These MKV files don't play on PS3
individual
Post Sun Apr 24, 2011 7:26 am
Following DEBUG instructions from another post, I collected the information regarding the following files. The files are correctly indexed to media library, but they don't play in PS3, giving "The data type is unsupported" error.
File 1:
Media Info
Unique ID                        : 196464359986102109260371442183145870048 (0x93CDA8CDCBFE7B8094082B8BD6B152E0)
Complete name                    : Z:\video\Movies\The Return of the King 2003 1080p\The Return of the King 1080p.mkv
Format                           : Matroska
File size                        : 15.3 GiB
Duration                         : 3h 21mn
Overall bit rate                 : 10.9 Mbps
Encoded date                     : UTC 2009-03-14 16:09:37
Writing application              : mkvmerge v3.2.0 ('Beginnings') built on Feb 12 2010 16:46:17
Writing library                  : libebml v0.7.9 + libmatroska v0.8.1
Format profile                   : High@L4.0
Format settings, CABAC           : Yes
Format settings, ReFrames        : 5 frames
Codec ID                         : V_MPEG4/ISO/AVC
Duration                         : 3h 21mn
Bit rate                         : 9 392 Kbps
Width                            : 1 920 pixels
Height                           : 800 pixels
Display aspect ratio             : 2.40:1
Frame rate                       : 23.976 fps
Bits/(Pixel*Frame)               : 0.255
Stream size                      : 12.9 GiB (84%)
Writing library                  : x264 core 89 r1471M 1144615
Encoding settings                : cabac=1 / ref=5 / deblock=1:0:0 / analyse=0x3:0x113 / me=umh / subme=7 / psy=1 / psy_rd=1.00:0.20 / mixed_ref=1 / me_range=16 / chroma_me=1 / trellis=1 / 8x8dct=1 / cqm=0 / deadzone=21,11 / fast_pskip=1 / chroma_qp_offset=-3 / threads=6 / sliced_threads=0 / nr=0 / decimate=1 / interlaced=0 / constrained_intra=0 / bframes=3 / b_pyramid=2 / b_adapt=1 / b_bias=0 / direct=3 / wpredb=1 / wpredp=0 / keyint=250 / keyint_min=25 / scenecut=40 / intra_refresh=0 / rc_lookahead=40 / rc=2pass / mbtree=1 / bitrate=9392 / ratetol=1.0 / qcomp=0.60 / qpmin=10 / qpmax=51 / qpstep=4 / cplxblur=20.0 / qblur=0.5 / ip_ratio=1.40 / aq=1:1.00 / pulldown=0
Language                         : English
Format                           : DTS
Format/Info                      : Digital Theater Systems
Format profile                   : ES
Codec ID                         : A_DTS
Duration                         : 3h 21mn
Bit rate                         : 1 510 Kbps
Channel(s)                       : 6 channels
Channel positions                : Front: L C R, Side: L R, LFE
Bit depth                        : 24 bits
Stream size                      : 2.12 GiB (14%)
Language                         : English
Text
Format                           : UTF-8
Codec ID                         : S_TEXT/UTF8
Codec ID/Info                    : UTF-8 Plain Text
Language                         : English
Menu
00:00:00.000                     : en:00:00:00.000
00:06:13.582                     : en:00:06:13.582
00:09:10.633                     : en:00:09:10.633
00:12:08.394                     : en:00:12:08.394
00:15:10.535                     : en:00:15:10.535
00:19:09.899                     : en:00:19:09.899
00:26:45.646                     : en:00:26:45.646
00:29:39.736                     : en:00:29:39.736
00:31:39.940                     : en:00:31:39.940
00:37:13.398                     : en:00:37:13.398
00:39:50.346                     : en:00:39:50.346
00:43:46.040                     : en:00:43:46.040
00:44:21.367                     : en:00:44:21.367
00:46:38.337                     : en:00:46:38.337
