jpg photo problem
Bobbi
Post Sun Apr 24, 2011 12:31 am
jpg photo problem
Hi
My english is not very good but i hope you will understand me
My problem is...Some of my jpg cant load it. I see only the thumbnails.
Some of my photos can load it and some cant load it
Why?
Can everbody help me?
Post Sun Apr 24, 2011 1:15 am
Re: jpg photo problem
post the information on the files. they might be too big for the DLNA standards and might need to be transcoded.
look at this post
http://forum.serviio.org/viewtopic.php?f=12&t=2140&p=13184&hilit=resolution#p13184
Bobbi
Post Sun Apr 24, 2011 8:01 am
Hello moltra
its a jpg file
27,7 KB (28.454 Bytes)
418x600
96 dpi
patters
Post Sun Apr 24, 2011 9:37 am
Can you run ffmpeg -i on the JPEG file from the command prompt. FFmpeg is in Serviio's lib folder. Perhaps the JPEG is progressive encoded or something.
Bobbi
Post Mon Apr 25, 2011 12:28 am
i dont know
how can see it?
And what it the ffmpeg? how can rum it? with cmd maybe?
Sorry for my bad english
Post Mon Apr 25, 2011 11:31 am
Bobbi
Post Mon Apr 25, 2011 1:33 pm
Thank you
But in dont now how open/start the ffmpeg
When i try to click on ffmpeg.ext ....nothing do it
doesn't open ffmpeg ...will not start :-(
Bobbi
Post Wed Apr 27, 2011 4:59 am
Please help me
How can start ffmpeg
When i try to click on the ffmpeg icon doesnt work
Post Wed Apr 27, 2011 5:14 am
Bobbi wrote:Please help me
Follow the information here - viewtopic.php?f=5&t=1123
Bobbi
Post Wed Apr 27, 2011 11:28 am
Thx
But where?
In CMD?
Post Wed Apr 27, 2011 12:21 pm
Bobbi
Post Wed Apr 27, 2011 12:29 pm
Thank you for your help Illico
You are the best :-)
Im absolute beginner :)
Post Wed Apr 27, 2011 3:36 pm
Bobbi wrote:Thx
But where?
In CMD?
yes
Bobbi
Post Wed Apr 27, 2011 9:45 pm
Ok
and how can load progresive jpg?
Post Thu Apr 28, 2011 6:42 am
We need to verify some information about your JPEG file.
So could you provide (see my previous link) the "ffmpeg -i" result of your file ?
Or post me "private message" with your JPEG file in attachment
Bobbi
Post Thu Apr 28, 2011 10:45 pm
Duration: 00:00:00.04, start: 0.000000, bitrate: N/A
Stream #0.0: Video: mjpeg, yuvj420p, 418x600 [PAR 1:1 DAR 209:300], 25 tbr,
25 tbn, 25 tbc
Post Fri Apr 29, 2011 6:35 am
This is not a JPEG photo, this is a video stream (motionJPEG).
To see this file (VIDEO), you need to select the proper section (VIDEO) into Sony XMB menu.
To see photos, you need to select the proper section (PHOTO) into Sony XMB menu.
Bobbi
Post Fri Apr 29, 2011 11:55 am
But i cant open it with Serviio when i select in PHOTO this pic :-(
MenU>Photo>My Folder>My Picture>i see the thumnails from pic> cant open it
Post Fri Apr 29, 2011 12:04 pm
Bobbi wrote:But i cant open it with Serviio when i select in PHOTO this pic :-(
Yes, normal, this "pic" is not a picture but a movie (mjpeg mean MOTION jpeg) so must be open from the VIDEO folder menu in the Sony XMB menu. Could you check this?
Menu>Video>My Folder>My Picture>
One the FAQ section of this topic you can read that:
FAQ
- Make sure you are browsing the proper section of the Sony XMB (press Home then left several times).
The Serviio audio, image and video folders will all show up in each category due to how DLNA servers work - it's just the Sony that insists on having a menu for each category.
Bobbi
Post Fri Apr 29, 2011 7:44 pm
Ok i have try it
But when i go to
Menu>Video>My Folder>My Pictute> Folder is Emty
