Serviio in Ubuntu 22.04 to connect to LG TV 55QNED80
JesusRastaMzt
Post Thu Apr 13, 2023 11:20 pm
Hello everyone :D
I am New to Serviio but I have already installed it in a MacBookPro and its working fine with the mentioned LG TV
Now I wanna make a dedicated Media Server with and old Gateway laptop that I have, in which I installed Ubuntu 22.04 and Serviio Pro V2.3
in the Gateway computer running Ubuntu, The Serviio server I am controlling it from firefox in http://localost:23423/console/
it shows Running status and I CAN actually see the LG TV in the list of Connected Devices, it even has the little green Icon that if moused over it says "Active", but the TV just doesn't pick it up or recognize the Serviio running in my Ubuntu Gateway Laptop. When I run Serviio in my other laptop (MacOS) the TV picks it up immediately and works Perfectly.
I have no idea what I have done wrong, been reading alot and trying to resolve this issue, but I just can't :(
Last thing I read and tryed was to downgrade my openJDK from 11 to 8, that didn't fix it either :'(
PLEASE HELP!!! :(
Thanks soooo very much.
Post Fri Apr 14, 2023 2:29 pm
Re: Serviio in Ubuntu 22.04 to connect to LG TV 55QNED80
There's probably a firewall setting in your Linux install that is blocking the stream. You need both the TCP port 8895 and UDP 1900 port open for Serviio to work on your internal network. My guess is Serviio can see out (so it sees the TV) but the TV isn't seeing into the Serviio install.
JesusRastaMzt
Post Fri Apr 14, 2023 7:24 pm
DAN YOU ROCK!!!
that simply SOLVE THE ISSUE... you are THE BEST!!
thanks sooooooooo MUCH :D
Return to LG