00:49:21.375                     : en:00:49:21.375
00:51:53.319                     : en:00:51:53.319
00:56:09.992                     : en:00:56:09.992
00:58:09.820                     : en:00:58:09.820
01:01:11.251                     : en:01:01:11.251
01:06:30.153                     : en:01:06:30.153
01:11:11.851                     : en:01:11:11.851
01:14:45.898                     : en:01:14:45.898
01:19:27.554                     : en:01:19:27.554
01:21:55.869                     : en:01:21:55.869
01:23:19.077                     : en:01:23:19.077
01:25:19.906                     : en:01:25:19.906
01:27:05.470                     : en:01:27:05.470
01:29:59.394                     : en:01:29:59.394
01:37:23.629                     : en:01:37:23.629
01:46:32.136                     : en:01:46:32.136
01:47:09.048                     : en:01:47:09.048
01:47:43.582                     : en:01:47:43.582
01:48:50.399                     : en:01:48:50.399
01:54:52.135                     : en:01:54:52.135
01:55:57.450                     : en:01:55:57.450
02:01:33.786                     : en:02:01:33.786
02:03:29.193                     : en:02:03:29.193
02:07:20.258                     : en:02:07:20.258
02:08:50.681                     : en:02:08:50.681
02:10:34.702                     : en:02:10:34.702
02:11:29.048                     : en:02:11:29.048
02:12:20.391                     : en:02:12:20.391
02:14:21.387                     : en:02:14:21.387
02:16:27.137                     : en:02:16:27.137
02:18:15.037                     : en:02:18:15.037
02:24:41.423                     : en:02:24:41.423
02:26:35.704                     : en:02:26:35.704
02:29:38.553                     : en:02:29:38.553
02:34:13.619                     : en:02:34:13.619
02:36:25.918                     : en:02:36:25.918
02:37:29.523                     : en:02:37:29.523
02:39:02.199                     : en:02:39:02.199
02:39:36.233                     : en:02:39:36.233
02:45:14.863                     : en:02:45:14.863
02:47:28.163                     : en:02:47:28.163
02:50:59.749                     : en:02:50:59.749
02:53:21.266                     : en:02:53:21.266
02:58:13.349                     : en:02:58:13.349
03:02:55.214                     : en:03:02:55.214
03:12:12.521                     : en:03:12:12.521
FFMPEG
BECONAS> ffmpeg -i "/volume1/video/Movies/The Return of the King 2003 1080p/The Return of the King 1080p.mkv" -y -vcodec copy -vbsf h264_mp4toannexb -copyts -acodec ac3 -ab
384k -ac 6 -map 0:0 -map 0:1 -sn -f mpegts /volume1/@tmp/Serviio/transcoding-temp-14-MPEG2TS.stf
  built on Apr  8 2011 17:16:26 with gcc 4.2.3
  configuration: --arch=arm --enable-armv5te --prefix=/opt --extra-cflags=-I/opt/include --extra-ldflags=-L/opt/lib --enable-static --disable-shared --disable-ffplay --disable-ffserver --enable-libmp3lame
  libavutil     50.36. 0 / 50.36. 0
  libavcore      0.16. 0 /  0.16. 0
  libavcodec    52.108. 0 / 52.108. 0
  libavformat   52.92. 0 / 52.92. 0
  libavdevice   52. 2. 3 / 52. 2. 3
  libavfilter    1.72. 0 /  1.72. 0
  libswscale     0.12. 0 /  0.12. 0
[matroska,webm @ 0xb8ecf0] max_analyze_duration reached
[matroska,webm @ 0xb8ecf0] Estimating duration from bitrate, this may be inaccurate
Seems stream 0 codec frame rate differs from container frame rate: 47.95 (48000/1001) -> 23.98 (48000/2002)
Input #0, matroska,webm, from '/volume1/video/Movies/The Return of the King 2003 1080p/The Return of the King 1080p.mkv':
  Duration: 03:21:02.04, start: 0.000000, bitrate: 1536 kb/s
    Chapter #0.0: start 0.000000, end 373.582000
      title           : 00:00:00.000
    Chapter #0.1: start 373.582000, end 550.633000
