Suddenly the console port seems unavailable
n3mmr
Post Wed Feb 19, 2025 3:37 pm
I have my Serviio 2.3 running in a jail under TrueNAS Core 13.3.
The jail has the address <home-network>.199
IP scanners find the serviio jail and my media players can play stuff from the serviio dlna.
However, when I try to connect to "<home-network>.199:23523/console" with my browser, the connection times out. Same for the mediabrowser.
I need ideas on what might prevent reaching the console.
Post Wed Feb 19, 2025 8:31 pm
Re: Suddenly the console port seems unavailable
Just to confirm: this sandboxed place you run Serviio, the URL uses the .199, but not as a port? I could see your internal DNS have trouble resolving a URL that is using a number as the root of the network name. I don't know if that's something you've done intentionally, or if the system you're using did that by default. I could see the DLNA still functioning despite the naming, since it's using UDP and uPNP to discover the services. But I just have a hunch (with nothing to back it up) that your network name is the issue.
n3mmr
Post Thu Feb 20, 2025 8:45 am
atc98092 wrote:Just to confirm: this sandboxed place you run Serviio, the URL uses the .199, but not as a port? I could see your internal DNS have trouble resolving a URL that is using a number as the root of the network name. I don't know if that's something you've done intentionally, or if the system you're using did that by default. I could see the DLNA still functioning despite the naming, since it's using UDP and uPNP to discover the services. But I just have a hunch (with nothing to back it up) that your network name is the issue.
using the DNS resolver to give the jail a name I tried https://serviio2.rhg097:23523/console and got the same failure exactly.
I've had this serviio in that jail since 2.3 came out and the FreeBSD crowd hacked up a "port" that I found in freshports.org, which is the FreeBSD way to add non-BSD SW to the commonality.
The console has worked flawlessly in the manner described in my OP since I installed that jail, until a few days ago.
n3mmr
Post Thu Feb 20, 2025 11:54 am
I got ssh running so I could run stuff in a better terminal window.
And I tried this inside the Serviio2 jail:
[hans@Serviio2 ~]$ wget https://localhost:23523/console
--2025-02-20 12:51:34--  https://localhost:23523/console
Resolving localhost (localhost)... ::1, 127.0.0.1
Connecting to localhost (localhost)|::1|:23523... failed: Connection refused.
Connecting to localhost (localhost)|127.0.0.1|:23523... failed: Connection refused.
So, nobody seems to be listening! Huh?????? What the f....!
n3mmr
Post Thu Feb 20, 2025 1:17 pm
The port is 23423 for unsecure connection!
Gaah!
Post Fri Feb 21, 2025 4:26 am
Yes, 23423 is a standard port, while 23523 requires a security certificate of some sort installed on the machine with a FQDN that matches the machine. Beyond that, I'm outside my knowledge area with sandboxed or jailed apps. Hopefully someone else can step up here with some ideas.
n3mmr
Post Mon Feb 24, 2025 3:11 pm
n3mmr wrote:The port is 23423 for unsecure connection!
Gaah!
And it now works.
Users browsing this forum: Baidu [Spider] and 25 guests
