ServiiGo no longer working
Sargon
Post Fri Jan 26, 2024 3:29 pm
I use ServiiGo on multiple Android devices and it has stopped working on all my devices sometime in the last few months. I am getting an error message that says "Failed to open connection to the server". Nothing has changed on my server and MediaBrowser still connects as normal from all devices. Does anyone else use ServiiGo and have you experienced any problems? Any suggestions on how to get it working again?
Post Fri Jan 26, 2024 3:45 pm
Re: ServiiGo no longer working
I moved this thread into the proper location in the forum. ServiiGo is a 3rd party product, and all support is provided by the developer, not Serviio. Forum user Will is the developer of ServiiGo, and you need to contact him for support. I don't know if ServiiGo has any contact information in the app itself, but here's the link for ServiiGo on this forum: viewtopic.php?f=17&t=6803
Sargon
Post Fri Jan 26, 2024 8:51 pm
I got it fixed. Somehow all my port forwarding settings got wiped out on my router. I should have checked that first, but I knew they were setup before so I had no reason to think they would have randomly disappeared.
Post Fri Jan 26, 2024 8:55 pm
Yep, that would do it :) Glad you have it working again.
