LG OLED48C14
montediaz
Post Fri Mar 25, 2022 8:13 pm
LG OLED48C14
hi,
LG OLED48C14
I want to DTS to ac3 convert with your product.
My Tv features
Picture Processor 4th Generation α9 Intelligent Processor4K Cinema HDR Yes
Supported HDR Formats Dolby Vision IQ, HDR 10 Pro, HLGFilmmaker Mode Yes
Ultra Brightness Yes (Pro) Resolution Booster Yes (4K)
Has Wide Color GamutMotion Pro OLED Motion Pro
Picture Mode 9 modes
(Live, Standard, Filmmaker, Eco, Cinema, Sports, Game, isf Expert (Light Room), isf Expert (Dark Room)4K HFR Yes
2K HFR YesHEVC Yes (4K/120p, 10-bit)
VP9 Yes (4K/60p, 10-bit)AV1 Yes (4K/60p, 10-bit)
Gaming Experience Auto Low Latency Mode, Variable Refresh RateG-Sync Compatibility (2K/4K)
FreeSync™ Compatibility YesHGIG Mode Yes
SOUND
Speaker System 2.2 Speaker SystemAudio Output 40W
Dolby Atmos YesSurround Sound Feature OLED Surround
Clear Sound Yes (Pro)Music Playback Via Bluetooth Yes
LG Sound Sync VarAudio Codec AC4, AC3(Dolby Digital), EAC3, HE-AAC, AAC, MP2, MP3, PCM, WMA, apt-X
Help me pelease.
Post Sat Mar 26, 2022 12:38 am
Re: LG OLED48C14
For testing purposes, try using the Roku 4K TV profile. It will transcode DTS to AC3, as well as the lossless codecs, such as TrueHD. If that works, you can just stick with that profile or build a new LG profile for your use.
montediaz
Post Sat Mar 26, 2022 5:00 am
Re: LG OLED48C14
atc98092 wrote:For testing purposes, try using the Roku 4K TV profile. It will transcode DTS to AC3, as well as the lossless codecs, such as TrueHD. If that works, you can just stick with that profile or build a new LG profile for your use.
I'm someone who doesn't know anything about these things. I would appreciate it if you could let me know where to find this profile and how to change it.
Tks.
montediaz
Post Sat Mar 26, 2022 8:45 am
Re: LG OLED48C14
it didn't work on my lg oled. When I switch to this profile, the TV does not show the newly added ones in the lists.
In the old days, it says the audio format is not supported and does not play the movie.
Post Sun Mar 27, 2022 3:56 am
Re: LG OLED48C14
OK, you might try some other 4K TV profiles, such as the Samsung NU series. One should have the right combination of transcoding commands.
montediaz
Post Sun Mar 27, 2022 9:48 am
Re: LG OLED48C14
atc98092 wrote:OK, you might try some other 4K TV profiles, such as the Samsung NU series. One should have the right combination of transcoding commands.
all profile tryed, not work.
Post Sun Mar 27, 2022 10:03 pm
Re: LG OLED48C14
That is puzzling. At least one of them should have done something.
After you set the new profile, did you press the Save button at the bottom of the screen? This is not the screen where you set the profile, but after you changed it and closed the settings window. There's a second Save button at the bottom of the screen when you return to the Status screen.
