Option to turn off alphabet subfolders
hulala
Post Tue Apr 11, 2023 1:22 pm
Having just a few movies, I would prefer to see all my titles listed at once, skipping the alphabet subfolders. I see no such option in the "Presentation" settings. Is there any way to turn off these unnecessary alphabet subfolders in the XML settings file(s) or somehow/somewhere else? If not, please add this as a feature request for the next update (it has to be very easy to implement). Thank you.
Post Tue Apr 11, 2023 2:39 pm
Re: Option to turn off alphabet subfolders
No, under the Titles presentation you will have the alphanumeric subfolders. However, under the Movies presentation, you get a single list of all titles, with no subfolders. TV series will still be under a separate presentation view.
One other option is to use the Folders view. Once you select the specific folder (and if you only have a small library there's probably only one folder) all titles in that folder are displayed.
hulala
Post Tue Apr 11, 2023 3:01 pm
Excellent. Thank you!
Users browsing this forum: Baidu [Spider] and 60 guests