      title           : 00:06:13.582
    Chapter #0.2: start 550.633000, end 728.394000
      title           : 00:09:10.633
    Chapter #0.3: start 728.394000, end 910.535000
      title           : 00:12:08.394
    Chapter #0.4: start 910.535000, end 1149.899000
      title           : 00:15:10.535
    Chapter #0.5: start 1149.899000, end 1605.646000
      title           : 00:19:09.899
    Chapter #0.6: start 1605.646000, end 1779.736000
      title           : 00:26:45.646
    Chapter #0.7: start 1779.736000, end 1899.940000
      title           : 00:29:39.736
    Chapter #0.8: start 1899.940000, end 2233.398000
      title           : 00:31:39.940
    Chapter #0.9: start 2233.398000, end 2390.346000
      title           : 00:37:13.398
    Chapter #0.10: start 2390.346000, end 2626.040000
      title           : 00:39:50.346
    Chapter #0.11: start 2626.040000, end 2661.367000
      title           : 00:43:46.040
    Chapter #0.12: start 2661.367000, end 2798.337000
      title           : 00:44:21.367
    Chapter #0.13: start 2798.337000, end 2961.375000
      title           : 00:46:38.337
    Chapter #0.14: start 2961.375000, end 3113.319000
      title           : 00:49:21.375
    Chapter #0.15: start 3113.319000, end 3369.992000
      title           : 00:51:53.319
    Chapter #0.16: start 3369.992000, end 3489.820000
      title           : 00:56:09.992
    Chapter #0.17: start 3489.820000, end 3671.251000
      title           : 00:58:09.820
    Chapter #0.18: start 3671.251000, end 3990.153000
      title           : 01:01:11.251
    Chapter #0.19: start 3990.153000, end 4271.851000
      title           : 01:06:30.153
    Chapter #0.20: start 4271.851000, end 4485.898000
      title           : 01:11:11.851
    Chapter #0.21: start 4485.898000, end 4767.554000
      title           : 01:14:45.898
    Chapter #0.22: start 4767.554000, end 4915.869000
      title           : 01:19:27.554
    Chapter #0.23: start 4915.869000, end 4999.077000
      title           : 01:21:55.869
    Chapter #0.24: start 4999.077000, end 5119.906000
      title           : 01:23:19.077
    Chapter #0.25: start 5119.906000, end 5225.470000
      title           : 01:25:19.906
    Chapter #0.26: start 5225.470000, end 5399.394000
      title           : 01:27:05.470
    Chapter #0.27: start 5399.394000, end 5843.629000
      title           : 01:29:59.394
    Chapter #0.28: start 5843.629000, end 6392.136000
      title           : 01:37:23.629
    Chapter #0.29: start 6392.136000, end 6429.048000
      title           : 01:46:32.136
    Chapter #0.30: start 6429.048000, end 6463.582000
      title           : 01:47:09.048
    Chapter #0.31: start 6463.582000, end 6530.399000
      title           : 01:47:43.582
    Chapter #0.32: start 6530.399000, end 6892.135000
      title           : 01:48:50.399
    Chapter #0.33: start 6892.135000, end 6957.450000
      title           : 01:54:52.135
    Chapter #0.34: start 6957.450000, end 7293.786000
      title           : 01:55:57.450
    Chapter #0.35: start 7293.786000, end 7409.193000
      title           : 02:01:33.786
    Chapter #0.36: start 7409.193000, end 7640.258000
      title           : 02:03:29.193
    Chapter #0.37: start 7640.258000, end 7730.681000
      title           : 02:07:20.258
    Chapter #0.38: start 7730.681000, end 7834.702000
      title           : 02:08:50.681
    Chapter #0.39: start 7834.702000, end 7889.048000
      title           : 02:10:34.702
    Chapter #0.40: start 7889.048000, end 7940.391000
      title           : 02:11:29.048
    Chapter #0.41: start 7940.391000, end 8061.387000
      title           : 02:12:20.391
    Chapter #0.42: start 8061.387000, end 8187.137000
