Some MP4's on LN46B750
swandive76
Post Tue Apr 26, 2011 5:14 am
I am having some troubles playing certain files on my Samsung LN46B750. They are mp4 format but I cant get them to work. I do have other mp4's that work in my library but dont know enough about this container to understand what the hicup is. Im hoping you can shed some light for me.
I did find that changing the Profile in Serviio to the Samsung A series did make these files playable but doing so I lost the ability to get any avi's that i have to play. Im not ready to dump all my avi's for mp4 at this time.
Here is the results of running the ffmpeg.exe command
C:\Program Files (x86)\Serviio\lib>ffmpeg.exe -i "F:\TV Share\Movies\Dad\Borne\b
ourne.mp4"
686-mingw32-
libavutil 50.36. 0 / 50.36. 0
libavcore 0.16. 0 / 0.16. 0
libavfilter 1.72. 0 / 1.72. 0
libswscale 0.12. 0 / 0.12. 0
Input #0, mov,mp4,m4a,3gp,3g2,mj2, from 'F:\TV Share\Movies\Dad\Borne\bourne.mp4
major_brand : isom
minor_version : 1
compatible_brands: isom
creation_time : 2011-01-06 02:02:32
Duration: 01:58:17.49, start: 0.000000, bitrate: 2725 kb/s
Stream #0.0(und): Video: h264, yuv420p, 1280x544 [PAR 1:1 DAR 40:17], 2324 k
b/s, 23.98 fps, 23.98 tbr, 24k tbn, 47.95 tbc
creation_time : 2011-01-05 15:19:47
Stream #0.1(eng): Audio: aac, 48000 Hz, 5.1, s16, 397 kb/s
creation_time : 2011-01-06 02:05:00
I am running Serviio on Win 7 (64bit)
Please let me know anything you can.
Thanks in advance
Swandive
Post Tue Apr 26, 2011 7:28 am
Re: Some MP4's on LN46B750
can you give us mediainfo on this file i have a feeling the profile level is to high.
swandive76
Post Tue Apr 26, 2011 2:59 pm
Is there a good tool you would recommend for getting the media info? It is a movie in the HDLite format.
Post Tue Apr 26, 2011 3:01 pm
swandive76 wrote:Is there a good tool you would recommend for getting the media info?
Lol.
MediaInfo
swandive76
Post Tue Apr 26, 2011 3:33 pm
duh! I feel dumb now.
Ill post the output of this later this evening
Thanks!
Post Tue Apr 26, 2011 4:57 pm
swandive76 wrote:duh! I feel dumb now.
Thanks!
:D sorry i should add that link to my signiture but havent got around to it yet :D
EDIT - link to media Info is now in my signiture for future reference. :)
swandive76
Post Wed Apr 27, 2011 1:41 am
Hows this? Let me know if I can provide anything else. Since I now have Media Info installed and know what it is!
Complete name                    : F:\TV Share\Movies\Dad\Borne\bourne.mp4
Format                           : MPEG-4
Format profile                   : Base Media
Codec ID                         : isom
File size                        : 2.25 GiB
Duration                         : 1h 58mn
Overall bit rate                 : 2 726 Kbps
Encoded date                     : UTC 2011-01-06 02:02:32
Tagged date                      : UTC 2011-01-06 02:02:32
Format profile                   : High@L4.1
Format settings, CABAC           : Yes
Format settings, ReFrames        : 8 frames
Codec ID                         : avc1
Codec ID/Info                    : Advanced Video Coding
Duration                         : 1h 58mn
Bit rate mode                    : Variable
Bit rate                         : 2 326 Kbps
Maximum bit rate                 : 15.4 Mbps
Width                            : 1 280 pixels
Height                           : 544 pixels
Display aspect ratio             : 2.35:1
Frame rate mode                  : Constant
Frame rate                       : 23.976 fps
Bits/(Pixel*Frame)               : 0.139
Stream size                      : 1.92 GiB (85%)
Title                            : HDLiTE
Writing library                  : x264 core 110 r1820 fdcf2ae
Encoding settings                : cabac=1 / ref=8 / deblock=1:1:-3 / analyse=0x3:0x113 / me=umh / subme=10 / psy=1 / psy_rd=1.01:0.01 / mixed_ref=1 / me_range=32 / chroma_me=1 / trellis=2 / 8x8dct=1 / cqm=0 / deadzone=21,11 / fast_pskip=0 / chroma_qp_offset=-3 / threads=6 / sliced_threads=0 / nr=0 / decimate=0 / interlaced=0 / constrained_intra=0 / bframes=5 / b_pyramid=2 / b_adapt=2 / b_bias=0 / direct=2 / weightb=1 / open_gop=0 / weightp=2 / keyint=250 / keyint_min=23 / scenecut=40 / intra_refresh=0 / rc_lookahead=50 / rc=2pass / mbtree=1 / bitrate=2326 / ratetol=1.5 / qcomp=0.60 / qpmin=10 / qpmax=51 / qpstep=4 / cplxblur=20.0 / qblur=0.5 / vbv_maxrate=40000 / vbv_bufsize=30000 / ip_ratio=1.40 / aq=2:0.90 / nal_hrd=none
Encoded date                     : UTC 2011-01-05 15:19:47
Tagged date                      : UTC 2011-01-06 02:05:38
Format                           : AAC
Format/Info                      : Advanced Audio Codec
Format profile                   : LC
Codec ID                         : 40
Duration                         : 1h 58mn
Bit rate                         : 397 Kbps
Maximum bit rate                 : 515 Kbps
Channel(s)                       : 6 channels
Channel positions                : Front: L C R, Side: L R, LFE
Stream size                      : 336 MiB (15%)
Language                         : English
Encoded date                     : UTC 2011-01-06 02:05:00
Post Wed Apr 27, 2011 2:27 am
File looks good to me, kinda big in size ut that shouldnt matter.
