Serviio not sorting on Samsung Smart TV
mhinc
Post Wed Mar 01, 2023 9:35 pm
Hey all,
Couldn't find any info on this after searching. I've used Serviio flawlessly on my old Samsung BlueRay player for years. Recently picked up a new SAMSUNG 50" 4K HDR SMART 120MR LED TV - UN50TU7000FXZC
With the Tizen OS. Serviio pops right up. No connection issues at all. But it does not sort in the correct order.
Does anyone know what the reason is for this. Or if there is a way to correct it?
Post Wed Mar 01, 2023 10:25 pm
Re: Serviio not sorting on Samsung Smart TV
Samsung support for DLNA as declined over the years. Their user interface has never been all that great, and their media support is so-so. That said, I've never seen a sorting issue. The TV has always presented the media exactly the same way as the Serviio MediaBrowser. Can you provide an example of what you believe is not sorted correctly, so I know what you're seeing and what it should be?
