Not working after Windows 11 upgrade
steamroll420
Post Sat Mar 26, 2022 5:52 am
Recently updated to Windows 11 and nothing is working. Service wont start, get a "Could not start service Error 1067". I can't even get the console to open(tried running as administrator, nothing happens). Uninstalled, re-installed, tried legacy version, same thing every time. Updated to latest java. Have been getting a Java error when uninstalling (could not start virtual machine I believe).
Would appreciate any advice. Thanks in advance!
Post Sun Mar 27, 2022 3:57 am
Re: Not working after Windows 11 upgrade
Would you please upload your Serviio log here? You can find it under C:/Program Files/Serviio/log. Just the Serviio.log file. The Derby file isn't needed.
steamroll420
Post Sun Mar 27, 2022 10:54 pm
I went to the log file, and it was empty(nothing hidden). I was able to get rid of the Java error by editing the environmental variables. Still not luck. Tried uninstalling/RE and no luck. Here is the log when I uninstalled;
Sun Mar 27 16:46:51 EDT 2022:
Booting Derby version The Apache Software Foundation - Apache Derby - 10.14.2.0 - (1828579): instance a816c00e-017f-cd21-b0bc-00001ea85e32
on database directory C:\Program Files\Serviio\library\db with class loader jdk.internal.loader.ClassLoaders$AppClassLoader@73d16e93
Loaded from file:/C:/Program%20Files/Serviio/lib/derby.jar
java.vendor=Oracle Corporation
java.runtime.version=17.0.2+8-LTS-86
user.dir=C:\Program Files\Serviio\bin
os.name=Windows 11
os.arch=amd64
os.version=10.0
derby.system.home=C:\Program Files\Serviio\library
derby.stream.error.file=../log/derby.log
Database Class Loader started - derby.database.classpath=''
Still get can not start service on local computer/Error 1067: The process terminated unexpectedly.
After playing around a bit more, I found a few other programs with the same issue;
Plex-Never liked it, but had it on PC for a Backup. Tried un/re-installing, it won't run at all.
Oshare-UPNP server I used with my OPPO bluray player. Simple program that I have used for years with no issue. Program will run, but freeze up and not show up when searching for media players.
Universal Media Player-Works fine(prefer Serviio)
Anything in the event viewer I should look for?
Anyone heard of this issue when upgrading to Windows 11?
Odd situation. I might have to do a clean install. Not the worst, just time consuming.
Thanks in advance!
Post Mon Mar 28, 2022 12:02 am
On Windows, Serviio installs its own version of Java, so your Windows global environmental settings shouldn't do anything.
None of my computers are eligible for Windows 11, so I haven't been able to test the new OS. I'm going to have to try it in a VM and see what's going on.
It does sound like Microsoft did something during the upgrade that messed with Serviio. At this point, I'd suggest doing the clean install, but I'd remove Serviio completely first, just to make sure it's completely clean. I've heard of some people needing to do a clean install after a Windows update, so not unheard of. I've heard of the same thing on occasion after a Mac update, so Microsoft doesn't have a corner on the market for messing up applications with an upgrade.
Michalr
Post Thu Dec 08, 2022 9:17 pm
Hello, I'm on Win11 and have different issue - latest version of Serviio installed but cannot stream anything to the TV - it always says that the file is in wrong format. The folders and files are visible on the TV, you can connect to the server from the TV itself, but you cannot play any file. On Win10 all files were perfectly working.
dlzc
Post Tue Dec 13, 2022 3:56 pm
New install of Win11 on new hardware, and Serviio worked for a week or so, then Windoze breaks it. When it breaks, the Serviio console will not ever fully display... window has title bar but page is blank.
Micro$haft REALLY wants you to use their media player, so they can help spy on you better. I guess.
EDIT:
(KB5020044) broke Serviio
(KB5020880) and / or (KB5021255) fixed Serviio.
... so full updates "eventually" fix whatever Micro$haft breaks.
Michalr
Post Thu Dec 29, 2022 9:59 pm
Small update on this - it started to work again on the latest Insider Win 11 compilation.
Wysłane z mojego SM-G770F przy użyciu Tapatalka
