Console security risk
Is there any way to restrict the console to a specified user name and password?
Thanks for any assistance.
Shangri La wrote: Also, if you're running it from your laptop and you go out and use a public network, you don't want random strangers being able to browse and access your filesystem.
Shangri La wrote:I'm sorry, but that's simply not true. While it's very common to have client isolation, it can't be assumed. Even if the wireless access point has a function for that, it's not always configured that way. Where I live at least, there are many small cafés, a library, and other places where you see a list of other peoples' computers with their Windows file sharing names. Any guide to how to stay safe on public WiFi mentions turning off your file sharing. I don't know how it is with Serviio on Windows, but on a Mac, that involves entering "sudo" commands in the terminal, which is not very convenient.
Shangri La wrote:
Does Windows automatically block Serviio when it joins a public network? If so, that's a nice feature, too bad the Mac doesn't have it. A Mac on a network without peer isolation would have the console accessible to anyone on the network, unless you manually change the firewall settings or disable the server in the Terminal.
Users browsing this forum: Google [Bot] and 24 guests
