2.5 update on Mac Intel, now stop working
Hello
first, is it normal thats say Serviio-Console-Wrapper?
i'm on a Mac Intel Monterey 12.6.7
after the update only thigs i see is:
Cannot connect to the server, it doesn't seem to be running...
i do not know whats happening, nothing change before the update.
EDIT From the Console
Last login: Mon Jun 15 17:24:45 on console
The default interactive shell is now zsh.
To update your account to use zsh, please run `chsh -s /bin/zsh`.
For more details, please visit https://support.apple.com/kb/HT208050.
/Applications/Serviio-Console.app/Contents/MacOS/Serviio-Console ; exit;
iMacP:~ pit$ /Applications/Serviio-Console.app/Contents/MacOS/Serviio-Console ; exit;
(node:1594) electron: Failed to load URL: http://localhost:23423/console with error: ERR_CONNECTION_REFUSED
(Use `Serviio-Console --trace-warnings ...` to show where the warning was created)
[1594:0615/175432.700106:ERROR:trust_store_mac.cc(844)] Error parsing certificate:
ERROR: Failed parsing extensions
EDIT 2 after change to zsh
Last login: Mon Jun 15 18:31:15 on ttys000
pit@iMacP ~ % /Applications/Serviio-Console.app/Contents/MacOS/Serviio-Console ; exit;
(node:1045) electron: Failed to load URL: http://localhost:23423/console with error: ERR_CONNECTION_REFUSED
[1045:0615/183614.230773:ERROR:trust_store_mac.cc(844)] Error parsing certificate:
