profiles.xml location on QNAP TS-453BT3
Mersing
Post Wed Aug 21, 2024 6:03 am
I have installed Serviio 2.4 on QNAP TS-453BT3 NAS.
Everything is working fine.
I would like to access the profiles.xml file to update the FriendlyName.
Where can I find the profiles.xml file on the TS-453BT3 ?
As per https://serviio.org/index.php?option=co ... icle&id=16
Profiles definition is stored in file config/profiles.xml in the Serviio installation directory
Where is Serviio installed
Serviio is installed, by default, in these locations
Windows - c:\Program Files\Serviio
OSX - /Library/Application Support/Serviio
What is the path on QNAP TS-453BT3 ?
I had a look on /etc/config.
But no profiles.xml file here.
I also tried /share/CACHEDEV5_DATA/.qpkg/Serviio/config and /share/CACHEDEV8_DATA/.qpkg/Serviio/config. But .qpkg folder does not exist
Thank you,
Mersing.
Meelis
Post Wed Aug 21, 2024 2:03 pm
Re: profiles.xml location on QNAP TS-453BT3
Maybe this will explain it.
viewtopic.php?f=1&t=30791
