Backup Serviio settings.
How do I backup my Serviio settings, library, presentation choices etc? I would like to have them saved for reference / import (if required) at a later date.
Thanks!
zip wrote:They are in the library folder, together with all the media files information.
drwxr-xr-x 9 serviio root 4096 Aug 28 21:37 .
drwxr-xr-x 20 root root 4096 Sep 20 07:50 ..
-rw-r--r-- 1 serviio root 3255 Aug 28 21:36 LICENCE.txt
-rw-r--r-- 1 serviio root 10900 Aug 28 21:36 NOTICE.txt
-rw-r--r-- 1 serviio root 3396 Aug 28 21:36 README.txt
-rw-r--r-- 1 serviio root 40510 Aug 28 21:36 RELEASE_NOTES.txt
drwxr-xr-x 2 serviio root 4096 Sep 20 07:28 bin
drwxr-xr-x 3 serviio root 4096 Aug 28 21:36 config
drwxr-xr-x 2 serviio root 4096 Aug 28 21:36 legal
drwxr-xr-x 3 serviio root 4096 Aug 28 21:36 lib
drwxr-xr-x 5 serviio root 4096 Sep 12 20:32 library
drwxr-xr-x 2 serviio users 4096 Aug 28 21:37 log
drwxr-xr-x 2 serviio root 4096 Aug 28 21:36 plugins
DiskStation> pwd
/volume1/@appstore/ServiioDiskStation> cd library
DiskStation> ls -al
drwxr-xr-x 5 serviio root 4096 Sep 12 20:32 .
drwxr-xr-x 9 serviio root 4096 Aug 28 21:37 ..
drwxr-xr-x 2 serviio users 4096 Sep 20 07:28 cache
drwxr-xr-x 5 serviio users 4096 Sep 20 07:28 db
-rw-r--r-- 1 serviio root 164 Aug 28 21:36 derby.properties
drwxr-xr-x 2 serviio users 4096 Sep 20 07:54 search
DiskStation>
zip wrote:the settings are stored in the sql database, not a config file
atc98092 wrote:If your Serviio install on both OSs are on the same drive (i.e. they are both installed on your C drive), and your media is also in matching locations (either on separate drives with the same drive letters or on the OS drive), then copying the library folder should be all you need to do. Install Serviio on the second OS, then stop the Serviio process and copy the library folder onto the 2nd OS install.
Users browsing this forum: Google [Bot] and 9 guests
