Nokia Streaming Box 8000
Quillan
Post Mon Jun 27, 2022 4:12 pm
Hi, I have a Nokia Streaming Box 8000. The operating system says Android TV. I cannot install ServiiGo. For this device I cannot find the app in the app store and if I try to install the apk from a memory stick I get a message that it can't be installed on this device. All other apps work on this box without a problem. I have a work around which is to use a tablet or phone and because the Nokia box also has built in Chromecast but I would really like to install the apk. Any ideas?
Post Wed Jun 29, 2022 12:25 am
Re: Nokia Streaming Box 8000
You should probably post this in the ServiiGo area, as the developer might not see it here. viewtopic.php?f=17&t=6803
Just because something is running Android TV doesn't mean that all Android apps will install on them. I have several Nvidia Shield players, all of which run a version of Android TV, as well as the Onn 4K streaming player, which also runs Android TV. ServiiGo is not available for any of them. I'm not familiar with your streaming player, but odds are it won't run ServiiGo.
Users browsing this forum: No registered users and 75 guests
