LULU block Serviio
needserviio
Post Tue Sep 24, 2024 7:18 pm
LULU block Serviio
Hello everyone,
I start using LULU a firewall for Mac (i needed it ;-), but even if i allowed the connection my sumsung still didnt see serviio... unless i disable then enabled again LULU... so it works.
shuld i insert the port used by? if this the case what port serviio use?
whats is "remote addres/domain"... can bu usefull?
Thanks...
Schermata 2024-09-24 alle 21.11.34.png (81.75 KiB) Viewed 14144 times
Post Tue Sep 24, 2024 10:42 pm
Re: LULU block Serviio
You need port 1900 UDP open, and port 23423 for accessing the Serviio console from a different computer on your network. I don't think you need anything else open on the Serviio computer, but then I don't run a firewall on my servers so can't say for certain if any others need to be opened.
Remote access is generally used for a firewall on the Internet connection to permit connections outside (i.e. from a computer on the Internet) for accessing the content. This would be needed if you have a paid version of Serviio and want to access MediaBrowser when you are not on your home network. But again, that is for your Internet firewall, and I can't say for certain if it would also need to be opened on your specific computer running Serviio. I think it might, but that's a more complicated discussion about routing.
I just had to scroll your image and now I realize what it's for. This is for access to the Serviio console from a different computer on your network as I mentioned above. The splat (*) is telling the firewall that any computer can connect. If you wanted to restrict what computer could access the Serviio console, you could restrict it via an IP address here.
needserviio
Post Wed Sep 25, 2024 6:06 pm
Thanks for the reply.
It's really bizarre that my tv didn't see Serviio until i disable LULU, and, after start seeing Serviio, enable the firewall again and my tv keep seeing Serviio and working properly... port seems dont do anything...
Post Wed Sep 25, 2024 6:16 pm
Just a guess on my part, but maybe LULU recognized Serviio running when it was restarted and permitted access. I know zilch about LULU, but maybe it's smart enough for that.
needserviio
Post Wed Sep 25, 2024 6:29 pm
I don't know either, could be... thanks again
Return to General discussion