CountVonn
Post Sun May 15, 2022 10:44 pm
Re: LG OLED48C14
I was able to resolve DTS issues for my LG C10 (OLED48CXPUA) by modifying the LG profile in profiles.xml. Here's the default LG TV profile:
   <Profile id="8" name="LG TV / player" extendsProfileId="1">
      <Detection>
         <HttpHeaders>
            <friendlyName.dlna.org>LG.*</friendlyName.dlna.org>
         </HttpHeaders>
      </Detection>
      <!-- ResourceTransportProtocolHandler>org.serviio.upnp.protocol.http.transport.LGProtocolHandler</ResourceTransportProtocolHandler -->
      <MediaFormatProfiles>
         <MediaFormatProfile mime-type="video/mp4" name="">AVI</MediaFormatProfile>
      </MediaFormatProfiles>
      Transcoding doesn't seem to work and some files can be played natively:
      http://forum.serviio.org/viewtopic.php?f=12&t=3914#p26273
         <Video targetContainer="mpegts" targetVCodec="mpeg2video" targetACodec="ac3" >
            <Matches container="flv" />
               <Matches container="asf" vCodec="wmv2"/>
               <Matches container="rm" />
               <Matches container="wtv" />
      </Transcoding>-->
      <GenericTranscoding>
        <Video targetContainer="mpegts" targetVCodec="mpeg2video" targetACodec="ac3" />
      </GenericTranscoding>
      <MultipleAudioTrackAware>false</MultipleAudioTrackAware>
The transcoding config for the LG TV profile has been commented out. Apparently that fixed a bug from 2011: http://forum.serviio.org/viewtopic.php?f=12&t=3914#p26273
I changed my LG TV profile to the following and restarted Serviio:
      <Detection>
         <HttpHeaders>
         </HttpHeaders>
      </Detection>
            <Matches container="*" aCodec="dts-hd" />
This works great for my LG C10 (OLED48CXPUA), using Serviio to play media with a DTS track no longer gives me an "Audio not supported" message on the display. @montediaz, I think this solution would work as well with your OLED48C14. We've got practically the same TV except yours is a year newer.
bern
Post Sun Oct 16, 2022 10:37 am
Re: LG OLED48C14
CountVonn wrote:.......
Hi, I have a new LG OLED55C21LA and ofcourse there is no DTS decoding/passtrough so I would like to try the transcoding. I've just installed serviio 2.2.1 on my Ubuntu machine and changed "LG TV / player" section in the profiles.xml (as described in prevoius post) but unfortunately it doesn't work for me. When I select the movie with the DTS audio track I can watch only video without the audio (there is no sound). What to change to have transcoding DTS stream to AC3 in the fly without touching the video?
Post Sun Oct 16, 2022 7:08 pm
Re: LG OLED48C14
When you are playing the video on the TV, look at the Serviio console on the Status tab, and see if it shows the video being transcoded. If it's playing native, the play indicator is green. If it's being transcoded, it is more of an orange color. If it's green, then we need to look deeper as to why it's not transcoding. If it is transcoding, then we need to see a detailed log of the playback, so we can look at the ffmpeg command being used and perhaps find a solution for you.
bern
Post Mon Oct 17, 2022 6:30 am
Re: LG OLED48C14
Thanks,
Lets see example of the mkv file with DTS steream:
Unique ID                      : 176277916532985788741644484851601702463 (0x849DE44CE82EAB52A8C28A8534CAFE3F)
Complete name                  : X:\The.Hobbit.The.Battle.of.the.Five.Armies.2014.720p.BluRay.x264[rarbg]\The.Hobbit.The.Battle.of.the.Five.Armies.2014.720p.BluRay.x264.mkv
Format                         : Matroska
