Samsung UE65F9000 MKV h264 + EAC3 problem
kingarthas
Post Wed Sep 28, 2022 7:40 pm
Have an issue with Samsung UE65F9000 using E/F-series profile...
With stock profile MKV h264 + E-AC-3, however other files (for sure) those with E-AC-3 JOC do not run at all, and required new setting for transcoding/re-warping .
Is there an way to separate, so only E-AC-3 JOC to be modified ( e.g. by bit rate over 640 kb/s, please give a syntax)... By re-warping all EAC3, I`m loosing play controls (can not fast foreword or restart video from where it stop, also timestamp is wrong).
This one can not run on F-series without re-warping:
   <Video targetContainer="mpegts" forceInheritance="true">. However I can only set <Matches container="matroska" vCodec="h264" aCodec="eac3" /> . And it will re-warp all EAC3
Format                      : Matroska
Format version              : Version 4
File size                   : 1.74 GiB
Duration                    : 59 min 48 s
Overall bit rate mode       : Variable
Overall bit rate            : 4 169 kb/s
Writing application         : mkvmerge v70.0.0 ('Caught A Lite Sneeze') 64-bit
Writing library             : libebml v1.4.2 + libmatroska v1.6.4
Format                      : AVC
Format/Info                 : Advanced Video Codec
Format profile              : Main@L3.1
Format settings             : CABAC / 4 Ref Frames
Format settings, CABAC      : Yes
Format settings, Reference  : 4 frames
Codec ID                    : V_MPEG4/ISO/AVC
Bit rate mode               : Variable
Bit rate                    : 3 400 kb/s
Maximum bit rate            : 5 100 kb/s
Width                       : 1 280 pixels
Height                      : 720 pixels
Display aspect ratio        : 16:9
Frame rate mode             : Constant
Frame rate                  : 23.976 (24000/1001) FPS
Color space                 : YUV
Chroma subsampling          : 4:2:0
Bit depth                   : 8 bits
Scan type                   : Progressive
Bits/(Pixel*Frame)          : 0.154
Stream size                 : 1.42 GiB (81%)
Writing library             : x264 core 157 r2965 861cec4
Encoding settings           : cabac=1 / ref=4 / deblock=1:0:0 / analyse=0x1:0x111 / me=hex / subme=7 / psy=1 / psy_rd=1.00:0.00 / mixed_ref=1 / me_range=16 / chroma_me=1 / trellis=1 / 8x8dct=0 / cqm=0 / deadzone=21,11 / fast_pskip=1 / chroma_qp_offset=-2 / threads=22 / lookahead_threads=3 / sliced_threads=0 / nr=0 / decimate=1 / interlaced=0 / bluray_compat=0 / constrained_intra=0 / bframes=3 / b_pyramid=2 / b_adapt=1 / b_bias=0 / direct=1 / weightb=1 / open_gop=0 / weightp=2 / keyint=96 / keyint_min=96 / scenecut=40 / intra_refresh=0 / rc_lookahead=40 / rc=2pass / mbtree=1 / bitrate=3400 / ratetol=1.0 / qcomp=0.60 / qpmin=0 / qpmax=69 / qpstep=4 / cplxblur=20.0 / qblur=0.5 / vbv_maxrate=5100 / vbv_bufsize=2550 / nal_hrd=vbr / filler=0 / ip_ratio=1.40 / aq=1:1.00
Language                    : English
Default                     : Yes
Forced                      : No
Color range                 : Limited
Color primaries             : BT.709
Transfer characteristics    : BT.709
Matrix coefficients         : BT.709
Format                      : E-AC-3 JOC
Format/Info                 : Enhanced AC-3 with Joint Object Coding
Commercial name             : Dolby Digital Plus with Dolby Atmos
Codec ID                    : A_EAC3
Bit rate mode               : Constant
Bit rate                    : 768 kb/s
Channel(s)                  : 6 channels
Channel layout              : L R C LFE Ls Rs
Sampling rate               : 48.0 kHz
Frame rate                  : 31.250 FPS (1536 SPF)
Compression mode            : Lossy
Stream size                 : 329 MiB (18%)
Language                    : English
Service kind                : Complete Main
Default                     : Yes
Forced                      : No
Complexity index            : 16
Number of dynamic objects   : 15
