Out of memory exceptions
lebdron
Post Sat Jan 07, 2023 11:49 pm
Hello. Recently I started getting the following messages in the log, presumably leading to a system hang:
Jan  5 02:22:30 raspberrypi serviio.sh[162193]: [2426886.643s][warning][os,thread] Failed to start thread "Unknown thread" - pthread_create failed (EAGAIN) for attributes: stacksize: 2048k, guardsize: 0k, detached.
Jan  5 02:22:30 raspberrypi serviio.sh[162193]: [2426886.739s][warning][os,thread] Failed to start the native thread for java.lang.Thread "ServioThread-73951-DiscoveryNotifier"
Jan  5 02:22:30 raspberrypi kernel: [2456326.637800] cgroup: fork rejected by pids controller in /system.slice/serviio.service
Jan  5 02:22:30 raspberrypi serviio.sh[162193]: Exception in thread "ServioThread-72352-DiscoverySSDPMessageListener" java.lang.OutOfMemoryError: unable to create native thread: possibly out of memory or process/resource limits reached
Jan  5 02:22:30 raspberrypi serviio.sh[162193]: #011at java.base/java.lang.Thread.start0(Native Method)
Jan  5 02:22:30 raspberrypi serviio.sh[162193]: #011at java.base/java.lang.Thread.start(Thread.java:798)
Jan  5 02:22:30 raspberrypi serviio.sh[162193]: #011at org.serviio.upnp.discovery.DiscoveryManager.deviceAvailable(DiscoveryManager.java:134)
Jan  5 02:22:30 raspberrypi serviio.sh[162193]: #011at org.serviio.upnp.discovery.DiscoveryManager.restartDiscoveryEngine(DiscoveryManager.java:109)
Jan  5 02:22:30 raspberrypi serviio.sh[162193]: #011at org.serviio.upnp.discovery.Multicaster.getBoundNIC(Multicaster.java:46)
Jan  5 02:22:30 raspberrypi serviio.sh[162193]: #011at org.serviio.upnp.discovery.DiscoverySSDPMessageListener.run(DiscoverySSDPMessageListener.java:81)
Jan  5 02:22:30 raspberrypi serviio.sh[162193]: #011at java.base/java.lang.Thread.run(Thread.java:829)
Jan  5 02:23:55 raspberrypi serviio.sh[162193]: [2426971.829s][warning][os,thread] Failed to start thread "Unknown thread" - pthread_create failed (EAGAIN) for attributes: stacksize: 2048k, guardsize: 0k, detached.
Jan  5 02:23:55 raspberrypi serviio.sh[162193]: [2426971.833s][warning][os,thread] Failed to start the native thread for java.lang.Thread "ServioThread-73955-DiscoveryNotifier"
Jan  5 02:23:55 raspberrypi serviio.sh[162193]: Exception in thread "ServioThread-73948-DiscoverySSDPMessageListener" java.lang.OutOfMemoryError: unable to create native thread: possibly out of memory or process/resource limits reached
Jan  5 02:23:55 raspberrypi serviio.sh[162193]: #011at java.base/java.lang.Thread.start0(Native Method)
Jan  5 02:23:55 raspberrypi serviio.sh[162193]: #011at java.base/java.lang.Thread.start(Thread.java:798)
Jan  5 02:23:55 raspberrypi serviio.sh[162193]: #011at org.serviio.upnp.discovery.DiscoveryManager.deviceAvailable(DiscoveryManager.java:134)
Jan  5 02:23:55 raspberrypi serviio.sh[162193]: #011at org.serviio.upnp.discovery.DiscoveryManager.restartDiscoveryEngine(DiscoveryManager.java:109)
Jan  5 02:23:55 raspberrypi serviio.sh[162193]: #011at org.serviio.upnp.discovery.Multicaster.getBoundNIC(Multicaster.java:46)
Jan  5 02:23:55 raspberrypi serviio.sh[162193]: #011at org.serviio.upnp.discovery.DiscoverySSDPMessageListener.run(DiscoverySSDPMessageListener.java:81)
Jan  5 02:23:55 raspberrypi serviio.sh[162193]: #011at java.base/java.lang.Thread.run(Thread.java:829)
Is there anything I can do with it? Thank you.
Post Sun Jan 08, 2023 3:32 am
Re: Out of memory exceptions
You can increase the memory assigned to Java in the VMOptions file. I can't say where that file is located on your install, since you're not using Windows. Unfortunately, I can't recall the format of the command to add to the line. I thought I had it in my folder, but I just checked and it's not there.
Wait, I think I found it. Add -Xmx512m to the file I mentioned above. If 512m isn't enough, bump it to 1024m and try again. Make sure you restart the Serviio service after you make the change.
cmakula
Post Sun Jan 08, 2023 6:28 pm
The JVM options are located at the end of the serviio.sh file in the bin directory of the Linux/RasPi install. You can set the -Xmx512M options there.
Good Luck
:ugeek:
Serviio Server - Dell PowerEdge R420, Dual Xeon E5-2420, 4x120 GB SSD RAID 0, 64 GB RAM (Serviio running from RAMdisk), 4 NICs (aggregated to LAN), 10Gbe to NAS, Ubuntu Server 24.04.3
NFS File Server - Synology DS1517+, 20TB disk space (5x4TB), 4 NICs (aggregated to LAN), 10Gbe to Serviio Server
Users browsing this forum: Baidu [Spider] and 51 guests
