"Cannot find the server", "Cannot load data"
gavsdavs
Post Sat Jul 06, 2019 3:51 pm
Have a Sony BluRay player (BDP-S7200)
I suspect this is a piece of media in my library but I dont' know how to identify it. The problem started when I switched to Serviio 2.0.
Most of the time I get a "Cannot find the server", "Cannot load data" error when trying to browse serviio videos. Occasionally it'll let me see the menu structure (Movies, Titles, Artists, etc)
Pertinent log segment:
2019-07-06 16:50:10,373 DEBUG [ServiioHttpService] Incoming request from /10.99.99.19:39008: POST /serviceControl HTTP/1.1, headers = [X-AV-Physical-Unit-Info: pa="Blu-ray Disc Player";,X-AV-Client-Info: av=5.0; cn="Sony Corporation"; mn="Blu-ray Disc Player"; mv="2.0";,Host: 10.99.99.116:8895,User-Agent: UPnP/1.0 DLNADOC/1.50,Content-Length: 595,Content-Type: text/xml; charset="utf-8",SOAPACTION: "urn:schemas-upnp-org:service:ContentDirectory:1#Browse"]]
2019-07-06 16:50:10,374 DEBUG [RendererDAOImpl] Reading a Renderer with ip address 10.99.99.19
2019-07-06 16:50:10,374 DEBUG [RendererService] Rendered 00000000-0000-1010-8000-fcf152bb62b1 doesn't have a User assigned to it, using Default
2019-07-06 16:50:10,374 DEBUG [ServiceControlRequestHandler] ServiceControl request received for action '"urn:schemas-upnp-org:service:ContentDirectory:1#Browse"' from 10.99.99.19
2019-07-06 16:50:10,378 DEBUG [ContentDirectory] Browse() called for renderer Blu-ray Disc Player (profile 1) with parameters: objectID = 2, browseFlag = BrowseDirectChildren, filter = av:mediaClass,dc:title,dc:date,@childCount,upnp:class,res,res@resolution,res@size,res@protocolInfo,res@duration,res@bitrate,av:containerClass,res@dlna:ifoFileURI, startIndex = 0, count = 10, sortCriteria =
2019-07-06 16:50:10,378 WARN  [ContentDirectory] Object with id 2 doesn't exist
2019-07-06 16:50:10,379 DEBUG [ServiceControlRequestHandler] Returning error SOAP message
2019-07-06 16:50:10,984 DEBUG [MediaItemDAOImpl] Reading a MediaItem (id = 529)
2019-07-06 16:50:10,984 DEBUG [MediaItemDAOImpl] Getting counts of media items by type
How do I find what Object with id 2 is ?
Any hints ?
gavsdavs
Post Sat Jul 06, 2019 8:49 pm
Re: "Cannot find the server", "Cannot load data"
Frustratingly, Serviio is working fine when i browse it with VLC. No issues at all.
Just this sony BluRay player.
gavsdavs
Post Sat Jul 06, 2019 8:55 pm
[root@cracker movies]# tcpdump -A -n -i any host 10.99.99.19
tcpdump: verbose output suppressed, use -v or -vv for full protocol decode
listening on any, link-type LINUX_SLL (Linux cooked), capture size 262144 bytes
21:53:56.027225 IP 10.99.99.19.47100 > 10.99.99.116.8895: Flags [S], seq 156976764, win 5840, options [mss 1460,sackOK,TS val 1167103 ecr 0,nop,wscale 5], length 0
E..<..@.@...
cc.
cct..". [F|........\A.........
21:53:56.027269 IP 10.99.99.116.8895 > 10.99.99.19.47100: Flags [S.], seq 3158478893, ack 156976765, win 65160, options [mss 1460,sackOK,TS val 1096441872 ecr 1167103,nop,wscale 7], length 0
E..<..@.@._o
cct
cc."....B.-     [F}...............
AZ`.........
21:53:56.027463 IP 10.99.99.19.47100 > 10.99.99.116.8895: Flags [.], ack 1, win 183, options [nop,nop,TS val 1167103 ecr 1096441872], length 0
E..4..@.@...
cc.
cct..". [F}.B.......8.....
....AZ`.
21:53:56.027786 IP 10.99.99.19.47100 > 10.99.99.116.8895: Flags [P.], seq 1:364, ack 1, win 183, options [nop,nop,TS val 1167104 ecr 1096441872], length 363
E.....@.@...
cc.
cct..". [F}.B......5......
....AZ`.POST /serviceControl HTTP/1.1
Content-Length: 595
21:53:56.027803 IP 10.99.99.116.8895 > 10.99.99.19.47100: Flags [.], ack 364, win 507, options [nop,nop,TS val 1096441873 ecr 1167104], length 0
E..4.X@.@...
cct
cc."....B..     [G............