      title           : 02:14:21.387
    Chapter #0.43: start 8187.137000, end 8295.037000
      title           : 02:16:27.137
    Chapter #0.44: start 8295.037000, end 8681.423000
      title           : 02:18:15.037
    Chapter #0.45: start 8681.423000, end 8795.704000
      title           : 02:24:41.423
    Chapter #0.46: start 8795.704000, end 8978.553000
      title           : 02:26:35.704
    Chapter #0.47: start 8978.553000, end 9253.619000
      title           : 02:29:38.553
    Chapter #0.48: start 9253.619000, end 9385.918000
      title           : 02:34:13.619
    Chapter #0.49: start 9385.918000, end 9449.523000
      title           : 02:36:25.918
    Chapter #0.50: start 9449.523000, end 9542.199000
      title           : 02:37:29.523
    Chapter #0.51: start 9542.199000, end 9576.233000
      title           : 02:39:02.199
    Chapter #0.52: start 9576.233000, end 9914.863000
      title           : 02:39:36.233
    Chapter #0.53: start 9914.863000, end 10048.163000
      title           : 02:45:14.863
    Chapter #0.54: start 10048.163000, end 10259.749000
      title           : 02:47:28.163
    Chapter #0.55: start 10259.749000, end 10401.266000
      title           : 02:50:59.749
    Chapter #0.56: start 10401.266000, end 10693.349000
      title           : 02:53:21.266
    Chapter #0.57: start 10693.349000, end 10975.214000
      title           : 02:58:13.349
    Chapter #0.58: start 10975.214000, end 11532.521000
      title           : 03:02:55.214
    Chapter #0.59: start 11532.521000, end 12062.048000
      title           : 03:12:12.521
    Stream #0.0(eng): Video: h264, yuv420p, 1920x800, PAR 1:1 DAR 12:5, 23.98 fps, 23.98 tbr, 1k tbn, 47.95 tbc
    Stream #0.1(eng): Audio: dca, 48000 Hz, 5.1, s16, 1536 kb/s
    Stream #0.2(eng): Subtitle: [0][0][0][0] / 0x0000
[mpegts @ 0xbb0010] muxrate VBR, pcr every 100 pkts, sdt every 200, pat/pmt every 40 pkts
Output #0, mpegts, to '/volume1/@tmp/Serviio/transcoding-temp-14-MPEG2TS.stf':
    encoder         : Lavf52.92.0
    Stream #0.0(eng): Video: [0][0][0][0] / 0x0000, yuv420p, 1920x800 [PAR 1:1 DAR 12:5], q=2-31, 90k tbn, 1k tbc
    Stream #0.1(eng): Audio: ac3, 48000 Hz, 5.1, flt, 384 kb/s
Stream mapping:
  Stream #0.0 -> #0.0
  Stream #0.1 -> #0.1
Press [q] to stop encoding
frame=  360 fps= 25 q=-1.0 Lsize=   12349kB time=14.89 bitrate=6793.7kbits/s
video:10650kB audio:708kB global headers:0kB muxing overhead 8.726039%
File 2:
Media Info
Unique ID                        : 208964331178908593381509111080240099157 (0x9D3510F73E3F599785DFDC466D612F55)
Complete name                    : Z:\video\Movies\Rabbit Hole 2010 1080p\Rabbit Hole 2010.mkv
Format                           : Matroska
File size                        : 6.97 GiB
Duration                         : 1h 31mn
Movie name                       : Rabbit.Hole.(2010).1080P.X264.NL.SUBBED.Bradje
Encoded date                     : UTC 2011-04-16 11:04:41
Writing application              : mkvmerge v3.3.0 ('Language') built on Mar 24 2010 14:59:24
Writing library                  : libebml v0.8.0 + libmatroska v0.9.0
Format profile                   : High@L4.1
Format settings, ReFrames        : 4 frames
Duration                         : 1h 31mn
Bit rate                         : 8 756 Kbps
Height                           : 1 080 pixels
Bits/(Pixel*Frame)               : 0.176
Stream size                      : 5.46 GiB (78%)
Title                            : Rabbit.Hole.(2010).1080P.X264.NL.SUBBED.Bradje
Writing library                  : x264 core 115 r1936 7a9e08d