Bed channel count           : 1 channel
Bed channel configuration   : LFE
e.g. this one run flawless with fast forward on F-series
Format                      : Matroska
File size                   : 6.45 GiB
Duration                    : 1 h 48 min
Overall bit rate            : 8 516 kb/s
Format                      : AVC
Format profile              : High@L4
Bit rate                    : 7 874 kb/s
Nominal bit rate            : 10 000 kb/s
Width                       : 1 920 pixels
Height                      : 800 pixels
Display aspect ratio        : 2.40:1
Color space                 : YUV
Bit depth                   : 8 bits
Bits/(Pixel*Frame)          : 0.214
Stream size                 : 5.96 GiB (92%)
Language                    : English
Default                     : Yes
Forced                      : No
Format                      : E-AC-3
Codec ID                    : A_EAC3
Bit rate                    : 640 kb/s
Stream size                 : 496 MiB (8%)
Language                    : English
Default                     : Yes
Forced                      : No
p.s
Strangely this Audio codec run natively on my UE43KU6072 (J-series profile), however with picture freezing or pixelizing at regular intervals. Then re-warping fix the issue caused by audio ?
fixed by adding :
Post Wed Sep 28, 2022 11:29 pm
Re: Samsung UE65F9000 MKV h264 + EAC3 problem
The one that won't play contains a Dolby Atmos track, and that's probably what's tripping your TV up. Unfortunately, I don't believe there's any way to only match media with Atmos, so all EAC-3 tracks would need to be transcoded to AC-3.
As far as losing trick play functions, you could try using a different transcoding target. For example, when I wrote the Roku profiles, transcoding to MPEG-TS would lose trick play (no resume, FF or rewind). But when I changed the target container to applehttp trick play became available. As a test, you could try using the Roku TV profile and see if that works. If it does, you could create a user profile file and add your EAC-3 transcoding for just those files. If your personal file inherits from the Samsung E/F profile, everything in the original profile will be used, except for any specific matches you place in your user profile file.
kingarthas
Post Thu Sep 29, 2022 12:13 am
Thanks for replay (without asking about the sister, i do not have)....
Unfortunately my TV with original SEC-1500 is not able to play applehttp. Strangely ASF do not work either.
I test:
<Video targetContainer="applehttp">
However the targetContainer="mpegts", do not impair fast forward on UE43KU6072. And fix the issues with freezing frames and pixelaizing picture (one of those depending on the file :)).
Post Thu Sep 29, 2022 12:14 am
Sounds like a solution :D
kingarthas
Post Fri Oct 07, 2022 7:14 pm
Still can not figure it out where the problem is coming from, on Samsung UE65F9000 using E/F-series profile...
As some Atmos E-AC-3 JOC are working, other not (mostly NOT working)
Here is an example of file that stats:
Some 1080p.HMAX.WEBRip.DDP5.1.Atmos.x264-SMURF[rartv]
Format                      : Matroska
File size                   : 1.71 GiB
Duration                    : 58 min 41 s
Overall bit rate            : 4 166 kb/s
Format                      : AVC
Height                      : 720 pixels
Color space                 : YUV
Bit depth                   : 8 bits
Stream size                 : 1.39 GiB (81%)
Language                    : English
Default                     : Yes
Forced                      : No
Format                      : E-AC-3 JOC
Codec ID                    : A_EAC3
Bit rate                    : 768 kb/s
Stream size                 : 322 MiB (18%)
Language                    : English
Default                     : Yes
Forced                      : No
Text #1
Users browsing this forum: Google [Bot] and 43 guests
