Resume video
TangoFoxtrot
Post Fri Nov 14, 2025 1:29 pm
Resume video
I got a Samsung QE43QN90DATXXU last October and it has been pretty much flawless with Serviio, the TV did a firmware update and now no video will resume, I was using the N profile and I have tried a couple of others and it is still the same, the NU profile starts every video at 55mins which is really odd.
Any ideas how to get the video resume back without shelling out for another media box to plugin?
Post Sat Nov 15, 2025 12:37 am
Re: Resume video
My honest suggestion is to get a Fire TV or even an inexpensive Android based media player and forget the Samsung player. The user interface is terrible (and always has been). I wrote the JU profile more than 10 years ago and the NU profile about 4 years ago (no longer have either TV). You can get Android based players for as low as $25.
The Samsung player UI is completely lacking any information about the media other than the title and the image art, file size and maybe playing time (going from memory here). Even a basic Android player using Kodi as the media player app provides far more info, larger images, and can play far more media without requiring transcoding than the Samsung player can.
My complaints about the Samsung UI is the same for LG, Panasonic, and most other Smart TVs. It's not specifically a Samsung problem. I've never owned a TV with the Android/Google TV interface, so I can't say for certain how good/bad they might be.
TangoFoxtrot
Post Fri Nov 21, 2025 11:56 pm
Re: Resume video
The interface and player were functional enough for my needs and the box serviio runs on has power to spare to transcode if needed, I guess another box and another remote might just have to be the way forward for the sake of getting the feature back.
tmehanna
Post Sat Dec 20, 2025 4:59 pm
Re: Resume video
TangoFoxtrot wrote:I got a Samsung QE43QN90DATXXU last October and it has been pretty much flawless with Serviio, the TV did a firmware update and now no video will resume, I was using the N profile and I have tried a couple of others and it is still the same, the NU profile starts every video at 55mins which is really odd.
Same thing with my S95D since it got updated to the One UI firmware, except all my files now start at 4:40. Any luck so far?
Manala
Post Sat Dec 27, 2025 3:36 pm
Re: Resume video
Same problem here with 80D in my living room. Last FW update broke the resume function. This is frustrating because I have two Samsung TV's, both using the NU-profile and I could watch something from either one of them and then resume the movie on the other one. This was especially great late at night to resume the movie in bedroom when going to bed.
Manala
Post Mon May 04, 2026 10:10 am
Re: Resume video
Fortunately this issue seems to have been fixed now on the newest firmware (2123).
Brentiu
Post Mon May 25, 2026 4:34 am
Re: Resume video
TangoFoxtrot wrote:I got a Samsung QE43QN90DATXXU last October and it has been pretty much flawless with Serviio, the TV did a firmware update and now no video will resume, I was using the N profile and I have tried a couple of others and it is still the same, fnf the NU profile starts every video at 55mins which is really odd.
Good to know firmware 2123 finally fixed it. The weird random resume times definitely sounded more like a Samsung firmware bug than a Serviio profile problem.
fegike
Post Fri Oct 09, 2026 12:00 pm
Re: Resume video
Sounds like the firmware update may have changed how the Samsung TV handles playback resume with Serviio. Since the N profile worked before, I'd try switching back to it and restarting both the TV and the Serviio server, just to rule out a cached setting. Also, check whether the issue happens with every video or only certain file formats. The NU profile starting everything at 55 minutes is especially strange, so I wouldn't stick with that one. Hopefully someone with the same TV firmware can confirm whether there's a profile workaround.
