Post Wed Jan 08, 2025 8:30 am
Please support easier editing of online sources
I imported the list of internet radio radio stations that Paul published under Audio Streams.
And then I realised I couldn't live with a list of mostly uninteresting stations. And tried to reduce it.
Oh dear! Not very straightforward at all!
What is needed is, as a minimum, an easy way to start afresh with an empty online source config. Then you could export, clear all, edit the .sob file and import the edited version.
Or else one might add a way to do bulk editing. Like select a number of entries and do an operation on all selected entries. Operations should then at least be "Remove Selected Items" and "Export selected items to a.sob" and possibly a few more.
