Philips DLNA burned in subtitles
D.ADY
Post Sun Dec 27, 2020 7:33 pm
I own a Philips 65PUS7354/12.
Background:
Unfortunately, this Philips does not support .srt soft subtitles, so using my router's build-in DLNA server is no longer possible if I also want subtitles with my movies.
This is why I turned to serviio for the file formats that need .srt subtitles and don't have them built-in (like some .mkv files).
There would be 2 options:
1. mix-in the subtitles and then play the movies. This is very annoying to do as you need to pre-process the movies.
2. transcode the movie and burn in the subtitles on the go.
Unfortunately this is very CPU consuming, but it's easy to setup.
Pros:
- no prior setup to be done.
- subtitles can be downloaded automatically
Cons:
- the PC doing it will be using a lot of resources.
- Also, one more important thing I've noticed with this approach: skipping forward (fast-forward) no longer works properly. You can play and resume, but that's it.
The problem:
Trying to burn in the subtitles was pretty easy to setup, but it didn't work:
- used the "Philips 2010-" profile
- transcoding on
- build-in subtitles activated
- did all possible mixes of settings ith transcoding and subtitles.
Once the burn-in option is activated, the movie does not play at all, a spinner is blocked on the TV while it tries to start playing the movie.
ffmpeg is using 85% CPU power and there's a quite large .stf file being built in the background, but no movie.
The fix:
After digging around, I've seen the profile inherits most of the settings from the generic profile.
For transcoding and burning in the subtitles, it uses
targetContainer="mpeg"
This seems to be incompatible with Philips's DLNA implementation.
It works, however, with the targetContainer set to "mpegts".
So, overwriting the GenericTranscoding from the base profile did the trick:
<Profile id="plps2010" name="Philips (2010-)" extendsProfileId="1">
    <GenericTranscoding>
        <Video targetContainer="mpegts" targetVCodec="mpeg2video" targetACodec="ac3" aBitrate="384"/>
    </GenericTranscoding>
Wanted to leave this here as I wasted a lot of time finding this.
If anyone has a fix for the fast-forward problem, it would be nice to get some insight on that.
vn32427
Post Sat Oct 01, 2022 11:58 am
Re: Philips DLNA burned in subtitles
I want to try your "fix", but I cannot understand which file did you edit (the profile)?
Or is it a feature in the Console that I am missing...?
Thanks in advance.
Post Sat Oct 01, 2022 10:52 pm
I strongly urge you not to edit the generic profile. If you need something specific, you should instead create a user-profiles.xml file and create your own specific profile. This way when you install a future Serviio update you won't lose your customization, as the profiles.xml file is replaced with each update.
Return to Philips