Format version                 : Version 4
File size                      : 6.56 GiB
Duration                       : 2 h 24 min
Overall bit rate               : 6 496 kb/s
Encoded date                   : UTC 2015-03-05 21:19:17
Writing application            : mkvmerge v6.2.0 ('Promised Land') built on Apr 28 2013 12:22:01
Writing library                : libebml v1.3.0 + libmatroska v1.4.0
Format                         : AVC
Format/Info                    : Advanced Video Codec
Format profile                 : High@L4.1
Format settings                : CABAC / 5 Ref Frames
Format settings, CABAC         : Yes
Format settings, Reference fra : 5 frames
Codec ID                       : V_MPEG4/ISO/AVC
Bit rate                       : 4 985 kb/s
Width                          : 1 280 pixels
Height                         : 536 pixels
Display aspect ratio           : 2.40:1
Frame rate mode                : Constant
Frame rate                     : 23.976 FPS
Color space                    : YUV
Chroma subsampling             : 4:2:0
Bit depth                      : 8 bits
Scan type                      : Progressive
Bits/(Pixel*Frame)             : 0.303
Stream size                    : 4.90 GiB (75%)
Writing library                : x264 core 144 r2525 40bb568
Encoding settings              : cabac=1 / ref=5 / deblock=1:0:0 / analyse=0x3:0x133 / me=umh / subme=7 / psy=1 / psy_rd=1.00:0.00 / mixed_ref=1 / me_range=16 / chroma_me=1 / trellis=1 / 8x8dct=1 / cqm=0 / deadzone=21,11 / fast_pskip=0 / chroma_qp_offset=-2 / threads=18 / lookahead_threads=3 / sliced_threads=0 / nr=0 / decimate=1 / interlaced=0 / bluray_compat=0 / constrained_intra=0 / bframes=3 / b_pyramid=2 / b_adapt=1 / b_bias=0 / direct=1 / weightb=1 / open_gop=0 / weightp=2 / keyint=250 / keyint_min=23 / scenecut=40 / intra_refresh=0 / rc_lookahead=40 / rc=2pass / mbtree=1 / bitrate=4985 / ratetol=1.0 / qcomp=0.60 / qpmin=0 / qpmax=69 / qpstep=4 / cplxblur=20.0 / qblur=0.5 / ip_ratio=1.40 / aq=1:1.00
Language                       : English
Default                        : Yes
Forced                         : No
Format                         : DTS
Format/Info                    : Digital Theater Systems
Codec ID                       : A_DTS
Bit rate mode                  : Constant
Bit rate                       : 1 509 kb/s
Channel(s)                     : 6 channels
Channel layout                 : C L R Ls Rs LFE
Sampling rate                  : 48.0 kHz
Frame rate                     : 93.750 FPS (512 SPF)
Bit depth                      : 24 bits
Compression mode               : Lossy
Stream size                    : 1.52 GiB (23%)
Language                       : English
Default                        : Yes
Forced                         : No
My current serviio:
2022-10-17T07:40:46,515 INFO  [MediaServer] ------------------------------------------------------------------------
2022-10-17T07:40:46,518 INFO  [MediaServer] Serviio DLNA media streaming server v 2.2.1 (rev. 7dfe9e60ec4aa7e219630fa16aecf232e8b7bef0)
2022-10-17T07:40:46,518 INFO  [MediaServer] Petr Nejedly 2009-2018
2022-10-17T07:40:46,519 INFO  [MediaServer] http://www.serviio.org
2022-10-17T07:40:46,519 INFO  [MediaServer] Java 1.8.0_342-Private Build amd64
2022-10-17T07:40:46,519 INFO  [MediaServer] OS Linux 5.15.0-50-generic
2022-10-17T07:40:46,519 INFO  [MediaServer] File encoding: UTF-8
2022-10-17T07:40:46,520 INFO  [MediaServer] Headless mode enabled: true
2022-10-17T07:40:46,520 INFO  [MediaServer] User: root
