QNAP QTS-5.0.1
sutrus
Post Fri May 20, 2022 2:31 pm
QNAP QTS-5.0.1
The new version of QTS 5.0.1 has just been released.
Serviio is limited in the installer to QTS_MAX_VERSION="5.0.0"
Is it possible to release a new version?
Thank you
Albibox
Post Mon Jun 06, 2022 2:00 pm
Re: QNAP QTS-5.0.1
HI all
on QNAP ARM based TS-431 with new firmware 5.0.0.1, Servio has been disabled because the package has no digital signature.
Is it possible to realease a new Serviio_2.2.1_arm-x41.qpkg packet digitally signed?
It should be a very simple task to do.
Thanks in advance
Albibox
sutrus
Post Mon Jun 06, 2022 4:29 pm
Re: QNAP QTS-5.0.1
Digital signature checking can be turned off in the App Center settings.
There is also a more complex way to bypass the QTS_MAX_VERSION limit of an already installed serviio.
A new installation with a QTS_MAX_VERSION limit cannot be bypassed without releasing a new version.
ianfretwell
Post Thu Jun 09, 2022 11:53 am
Re: QNAP QTS-5.0.1
"There is also a more complex way to bypass the QTS_MAX_VERSION limit of an already installed serviio."
Cool - could you actually tell us how then please ?
sutrus
Post Thu Jun 09, 2022 3:42 pm
Re: QNAP QTS-5.0.1
The way is through SSH. Install Winscp or a similar program.
This allows you to manage files as if they were Windows files.
Edit the QTS_MAX_VERSION entries in the qpkg.conf file.
The file can be found in the /etc/config folder.
Groover99
Post Tue Sep 13, 2022 5:17 am
Re: QNAP QTS-5.0.1
Same issue. Solved by
downgrade QTS to 5.0.0.1891 build 20211221
install serviio 2.2.1
upgrade QTS
ksergey2012
Post Fri Sep 16, 2022 5:22 am
Re: QNAP QTS-5.0.1
Qnap TS-453D QTS-5.0.1 also Serviio 2.2.1 - not working! I would like to know when the update will be?
farly
Post Fri Sep 16, 2022 12:00 pm
Re: QNAP QTS-5.0.1
downgrade QTS to 5.0.0.2131 build 20220815 and waiting to new version of Serviio
AnubisAmpu
Post Sat Sep 17, 2022 1:13 pm
Re: QNAP QTS-5.0.1
Hello all, please see bellow the fix for running serviio with QTS5.0.1 , it is not Qnap fault , the Serviio package was build with a max allowed limit for QTS 5.0.0, please see bellow how to fix :
connect to your qnap system via SSH ( putty )
go to config folder :
cd /etc/config
create a backup of your qpkg.conf file
cp qpkg.conf qpkg.conf.old
now edit the qpkg file :
vi qpkg.conf
this file contains all your installed packages details , go down till you find
[Serviio]
Status = complete
Name = Serviio
Build = 20211104
Display_Name = Serviio
Version = 2.2.1
Author = Petr Nejedly
QPKG_File = Serviio.qpkg
Date = 2022-02-09
Shell = /share/CACHEDEV1_DATA/.qpkg/Serviio/serviio.sh
Install_Path = /share/CACHEDEV1_DATA/.qpkg/Serviio
WebUI = /console
Web_Port = 23423
Web_SSL_Port = 23523
RC_Number = 171
FW_Ver_Min = 4.1.0
FW_Ver_Max = 5.0.0
Enable = FALSE
Delete the line : FW_Ver_Max = 5.0.0
save the file , go to app center click refresh and start Serviio
Enjoy
ksergey2012
Post Sat Sep 17, 2022 3:50 pm
Re: QNAP QTS-5.0.1
And if you deleted Serviio, then what to do? I tried to install Serviio v.1 which didn't install either. As a result, I deleted everything and now nothing is installed and, of course, there is no configuration file.
ksergey2012
Post Sat Sep 17, 2022 3:57 pm
Re: QNAP QTS-5.0.1
Probably the right thing to do would be to ask whoever oversees this project to rebuild the Serviio package.
AnubisAmpu
Post Sat Sep 17, 2022 4:48 pm
Re: QNAP QTS-5.0.1
ksergey2012 wrote:And if you deleted Serviio, then what to do? I tried to install Serviio v.1 which didn't install either. As a result, I deleted everything and now nothing is installed and, of course, there is no configuration file.
Go back to QTS 5 , install serviio , upgrade QTS , apply procedure ...... works
farly
Post Sat Sep 17, 2022 4:55 pm
Re: QNAP QTS-5.0.1
AnubisAmpu > works great, thank you.
Muttetjeff
Post Sat Sep 17, 2022 9:41 pm
Re: QNAP QTS-5.0.1
Thanks a lot it work for me too... ;)
jharris2
Post Sun Sep 18, 2022 2:40 am
Re: QNAP QTS-5.0.1
OK, I'm missing something - probably something pretty basic ... two issues:
  • When I try to copy the file the QNAP gives message "cannot create regular file `qpkg.conf.old': Permission denied".
  • When I follow the instructions from @AnubisAmpu, I receive a message ""qpkg.conf" E212: Can't open file for writing"
What is the obvious part that I'm missing??
Thanks!
jharris2
Post Sun Sep 18, 2022 3:26 am
Re: QNAP QTS-5.0.1
Problem solved - I needed to log in using the admin account, not an account in the administrator group. Not sure why that made a difference but it worked and Serviio is running again.
Thank you, @AnubisAmpu!
Kopasz
Post Mon Sep 19, 2022 3:42 pm
Re: QNAP QTS-5.0.1
Thank You very much AnubisAmpu! Based on Your instructions my Serviio server is working like a charm again. :)
Albibox
Post Wed Sep 21, 2022 2:21 pm
Re: QNAP QTS-5.0.1
thanks sutrus! set it to 5.0.9 (for now), app started again on my QNAP arm TS-431P
gasparirob
Post Sun Sep 25, 2022 1:01 pm
Re: QNAP QTS-5.0.1
Edited qpkg.conf via WinSCP.
It works!!!
thanks AnubisAmpu
RLoef
Post Tue Sep 27, 2022 3:05 pm
Re: QNAP QTS-5.0.1
Thanks, This worked for me :D
Users browsing this forum: Google [Bot] and 22 guests