Encoding settings                : cabac=1 / ref=4 / deblock=1:0:0 / analyse=0x3:0x113 / me=umh / subme=8 / psy=1 / psy_rd=1.00:0.00 / mixed_ref=1 / me_range=16 / chroma_me=1 / trellis=1 / 8x8dct=1 / cqm=0 / deadzone=21,11 / fast_pskip=1 / chroma_qp_offset=-2 / threads=12 / sliced_threads=0 / nr=0 / decimate=1 / interlaced=0 / bluray_compat=0 / constrained_intra=0 / bframes=3 / b_pyramid=2 / b_adapt=2 / b_bias=0 / direct=3 / weightb=1 / open_gop=0 / weightp=2 / keyint=240 / keyint_min=24 / scenecut=40 / intra_refresh=0 / rc_lookahead=50 / rc=2pass / mbtree=1 / bitrate=8756 / ratetol=1.0 / qcomp=0.60 / qpmin=0 / qpmax=69 / qpstep=4 / cplxblur=20.0 / qblur=0.5 / ip_ratio=1.40 / aq=1:1.00
Language                         : English
Audio #1
Format                           : AC-3
Format/Info                      : Audio Coding 3
Mode extension                   : CM (complete main)
Codec ID                         : A_AC3
Duration                         : 1h 31mn
Bit rate                         : 640 Kbps
Bit depth                        : 16 bits
Stream size                      : 419 MiB (6%)
Title                            : AC3
Language                         : English
Audio #2
Format                           : DTS
Codec ID                         : A_DTS
Duration                         : 1h 31mn
Bit depth                        : 24 bits
Delay relative to video          : 11ms
Stream size                      : 988 MiB (14%)
Title                            : DTS
Language                         : English
Text #1
Format                           : UTF-8
Title                            : Subtitles
Language                         : Dutch
Text #2
Format                           : UTF-8
Title                            : Subtitles
Language                         : English
Menu
00:04:13.837                     : en:00:04:13.837
00:07:42.295                     : en:00:07:42.295
00:11:24.767                     : en:00:11:24.767
00:19:34.924                     : en:00:19:34.924
00:24:58.288                     : en:00:24:58.288
00:34:38.910                     : en:00:34:38.910
00:39:10.431                     : en:00:39:10.431
00:43:45.915                     : en:00:43:45.915
00:49:49.153                     : en:00:49:49.153
00:57:16.099                     : en:00:57:16.099
01:04:46.549                     : en:01:04:46.549
01:09:04.432                     : en:01:09:04.432
01:14:28.172                     : en:01:14:28.172
01:21:16.580                     : en:01:21:16.580
01:24:59.803                     : en:01:24:59.803
FFMPEG
ffmpeg -i "/volume1/video/Movies/Rabbit Hole 2010 1080p/Rabbit Hole 2010.mkv" -y -vcodec copy -vbsf h264_mp4toannexb -copyts -acodec ac3 -ab 384k -ac 6 -map 0:0 -ma
Input #0, matroska,webm, from '/volume1/video/Movies/Rabbit Hole 2010 1080p/Rabbit Hole 2010.mkv':
    title           : Rabbit.Hole.(2010).1080P.X264.NL.SUBBED.Bradje
  Duration: 01:31:28.54, start: 0.000000, bitrate: 2176 kb/s
    Chapter #0.0: start 0.000000, end 253.837000
    Chapter #0.1: start 253.837000, end 462.295000
      title           : 00:04:13.837
    Chapter #0.2: start 462.295000, end 684.767000
      title           : 00:07:42.295
    Chapter #0.3: start 684.767000, end 1174.924000
      title           : 00:11:24.767
    Chapter #0.4: start 1174.924000, end 1498.288000
      title           : 00:19:34.924
    Chapter #0.5: start 1498.288000, end 2078.910000
      title           : 00:24:58.288
    Chapter #0.6: start 2078.910000, end 2350.431000
      title           : 00:34:38.910
    Chapter #0.7: start 2350.431000, end 2625.915000
      title           : 00:39:10.431
    Chapter #0.8: start 2625.915000, end 2989.153000
      title           : 00:43:45.915
    Chapter #0.9: start 2989.153000, end 3436.099000
      title           : 00:49:49.153
