Re: Compatible devices list
NOT compatible: Libratone New Zipp Mini
But both Libratones should work well, they are using the same codecs! But the Mini says "Source not found Code 716" with BubbleUPNP as used app.
Greets
Vritra
atc98092 wrote:I have no idea what a Libratone is.
bkgeist wrote:I use five different Roku throughout my house for five different television sets. The Serviio and the streaming application available through Roku work well. One issue: no fast forward or rewind for streaming video. Bummer! Other than this though, I really love being able to stream my saved TV programs to any TV in the house. The Roku streaming utility and Serviio work well together. I also have access to photos and audio files, though I do not make use of this as much.
Meelis wrote:NOT compatible: Philips 55POS9002
OK: mkv HD works only with (Panasonic Viera 2013) profile.
NOT OK: mkv 4K works somehow with huge problems and only with (Samsung TV / player (J-series) profile. Sound is cutting, picture hangs. Overall impossible to watch. Not working.
PROBLEM: No profile where both HD and 4K will work together. Need to switch all the time between profiles. 4K videos problematic.
server: synology DS718+
