Serviio does no more run on QNAP
• Page 1 of 1
Hi, after the instalation of the new Firmware QTS 5.0.1.2145 on TS-431K does Serviio no more start. QTS reports that this version is not supported. Who can help me? Thanks Enyola
Re: Serviio does no more run on QNAP
Hi, I have the same issue here
"Failed to start Serviio. QTS does not support this Serviio version. Check for updates in "App Center" or on the official app website."
Any suggestions how to resolve it would be appreciated.
on TS-251A with QTS 5.0.1.2145
Me too
I have a TS-253D
I have a TS-253D
I'm having the same issue on a TS-453A,
firmware QTS 5.0.1.2145
I have the same problem
QTS 5.0.1.2145
TS-673A
QTS 5.0.1.2145
TS-673A
There's some suggestions in the NAS section of the forum. You might check those out and see if they help.
I can confirm that the instructions in the following topic (use ssh and edit the qpkg.conf file) worked just fine for me:
viewtopic.php?f=14&t=30245
atc98092, Fork: Right, that solution worked for me. Thanks!
• Page 1 of 1
Users browsing this forum: Google [Bot] and 51 guests
