does not show console contents on MacOS Sonoma 14.7
hellzone
Post Thu Sep 19, 2024 12:45 pm
Hello. I have MacOS SSonoma 14.6.1 on Apple M2. Serviio 2.2.1 CR2 suddenly when I start the console instead of content there is just an empty white square, nothing can be configured or added. Reinstallation does not help. What happened and how can I fix it. It worked without problems for a very long time. I am very upset. What should I do?after repeatedly deleting the program, manually deleting it from the library and reinstalling it, the console started and worked for 3 weeks. today after updating to Sonoma 14.7, everything happened again, the console is just empty. while the console works in the browser. how to solve the problem and make the program work?
Post Thu Sep 19, 2024 1:22 pm
Re: does not show console contents on MacOS Sonoma 14.7
When console issues have occurred in the past, clearing the browser cache will usually fix it. This has usually only happened when upgrading to a new version of Serviio, but I could see it happening with an OS update as well. The most recent version currently available is 2.4. It's possible that your older version of Serviio might not be playing nicely with the latest MacOS version. I'm not knowledgeable of the MacOS, so can't offer anything else there.
hellzone
Post Fri Sep 20, 2024 5:27 am
Hello! The thing is that I have the latest version 2.4. Before that, on the previous version of Sonoma, there were also such problems with display, but then everything was fixed. The console is displayed normally in the browser. Some kind of trouble. I reinstalled the program several times and the result is always the same.
