Issue Removing Old Drive Under The Shared Folders
sergioamtz
Post Tue May 09, 2023 3:05 pm
I am trying to remove an old drive i had with Music but everytime I try to remove it it gives me an error
"An Unexpected Error Ocurred (500). Check The Log"
I tried remoging the logs but still will not let me.
Can someone please help?
Thanks SAM
Post Wed May 10, 2023 12:14 am
Re: Issue Removing Old Drive Under The Shared Folders
What operating system are you using? It sounds like a permissions issue, but I wouldn't expect that with Windows. You might need to change to detailed logging and try again, then upload the log here for Zip to look at.
