value for resource item 'null'
it.x
Post Fri Sep 03, 2021 5:18 pm
Re: YouTube
My job ended when plugin start working again.
There are many possible causes for your problem: maybe you need search this forum or ask Serviio support for help, but you definitely need to be brave and smart against quotas, firewalls, antivir, etc... :)
Alex532
Post Sat Jan 08, 2022 8:55 pm
Re: YouTube
Greetings to the developer and all users, the plugin is working at the moment, if so then you can have detailed instructions on how to install it from 0, I am using this technology for the first time.
Post Sun Jan 09, 2022 1:03 am
Re: YouTube
The instructions for using this plugin should be back in the original post. You have to copy the plugin file into the plugins folder where Serviio is installed on your computer. On Windows, that's C:\Program Files\Serviio\plugins
Alex532
Post Sun Jan 09, 2022 7:07 am
Re: YouTube
Thank you for the quick answer, yes I did it, but what to do next, how to open a video from YouTube on my TV?)) :?
SlavaUkraini
Post Thu Apr 07, 2022 4:06 pm
Re: YouTube
Unfortunately the offered plugin has errors, about 9 lines of the previous version were missing, the attribute "streamingFormats" was no longer defined. :roll:
I guess that an own Google API key is still required and has to be set in line 57 of my version.
Youtube.groovy
Youtube plugin for Serviio
(16.13 KiB) Downloaded 10499 times
it.x
Post Thu Jun 02, 2022 11:03 pm
Re: YouTube
It works fine and stable - I use it often and conveniently with DLNA vs TV Sony Bravia sets or Sony Blu-ray/DVD/network/multimedia/... , several models of Android TV box and few other native DLNA players like Android/iOS apps etc.
I see that you are using the wrong version of groovy file to modify.
Maybe I will help by repeating - two ways:
1. (education:) get the original, last working file, from Serviio Admins post:
https://forum.serviio.org/viewtopic.php?f=20&t=3276&hilit=you+tube#p21613
(Youtube.groovy rel.09.02.2020/14005B)
than make the modifications I am writing about:
https://forum.serviio.org/viewtopic.php?f=20&t=3276&hilit=you+tube&start=580#p133877
that is replace lines <106..132> with new code and manage your own API key at line 53.
2. (fast) get the file already modified by me:
(Youtube.groovy rel.30.07.2021/15673B)
and manage only your own API key at line 55.
good luck
it.x
it.x
Post Wed Jun 26, 2024 11:43 pm
Re: YouTube
*** WARNING ***
- ca. 20.06.2024: plugin is not working at this time. New changes by Google and direct links are still available but not accessible (ffmpeg: HTTP error 403 forbidden). The new working version is here:
viewtopic.php?f=20&t=3276&p=137216#p137216
*** WARNING ***
junior
Post Sat Aug 24, 2024 9:46 am
Re: YouTube
Any update on this?
it.x
Post Fri Feb 07, 2025 11:59 pm
Re: YouTube
next working bypass here: we use YTDLP.ONLINE sevice to solve YouTube signatures.
Changes:
- new lines <116..142>: handling HTTP GET request to ytdlp.online
- new line 5: import java.util.regex.Matcher
- new line 6: import java.util.regex.Pattern
- changed variable name: TmpPost ->TmpHttpPost
- changed variable name: TmpBody ->TmpHttpBody
- new line 204: clever :) link swap
- removed unnecessary, old comments between lines <116..205>
- 11.02.2026/ YT video info/ POST body/ "clientName": "WEB" -> "ANDROID"
- 11.02.2026/ YT video info/ POST body/ "clientVersion": "2.20210721.00.00" -> "21.02.35"
- 11.02.2026/ YTDLP.online/ GET request: reorganize params
Comments:
- effectiveness depends on the response from ytdlp.online: If something doesn't work, always check status of YTDLP.ONLINE service first.
