File scan problem
Ramses2
Post Mon Jun 09, 2025 8:38 am
File scan problem
Hello, I'm using version 2.3, and for the past week, the folder scan hasn't been completed.
I have 65 files in a folder, but the scan often gets stuck at 14, then 15. I never see my 65 files. I uninstalled this version and reinstalled it, and nothing changed.
Any ideas about my problem?
Post Mon Jun 09, 2025 8:58 pm
Re: File scan problem
First thing to check is your Serviio log and see if a specific file is tripping it up. I have seen that happen on rare occasions where something in the file doesn't register correctly. I don't think detailed logging is needed for that, but it's possible.
Ramses2
Post Tue Jun 10, 2025 4:49 am
I have enabled debug mode, but I can't find the serviio.log file. I am using Monterey.
Post Tue Jun 10, 2025 2:15 pm
I’m unfamiliar with where it installs on the MacOS, but when you find the install location there will be a folder called logs. The most recent log file is named “serviio.log”.
Ramses2
Post Tue Jun 10, 2025 2:36 pm
The debug mode is enabled.
<Loggers>
<!-- <Logger name="org.serviio" level="info" /> -->
<Logger name="org.serviio" level="debug" />
I scan all my HDD and don't found "serviio.log"
Users browsing this forum: Google [Bot] and 27 guests
