Best profile for UE50RU7020KXXU
richierm257
Post Wed Jul 13, 2022 6:03 pm
Hi Folks anyone know what the Best profile for UE50RU7020KXXU is as i cant get my tv to play anything from serviio my D8000 only works if i use the generic profile when in the past it worked with the D profile
Thanks R...
Post Wed Jul 13, 2022 8:19 pm
Re: Best profile for UE50RU7020KXXU
The Samsung NU profile is the most recent profile I added. As to what profile would work the best for you, it's really dependent on your media content. If it's all in supported containers and using supported codecs, the generic profile is just fine. But if you have any lossless audio (TrueHD or DTS-MA), those will need at least audio transcoding. There's likely some video codecs that might not be supported by your TV, (AV-1 is one possibility) so those would need video transcoding.
Samsung DLNA support has gone downhill over the years, and their user interface is terrible (in my opinion). I gave up years ago playing anything directly on the TV, instead using a Blu Ray player, Roku player, or Android based player instead. Far less headache and a better user experience.