AZ`.....
21:53:56.028023 IP 10.99.99.19.47100 > 10.99.99.116.8895: Flags [P.], seq 364:959, ack 1, win 183, options [nop,nop,TS val 1167104 ecr 1096441873], length 595
E.....@.@...
cc.
cct..". [G..B......Y......
....AZ`.<?xml version="1.0"?><s:Envelope xmlns:s="http://schemas.xmlsoap.org/soap/envelope/" s:encodingStyle="http://schemas.xmlsoap.org/soap/encoding/"><s:Body><u:Browse xmlns:u="urn:schemas-upnp-org:service:ContentDirectory:1"><ObjectID>2</ObjectID><BrowseFlag>BrowseDirectChildren</BrowseFlag><Filter>av:mediaClass,dc:title,dc:date,@childCount,upnp:class,res,res@resolution,res@size,res@protocolInfo,res@duration,res@bitrate,av:containerClass,res@dlna:ifoFileURI</Filter><StartingIndex>0</StartingIndex><RequestedCount>10</RequestedCount><SortCriteria></SortCriteria></u:Browse></s:Body></s:Envelope>
21:53:56.028039 IP 10.99.99.116.8895 > 10.99.99.19.47100: Flags [.], ack 959, win 503, options [nop,nop,TS val 1096441873 ecr 1167104], length 0
E..4.Y@.@...
cct
cc."....B..     [J;.....8.....
AZ`.....
21:53:56.038628 IP 10.99.99.116.8895 > 10.99.99.19.47100: Flags [P.], seq 1:712, ack 959, win 503, options [nop,nop,TS val 1096441883 ecr 1167104], length 711
E....Z@.@..U
cct
cc."....B..     [J;...........
AZ`.....HTTP/1.1 500 Internal Server Error
EXT:
Date: Sat, 06 Jul 2019 20:53:56 GMT
Server: Linux UPnP/1.0 DLNADOC/1.50 Serviio/2.0
Content-Length: 518
<?xml version="1.0" encoding="utf-8" ?><SOAP-ENV:Envelope xmlns:SOAP-ENV="http://schemas.xmlsoap.org/soap/envelope/" SOAP-ENV:encodingStyle="http://schemas.xmlsoap.org/soap/encoding/"><SOAP-ENV:Body><SOAP-ENV:Fault><faultcode>SOAP-ENV:Client</faultcode><faultstring>UPnPError</faultstring><detail><UPnPError xmlns="urn:schemas-upnp-org:control-1-0"><errorCode xmlns="">701</errorCode><errorDescription xmlns="">No such object</errorDescription></UPnPError></detail></SOAP-ENV:Fault></SOAP-ENV:Body></SOAP-ENV:Envelope>
21:53:56.038852 IP 10.99.99.19.47100 > 10.99.99.116.8895: Flags [.], ack 712, win 227, options [nop,nop,TS val 1167115 ecr 1096441883], length 0
E..4..@.@...
cc.
cct..". [J;.B.......p.....
....AZ`.
21:53:56.039534 IP 10.99.99.19.47100 > 10.99.99.116.8895: Flags [F.], seq 959, ack 712, win 227, options [nop,nop,TS val 1167115 ecr 1096441883], length 0
E..4..@.@...
cc.
cct..". [J;.B.......o.....
....AZ`.
21:53:56.039594 IP 10.99.99.116.8895 > 10.99.99.19.47100: Flags [F.], seq 712, ack 960, win 503, options [nop,nop,TS val 1096441884 ecr 1167115], length 0
E..4.[@.@...
cct
cc."....B..     [J<.....Y.....
AZ`.....
21:53:56.039777 IP 10.99.99.19.47100 > 10.99.99.116.8895: Flags [.], ack 713, win 227, options [nop,nop,TS val 1167116 ecr 1096441884], length 0
E..4..@.@...
cc.
cct..". [J<.B.......l.....
....AZ`.