2022-10-17T07:40:46,520 INFO  [MediaServer] User home dir: /root
2022-10-17T07:40:46,520 INFO  [MediaServer] Temp dir: /tmp
2022-10-17T07:40:46,520 INFO  [MediaServer] ------------------------------------------------------------------------
2022-10-17T07:40:46,525 INFO  [DBSchemaUpdateExecutor] Checking if DB schema needs to be updated
2022-10-17T07:40:46,532 INFO  [DatabaseManager] Using DERBY database language
2022-10-17T07:40:47,296 INFO  [WebServer] Socket buffer set to 65535 bytes
2022-10-17T07:40:47,297 INFO  [RestletServer] Starting HTTP/1.1 Restlet server (/console) exposed on port 23423
2022-10-17T07:40:47,301 INFO  [RestletServer] Starting HTTP/1.1 Restlet server (/rest) exposed on port 23423
2022-10-17T07:40:47,304 INFO  [RestletServer] Starting HTTPS/1.1 Restlet server (/console) exposed on port 23523
2022-10-17T07:40:47,304 INFO  [RestletServer] Starting HTTPS/1.1 Restlet server (/rest) exposed on port 23523
2022-10-17T07:40:47,590 INFO  [RestletServer] Starting HTTP/1.1 Restlet server (/cds) exposed on port 23424
2022-10-17T07:40:47,591 INFO  [RestletServer] Starting HTTP/1.1 Restlet server (/mediabrowser) exposed on port 23424
2022-10-17T07:40:47,592 INFO  [RestletServer] Starting HTTPS/1.1 Restlet server (/cds) exposed on port 23524
2022-10-17T07:40:47,593 INFO  [RestletServer] Starting HTTPS/1.1 Restlet server (/mediabrowser) exposed on port 23524
2022-10-17T07:40:47,739 INFO  [MediaServer] ------------------------------------------------------------------------
2022-10-17T07:40:47,740 INFO  [MediaServer] License: PRO (EVALUATION, id: 11111111-1111-1111-1111-111111111113)
2022-10-17T07:40:47,740 INFO  [MediaServer] ------------------------------------------------------------------------
2022-10-17T07:40:47,756 INFO  [Device] Created UPnP Device with UUID: 83728232-23bd-3fd0-b542-51f2ebc729db, bound address: 10.10.11.1
2022-10-17T07:40:47,875 INFO  [ProfileManager] Loading profiles from file /profiles.xml
2022-10-17T07:40:48,199 INFO  [ProfilesDefinitionParser] Parsing Profiles definition
2022-10-17T07:40:48,241 INFO  [CustomisationManager] No customisation properties found
2022-10-17T07:40:48,311 INFO  [ProfilesDefinitionParser] Added profile 'Generic DLNA profile' (id=1)
2022-10-17T07:40:48,326 INFO  [ProfilesDefinitionParser] Added profile 'Samsung TV (B-series)' (id=2)
2022-10-17T07:40:48,331 INFO  [ProfilesDefinitionParser] Added profile 'Xbox 360' (id=3)
2022-10-17T07:40:48,332 INFO  [ProfilesDefinitionParser] Added profile 'Playstation 3' (id=4)
2022-10-17T07:40:48,333 INFO  [ProfilesDefinitionParser] Added profile 'Playstation 4' (id=ps4)
2022-10-17T07:40:48,334 INFO  [ProfilesDefinitionParser] Added profile 'Samsung TV (A-series)' (id=5)
2022-10-17T07:40:48,338 INFO  [ProfilesDefinitionParser] Added profile 'DirecTV HD-DVR' (id=6)
2022-10-17T07:40:48,340 INFO  [ProfilesDefinitionParser] Added profile 'Samsung TV / player (H-series)' (id=sam_h)
2022-10-17T07:40:48,342 INFO  [ProfilesDefinitionParser] Added profile 'Samsung TV / player (J-series)' (id=sam_j)
2022-10-17T07:40:48,343 INFO  [ProfilesDefinitionParser] Added profile 'Samsung TV / player (M-series)' (id=sam_m)
2022-10-17T07:40:48,344 INFO  [ProfilesDefinitionParser] Added profile 'Samsung TV (NU-series)' (id=Samsung_NU)
2022-10-17T07:40:48,344 INFO  [ProfilesDefinitionParser] Added profile 'Samsung TV / player (E/F-series)' (id=sam_ef)
2022-10-17T07:40:48,345 INFO  [ProfilesDefinitionParser] Added profile 'Samsung TV / player (C/D-series)' (id=7)
2022-10-17T07:40:48,346 INFO  [ProfilesDefinitionParser] Added profile 'LG TV / player' (id=8)