- YT itag 18 is forced: video and audio together
- tested on: v.2.1 (nas/linux); v.2.3 (win64); v.2.4 (win64)
- 13.10.2026: plugin is not working at the moment - YTDLP endpoint was disabled :(
Tips:
- "Feed expiry interval [hours]": regardless of what the repeatedly modified plugin does, setting this Serviio option to 5h seems smart, because curently YT links exipres after 6h. It works for me.
- it is good practice, for any server platform, to restart Serviio service once every 24 hours: e.g. simple night batch with STOP/START and much less chance of any potential problems. It works for me.
- refresh time for "Online sources" can be relatively long: changes take time and become visible for DLNA terminals after some time (1min..1hour)
- if You experience too often e.g. YTDPL.ONLINE service overloads or domain unavailability, it is worth considering using a plugin based on LOCAL YT-DLP executable (easy installation for nas/linux/win/MacOS)
Kindly reminding - add online source as "Web Resource" and edit "Source URL" like this:
https://www.googleapis.com/youtube/v3/search?q={YOUR_STRING_TO_FIND}&order=date //general SEARCHES
https://www.googleapis.com/youtube/v3/channels?id={CHANNEL_ID}&order=date //for channel ID
https://www.googleapis.com/youtube/v3/playlistItems?playlistId={PLAYLIST_ID}&order=date //for playlist ID
(... or anything that is YT api v3 compliant)
Examples for cool Polish cartoon series "Reksio":
https://www.googleapis.com/youtube/v3/search?q=reksio+terapeuta+seria+reksio&order=date
https://www.googleapis.com/youtube/v3/channels?id=UCfXtDCs237pyDFCBIQR46yw&order=date
https://www.googleapis.com/youtube/v3/playlistItems?playlistId=PLdD_ZqnsrJc9MrHf_oMV_CwKVmlCrkoW1&order=date
where:
{YOUR_STRING_TO_FIND}= "reksio+terapeuta+seria+reksio"
{CHANNEL_ID}= "UCfXtDCs237pyDFCBIQR46yw"
{PLAYLIST_ID}= "PLdD_ZqnsrJc9MrHf_oMV_CwKVmlCrkoW1"
Thanks to YT-DLP Team, which handles the YT signature problem efficiently and smoothly for many, many years :)
Enjoj and You're welcome with requests, questions or suggestions: http://itx0.cba.pl?s=Serviio :)
Youtube.groovy
(17.17 KiB) Downloaded 234 times
it.x
Post Thu May 22, 2025 1:16 am
Re: YouTube
"YouTube.groovy" based on WEB YT-DLP tool, You can get for free ABOVE.
"YouTube.groovy" based on LOCAL YT-DLP executable, for symbolic fee, with AUTOMATIC FAST DELIVERY (24/7), is available here:
http://itx0.cba.pl?s=Serviio_YouTube_plugin_based_on_YT-DLP_local_executable_AUTOMATIC_FAST_DELIVERY
Requirements:
- Your environment must have a working copy of Serviio Media Streaming Server :) and You have to make at least one dollar donation :)
- Your environment must have a working copy of YT-DLP executable and You must be able to point the path to it, by editing the indicated line in "YouTube.groovy" (text file).
- Your environment must be able to maintain normal Srviio loads + few instances of local YT-DLP executable: classic dual core machine is enough.
Delivery:
- You will receive an email with password protected link to plugin and short instruction (zip 6/20KB) after donating at least one dollar :)
- AUTOMATIC 24/7 email with crowdfunding service: buycoffee.to
Notice:
- changes made by me allow to use YouTube with Serviio since 2021 (first maintain Google data API v.3, next plugin based on YT-DLP tool) and please treat them as working bypass or template. Original version of script is published for free on this forum.
- 11.02.2026: changes ensuring functionality
- all Donors will receive further updates as they are developed
- 13.10.2026: effectiveness depends on version and configuration YTDLP local executable.
I will be happy to answer any questions - feel free to ask.
Previous
Return to Available plugins