    Chapter #0.10: start 3436.099000, end 3886.549000
      title           : 00:57:16.099
    Chapter #0.11: start 3886.549000, end 4144.432000
      title           : 01:04:46.549
    Chapter #0.12: start 4144.432000, end 4468.172000
      title           : 01:09:04.432
    Chapter #0.13: start 4468.172000, end 4876.580000
      title           : 01:14:28.172
    Chapter #0.14: start 4876.580000, end 5099.803000
      title           : 01:21:16.580
    Chapter #0.15: start 5099.803000, end 5488.544000
      title           : 01:24:59.803
    Stream #0.0(eng): Video: h264, yuv420p, 1920x1080, PAR 1:1 DAR 16:9, 23.98 fps, 23.98 tbr, 1k tbn, 47.95 tbc
    Stream #0.1(eng): Audio: ac3, 48000 Hz, 5.1, s16, 640 kb/s
      title           : AC3
    Stream #0.2(eng): Audio: dca, 48000 Hz, 5.1, s16, 1536 kb/s
      title           : DTS
    Stream #0.3(dut): Subtitle: [0][0][0][0] / 0x0000
      title           : Subtitles
    Stream #0.4(eng): Subtitle: [0][0][0][0] / 0x0000
      title           : Subtitles
[mpegts @ 0xba6030] muxrate VBR, pcr every 100 pkts, sdt every 200, pat/pmt every 40 pkts
    Stream #0.0(eng): Video: [0][0][0][0] / 0x0000, yuv420p, 1920x1080 [PAR 1:1 DAR 16:9], q=2-31, 90k tbn, 1k tbc
      title           : AC3
Stream mapping:
  Stream #0.0 -> #0.0
  Stream #0.1 -> #0.1
frame=  279 fps= 15 q=-1.0 Lsize=   15753kB time=11.51 bitrate=11209.1kbits/s
video:13990kB audio:550kB global headers:0kB muxing overhead 8.341480%
NAS: DS712+, 2x Seagate ST2000DL003
DLNA Server: Synology, Serviio, Twonky, Plex
DLNA Player: Raspberry Pi Raspbmc
DLNA Tablet: Yatse
patters
Post Sun Apr 24, 2011 9:40 am
Re: These MKV files don't play on PS3
At a guess I think it could be the DTS audio track that's upsetting FFmpeg, even though it's the second audio track in the file. Have you tried remuxing with TSMuxer (taking only the AC3 track) then re-adding to the library?
individual
Post Sun Apr 24, 2011 12:12 pm
patters wrote:At a guess I think it could be the DTS audio track that's upsetting FFmpeg, even though it's the second audio track in the file. Have you tried remuxing with TSMuxer (taking only the AC3 track) then re-adding to the library?
No, i didn't tried that. The files are huge and the pc i have is quite old...
DLNA Tablet: Yatse
individual
Post Wed Apr 27, 2011 8:58 am
Can't the Playstation profile be ammended so that it could chose which audio stream type should be extract, regardless what is available in the container?
DLNA Tablet: Yatse
Post Wed Apr 27, 2011 3:39 pm
individual wrote:Can't the Playstation profile be ammended so that it could chose which audio stream type should be extract, regardless what is available in the container?
no you cant choose currently what audio track is selected.
patters
Post Wed Apr 27, 2011 9:07 pm
A remux using TSMuxer is fast since it's only changing the container for the audio and video streams (which are not modified during the process). My old 2003 Dell PC can do a 4GB movie in a couple of minutes, even on an external USB hard disk.
individual
Post Thu Apr 28, 2011 6:43 am
@patters : I tried to remux into m2ts the 15Gb mkv file, but the process was done outside the NAS through the network, of course, and after one hour the process stopped at 78% saying that the disk is full, which is not the case since the NAS has over 1.4 TB free... The m2ts was saved to the NAS over the network and it plays through PS3 but it has no sound (it shows no audio; maybe the audio wasn't saved due to that error; and the file size is 12GB, so it might not have audio)
This Playstation 3 renderer is giving me headaches. I consider more and more to buy a simple HD media player that can handle everything.
DLNA Tablet: Yatse