2022-10-17T07:40:48,349 INFO  [ProfilesDefinitionParser] Added profile 'Sony Bravia TV (2012)' (id=sony2012)
2022-10-17T07:40:48,351 INFO  [ProfilesDefinitionParser] Added profile 'Sony Bravia TV (2013/14)' (id=sony2013)
2022-10-17T07:40:48,352 INFO  [ProfilesDefinitionParser] Added profile 'Sony BDP-Sx100 (2013)' (id=bdp2013)
2022-10-17T07:40:48,353 INFO  [ProfilesDefinitionParser] Added profile 'Sony BDP-Sx90 (2012)' (id=bdp2012)
2022-10-17T07:40:48,355 INFO  [ProfilesDefinitionParser] Added profile 'Sony BDP-Sx70/SMP-N100 (2010)' (id=bdp2010)
2022-10-17T07:40:48,355 INFO  [ProfilesDefinitionParser] Added profile 'Sony BDP-Sx70/SMP-N100 (2010) - US' (id=bdp2010us)
2022-10-17T07:40:48,356 INFO  [ProfilesDefinitionParser] Added profile 'Sony BDP-Sx80/SMP-N200 (2011)' (id=bdp2011)
2022-10-17T07:40:48,356 INFO  [ProfilesDefinitionParser] Added profile 'Toshiba REGZA' (id=13)
2022-10-17T07:40:48,357 INFO  [ProfilesDefinitionParser] Added profile 'Toshiba REGZA 2012-' (id=tosh2012)
2022-10-17T07:40:48,359 INFO  [ProfilesDefinitionParser] Added profile 'WDTV Live' (id=14)
2022-10-17T07:40:48,360 INFO  [ProfilesDefinitionParser] Added profile 'LaCie LaCinema Media Player' (id=15)
2022-10-17T07:40:48,360 INFO  [ProfilesDefinitionParser] Added profile 'Manta WIFI Centre' (id=16)
2022-10-17T07:40:48,365 INFO  [ProfilesDefinitionParser] Added profile 'Pure Flow' (id=17)
2022-10-17T07:40:48,366 INFO  [ProfilesDefinitionParser] Added profile 'Sharp Aquos' (id=18)
2022-10-17T07:40:48,366 INFO  [ProfilesDefinitionParser] Added profile 'Sony Bravia TV (2011)' (id=sony2011)
2022-10-17T07:40:48,367 INFO  [ProfilesDefinitionParser] Added profile 'Sony Bravia TV (2010)' (id=sony2010)
2022-10-17T07:40:48,368 INFO  [ProfilesDefinitionParser] Added profile 'Philips (2010-)' (id=plps2010)
2022-10-17T07:40:48,368 INFO  [ProfilesDefinitionParser] Added profile 'Philips (2009)' (id=20)
2022-10-17T07:40:48,369 INFO  [ProfilesDefinitionParser] Added profile 'Sony Bravia TV (2009)' (id=sony2009)
2022-10-17T07:40:48,370 INFO  [ProfilesDefinitionParser] Added profile 'Denon AVR' (id=22)
2022-10-17T07:40:48,371 INFO  [ProfilesDefinitionParser] Added profile 'Panasonic Viera (2013)' (id=viera2013)
2022-10-17T07:40:48,372 INFO  [ProfilesDefinitionParser] Added profile 'Panasonic Viera G/GT/DT/UT/VT (2011/2012)' (id=viera2011a)
2022-10-17T07:40:48,372 INFO  [ProfilesDefinitionParser] Added profile 'Panasonic Viera E/S/ST/VT (2011)' (id=viera2011)
2022-10-17T07:40:48,373 INFO  [ProfilesDefinitionParser] Added profile 'Panasonic Viera (2010)' (id=viera2010)
2022-10-17T07:40:48,373 INFO  [ProfilesDefinitionParser] Added profile 'Panasonic Viera (2009)' (id=viera2009)
2022-10-17T07:40:48,373 INFO  [ProfilesDefinitionParser] Added profile 'Sony Bravia TV (2012) - US' (id=sony2012us)
2022-10-17T07:40:48,374 INFO  [ProfilesDefinitionParser] Added profile 'Sony Bravia TV (2011) - US' (id=sony2011us)
2022-10-17T07:40:48,374 INFO  [ProfilesDefinitionParser] Added profile 'Sony AVReceiver STR' (id=SonySTR)
2022-10-17T07:40:48,375 INFO  [ProfilesDefinitionParser] Added profile 'Sony Audio CMT' (id=SonyCMT)
2022-10-17T07:40:48,375 INFO  [ProfilesDefinitionParser] Added profile 'Vizio TV' (id=viziotv)
2022-10-17T07:40:48,376 INFO  [ProfilesDefinitionParser] Added profile 'Panasonic BD player' (id=panasonicBDT220)
2022-10-17T07:40:48,376 INFO  [ProfilesDefinitionParser] Added profile 'Philips NP Streamium' (id=philips_streamium)
2022-10-17T07:40:48,377 INFO  [ProfilesDefinitionParser] Added profile 'Chaneru' (id=roku)