ZIP - any ideas ?
Post Wed Apr 27, 2011 7:15 am
Cerberus wrote:...any ideas ?
I think this is due to x264 encoding options used to encode this video, I mean "b_pyramid=2" is not supported, "b_pyramid=1" could be better.
But I must confess that x264 encoding options are quite obscure...
With search : search.php?st=0&sk=t&sd=d&sr=posts&keywords=b_pyramid%3D2
Post Wed Apr 27, 2011 9:01 am
Also, guys, for your info, in 0.6 I'm detecting profile differently. The value stored in the H264 header (as returned by MediaInfo) is not always 100% accurate - you can store whatever value there. Profile should be detected using ref_frame number with this formula (http://en.wikipedia.org/wiki/H.264/MPEG ... _buffering)
(width*height*ref_frames)/256 ... the result defines profile using the table in the link above.
For example this file: (1280 * 544 * 8) / 256 = 21760 .. so it actually is level 4.0 file
More on this also here: https://bitbucket.org/xnejp03/serviio/i ... de-profile
Post Wed Apr 27, 2011 9:15 am
zip wrote:Also, guys, for your info, in 0.6 I'm detecting profile differently. The value stored in the H264 header (as returned by MediaInfo) is not always 100% accurate - you can store whatever value there.
Yes, in fact, I suppose this is what is done by tools such as TsMuxer or H264LevelEditor to change the level.
Again, I prefer your method.
The profile level depends on device buffering capabilities.
Post Wed Apr 27, 2011 9:35 am
Will have to see whether it works across all devices, as for some it's enough to change the header value and they (usually) play. So we need to make sure a file with profile 5.0 in header but only 4 ref frames actually plays without transcoding (keep in mind for 0.6 testing ;-) )
swandive76
Post Wed Apr 27, 2011 3:14 pm
So sounds like a problem with how this file was encoded...Should I re-encode? I dont want to loose any quality.
As I mentioned It works when I select the Samsung A profile in Serviio. but then none of my avi files work. Is there a way I can combine the 2 profiles (A and B) to make everything work?
Post Wed Apr 27, 2011 3:24 pm
swandive76 wrote:As I mentioned It works when I select the Samsung A profile in Serviio. but then none of my avi files work.
With Samsung A profile selected, mp4(mov) files were transcoded into mpegts/mpeg2video/ac3, format supported by the TV.
swandive76 wrote:Is there a way I can combine the 2 profiles (A and B) to make everything work?
yes but all mp4 with h264 video will be transcoded
add <Matches container="mp4" vCodec="h264" /> into following section of the "Samsung TV (B-series)" profile
<Video targetContainer="mpegts" targetACodec="ac3" targetVCodec="mpeg2video">
    <Matches container="asf" vCodec="wmv2" />
    <Matches container="flv" />
swandive76
Post Wed Apr 27, 2011 3:39 pm
Thanks Illico
From the sounds of it 0.6 will handle this a bit better? Am I reading that correctly?
Post Wed Apr 27, 2011 3:46 pm
swandive76 wrote:From the sounds of it 0.6 will handle this a bit better? Am I reading that correctly?
Yes, we hope, keep in mind, we will test this in 0.6
Post Wed Apr 27, 2011 4:37 pm
Probably not in the case of this file as this file is a supported profile. It might be some other setting in the encoder, e.g. the one Illico pointed out - in which case you'll have to transcode.