21:53:56.247747 IP 10.99.99.19.50201 > 239.255.255.250.ssdp: UDP, length 267
E..'..@....V
cc........l...ZNOTIFY * HTTP/1.1
HOST: 239.255.255.250:1900
CACHE-CONTROL: max-age=1800
NT: upnp:rootdevice
NTS: ssdp:alive
SERVER: Linux/2.6 UPnP/1.0 Sony-BDP/2.0
USN: uuid:00000004-0000-1010-8000-fcf152bb62b1::upnp:rootdevice
21:53:56.269085 IP 10.99.99.19.50201 > 239.255.255.250.ssdp: UDP, length 276
E..0..@....M
cc........l....NOTIFY * HTTP/1.1
NT: uuid:00000004-0000-1010-8000-fcf152bb62b1
NTS: ssdp:alive
21:53:56.290137 IP 10.99.99.19.50201 > 239.255.255.250.ssdp: UDP, length 307
E..O..@.....
cc........l.;.+NOTIFY * HTTP/1.1
NT: urn:schemas-upnp-org:device:Basic:1
NTS: ssdp:alive
USN: uuid:00000004-0000-1010-8000-fcf152bb62b1::urn:schemas-upnp-org:device:Basic:1
21:53:56.311672 IP 10.99.99.19.50201 > 239.255.255.250.ssdp: UDP, length 315
E..W..@....&
cc........l.C.CNOTIFY * HTTP/1.1
NT: urn:dial-multiscreen-org:service:dial:1
NTS: ssdp:alive
USN: uuid:00000004-0000-1010-8000-fcf152bb62b1::urn:dial-multiscreen-org:service:dial:1
21:53:56.333061 IP 10.99.99.19.50201 > 239.255.255.250.ssdp: UDP, length 267
E..'..@....V
NT: upnp:rootdevice
NTS: ssdp:alive
21:53:56.354556 IP 10.99.99.19.50201 > 239.255.255.250.ssdp: UDP, length 276
E..0..@....M
NTS: ssdp:alive
21:53:56.376632 IP 10.99.99.19.50201 > 239.255.255.250.ssdp: UDP, length 307
E..O..@.....
NTS: ssdp:alive
21:53:56.398698 IP 10.99.99.19.50201 > 239.255.255.250.ssdp: UDP, length 315
E..W..@....&
NTS: ssdp:alive
21:53:56.420689 IP 10.99.99.19.50201 > 239.255.255.250.ssdp: UDP, length 267
E..'..@....V
NT: upnp:rootdevice
NTS: ssdp:alive
21:53:56.442139 IP 10.99.99.19.50201 > 239.255.255.250.ssdp: UDP, length 276
E..0..@....M
NTS: ssdp:alive
21:53:56.463592 IP 10.99.99.19.50201 > 239.255.255.250.ssdp: UDP, length 307
E..O..@.....
NTS: ssdp:alive
21:53:56.485270 IP 10.99.99.19.50201 > 239.255.255.250.ssdp: UDP, length 315
E..W..@....&
NTS: ssdp:alive
21:54:01.285118 ARP, Request who-has 10.99.99.19 tell 10.99.99.116, length 28
........L..h..
cct......
cc.
21:54:01.285249 ARP, Reply 10.99.99.19 is-at fc:f1:52:bb:62:b1, length 46
..........R.b.
cc.L..h..
cct..................
^C
26 packets captured
36 packets received by filter
2 packets dropped by kernel
gavsdavs
Post Sat Jul 06, 2019 9:11 pm
Downgraded to 1.10-1 - Initially the BD Rom could browse serviio, but very quickly the issue re-occurs.
I suspect this is a defective browser/player rather than serviio here, any suggestion as to how i prove it ?
gavsdavs
Post Sat Jul 06, 2019 9:34 pm
Full reset of the bluray player, so far (using v1.10-1 and V2.0) so good.
Will report back if it starts to misbehave again.
Post Sat Jul 06, 2019 10:31 pm
Yeah, it does sound like a player hiccup. My Sony BD players have always been reliable, but I tend to be using my Shield or Roku for playback most of the time. If it happens again, and VLC is still working, that doesn't sound like anything to do with Serviio.
kasterzanayed
Post Mon Mar 07, 2022 12:34 pm
"There are a few methods to install apps on Sailfish, but the most common one is through the Jolla Store, which is Sailfish's official app store. You can also download apps from third-party sources, but it's important to be cautious and only download from trusted sources.
For a step-by-step guide on installing apps on Sailfish OS, check out an article on the official Sailfish OS website. It covers everything from enabling developer mode, adding third-party repositories, and installing and updating apps.
And if you're looking for some great apps to try out on Sailfish OS, I recommend checking out smartengines.com. They offer a variety of automatic document scanning and OCR software that could be useful for business or personal use. Good luck with your Sailfish adventure!"
Spond2001
Post Fri Aug 21, 2026 12:24 pm
The Object with id 2 doesn't exist message is probably a symptom rather than something you can directly map to a particular file in your library.
The important bit is that the player is sending a UPnP Browse request for objectID = 2, and Serviio 2.0 is replying that it can't find that object in its media database. I wouldn't assume that ID 2 corresponds to a movie or other specific piece of media.
Since this started immediately after upgrading to Serviio 2.0, I'd first suspect a Serviio database/indexing or renderer-profile issue, rather than a corrupt media file.