2022-10-17T07:40:48,378 INFO  [ProfilesDefinitionParser] Added profile 'Roku Media Player' (id=RokuMPApp)
2022-10-17T07:40:48,378 INFO  [ProfilesDefinitionParser] Added profile 'Roku 4K Media Player (2016+)' (id=Roku4kMPApp)
2022-10-17T07:40:48,379 INFO  [ProfilesDefinitionParser] Added profile 'Roku 1080 Media Player (2016+)' (id=RokuNo4kApp)
2022-10-17T07:40:48,379 INFO  [ProfilesDefinitionParser] Added profile 'Roku TV (non 4K)' (id=RokuTV)
2022-10-17T07:40:48,380 INFO  [ProfilesDefinitionParser] Added profile 'Roku 4K TV' (id=Roku4kTV)
2022-10-17T07:40:48,380 INFO  [ProfilesDefinitionParser] Added profile 'Roku 4K Media Player w/MPEG2' (id=Roku4kMPM2)
2022-10-17T07:40:48,381 INFO  [ProfilesDefinitionParser] Added profile 'Yamaha BD-A1020/BD-A1010' (id=YamBD)
2022-10-17T07:40:48,381 INFO  [ProfilesDefinitionParser] Added profile 'Telenet Yelo TV' (id=TNDC)
2022-10-17T07:40:48,382 INFO  [ProfilesDefinitionParser] Added profile 'Xbox One S/Xbox One X' (id=xbox_one_s_x)
2022-10-17T07:40:48,382 INFO  [ProfilesDefinitionParser] Added profile 'Xbox One' (id=xbox_one)
2022-10-17T07:40:48,383 INFO  [ProfilesDefinitionParser] Added profile 'Raumfeld' (id=raumfeld)
2022-10-17T07:40:48,384 INFO  [ProfileManager] Loading profiles from file /application-profiles.xml
2022-10-17T07:40:48,442 INFO  [ProfilesDefinitionParser] Parsing Profiles definition
2022-10-17T07:40:48,443 INFO  [ProfilesDefinitionParser] Added profile 'Flash player' (id=flv_player)
2022-10-17T07:40:48,444 INFO  [ProfilesDefinitionParser] Added profile 'HTML5' (id=html5)
2022-10-17T07:40:48,445 INFO  [ProfilesDefinitionParser] Added profile 'HTML5 Mobile' (id=html5_mobile)
2022-10-17T07:40:48,445 INFO  [ProfilesDefinitionParser] Added profile 'ServiiGo (Standard)' (id=serviigo_standard)
2022-10-17T07:40:48,446 INFO  [ProfilesDefinitionParser] Added profile 'ServiiGo (Legacy Devices)' (id=serviigo)
2022-10-17T07:40:48,447 INFO  [ProfilesDefinitionParser] Added profile 'ServiiGo (HLS)' (id=serviigo_hls)
2022-10-17T07:40:48,447 INFO  [ProfilesDefinitionParser] Added profile 'ServiiGo (Google TV)' (id=serviigo_gtv)
2022-10-17T07:40:48,448 INFO  [ProfilesDefinitionParser] Added profile 'Google Cast' (id=googlecast)
2022-10-17T07:40:48,448 INFO  [ProfilesDefinitionParser] Added profile 'Chromecast' (id=chromecast)
2022-10-17T07:40:48,449 INFO  [ProfilesDefinitionParser] Added profile 'Alexa' (id=alexa)
2022-10-17T07:40:48,449 INFO  [ProfileManager] User profiles definition (user-profiles.xml) not found, using built-in profiles only
2022-10-17T07:40:48,491 INFO  [PluginCompilerThread] Looking for plugins at /opt/serviio-2.2.1/plugins
2022-10-17T07:40:48,492 INFO  [PluginCompilerThread] Started looking for plugins
2022-10-17T07:40:48,495 INFO  [UpdateChecker] Checking if a new version is available
2022-10-17T07:40:48,617 INFO  [FFMPEGWrapper] Found FFmpeg: ffmpeg
2022-10-17T07:40:48,618 INFO  [FFMPEGWrapper] FFmpeg details: [version=4.4.2-0ubuntu0.22.04.1, libRtpmPresent=false, libAssPresent=true, libShinePresent=true, libMxfPresent=true, nvEncPresent=false]
2022-10-17T07:40:48,638 INFO  [AbstractAVTranscodingDeliveryEngine] Cleaning transcode engine and its data
2022-10-17T07:40:48,846 INFO  [TrakttvService] Started trakt.tv sync updater
2022-10-17T07:40:48,847 INFO  [TrakttvService] Started trakt.tv scrobble poster
2022-10-17T07:40:48,867 INFO  [PlaybackProgressUpdater] Started playback progress updater
2022-10-17T07:40:48,883 INFO  [Device] Updated bound IP address of Device with UUID: 83728232-23bd-3fd0-b542-51f2ebc729db, bound address: 10.10.11.1
2022-10-17T07:40:48,883 INFO  [WebServer] WebServer starting on port 8895
2022-10-17T07:40:48,891 INFO  [EventSubscriptionExpirationChecker] Starting EventSubscriptionExpirationChecker
2022-10-17T07:40:48,892 INFO  [EventDispatcher] Starting EventDispatcher
2022-10-17T07:40:48,893 INFO  [DiscoveryAdvertisementNotifier] Starting DiscoveryAdvertisementNotifier
2022-10-17T07:40:48,893 INFO  [DiscoverySSDPMessageListener] Starting DiscoverySSDPMessageListener using interface wlp4s0 (wlp4s0) and address 10.10.11.1, timeout = 0
2022-10-17T07:40:48,897 INFO  [RendererSearchSender] Starting Renderer searcher process
2022-10-17T07:40:48,897 INFO  [RendererExpirationChecker] Starting RendererExpirationChecker
2022-10-17T07:40:50,203 INFO  [FileDeltaWatcher] Using 'sun.nio.fs.LinuxWatchService' for delta scan
The log debug output when I try to play the file:
https://www.dropbox.com/s/ebkcsbkj6g7yb ... .txt?raw=1
My changed "LG TV / player" profile:
      <Detection>
         <HttpHeaders>
         </HttpHeaders>
      </Detection>
unfortunately no sound. I can play 5.1 content (AC3, EAC3, AAC) normally (optical SPDIF output).
Post Mon Oct 17, 2022 12:45 pm
Re: LG OLED48C14
OK, from the detailed log, your file is not being transcoded: "Delivering file 'The.Hobbit.The.Battle.of.the.Five.Armies.2014.720p.BluRay.x264.mkv' in native format" You didn't mention if the Serviio console had a green playback indicator, but my guess is that it was green.
Why it's not being transcoded, I can't answer. I know the developer has mentioned in the past that some TVs simply won't trigger transcoding, but I can't remember if LG was one like that. I don't use the internal player on any of my smart TVs, instead I use external players like Roku or the Nvidia Shield. Roku players work fine for transcoding, while the Shield can play anything without needing transcoding.
If Zip sees this conversation, perhaps he'll have some answer.
bern
Post Mon Oct 17, 2022 5:52 pm
Re: LG OLED48C14
atc98092 wrote:OK, from the detailed log, your file is not being transcoded: "Delivering file 'The.Hobbit.The.Battle.of.the.Five.Armies.2014.720p.BluRay.x264.mkv' in native format" You didn't mention if the Serviio console had a green playback indicator, but my guess is that it was green.
Thank you Dan.
Sorry I forgot mention. Serviio had a green playback indicator,
I also have Kodi installed on the home Ubuntu server machine on which I have serviio installed. The hardware (Gemini Like x64 Intel SoC processor) allows hardware video decoding/encoding e.g \. HEVC up to 4K. So using Kodi I do not need any audio/video transcoding but video playback on internal player looks little better to me (especially moving objects) although internal player is clunky and cumbersome at times with a small amount of customization options...
bern
Post Sun Oct 23, 2022 12:44 pm
Re: LG OLED48C14
I just want to confirm that DTS to AC3 transcoding (using @CountVonn settings) works on my LG LG OLED55C21LA.
In addition to changing the default LG profile and selecting this profile on connected LG TV device (using web Serviio UI) you have to switch 'Enable transcoding' checkbox (Delivery/Transcoding). :oops:
Thanks a lot. :)
EDIT:
audio DTS stream transcoded to ac3 sounds weak (at the default bitrate of 192k) So I change audio codec ac3
to aac
         <Video targetContainer="mpegts" targetACodec="aac">
which is (more efficient at 192k bitrate) and at the end the sound is far better.
Return to LG
