Serviio 2.5 Install package for Synology DSM 7.x.x
Meelis
Post Thu Jun 25, 2026 9:28 am
Will we see in future Serviio installation package for Synology NAS systems?
We have here some special persons like "kittmaster" & "patters".
Now are past some years since no package for Synology NAS. Everyone is busy and it was very time consuming to make installer.
Is it possible to do it now faster with AI help maybe?
I just don't want to use docker version and prefer to have normal NAS installer.
Meelis
Post Tue Jul 28, 2026 11:36 am
Re: Serviio 2.5 Install package for Synology DSM 7.x.x
Here is Not Official Serviio 2.5 package for Synology NAS.
https://github.com/SimkaBoi/synology-se ... 5-0001.spk
Manual package install required.
kittmaster
Post Mon Oct 26, 2026 1:35 pm
It isn't the time consumption to build, it is the security architecture that change how it installs and it's methods based on the user permissions.
Factor in that patters had hardware transcoding, trying to merge that all together back then with limited information from a linux point of view, not so easy. That is why I jumped to Kodi and started skinning for my own expansion of capability and GUI interface controls.
What I don't like about the SPK is there is no source compilation and it is "install blind" as manual.
I'll see where I was (had a basic framework) and see if a 2.5 is possible with a proper installer, but will have to see what's what as I'm still on v6 of synology and virtual machined v7, might be possible to finally build something that will work.
kittmaster
Post Mon Oct 26, 2026 10:53 pm
I promised I'd look at this long ago, things just fell apart, but if it's worth anything, I've followed through and here is the release.
https://github.com/kittmaster/Serviio
Everything is documented and as complete as I can make it.
There are a few things to go, but the intent now is to see if you can install on v7 and see how it goes, what works, what's broken, or any other issue which I can resolve.
If this works out, I'll be updating my NAS to v7 permanently and not look back on v6 (which I'm still on).
So give it a go, the .spk is in the release pages and this is where all updates will come from.
Not sure how to have Serviio replace the downloads page link, but if anyone has suggestions, let me know so I can start that process assuming this works for all.
Regards,
F16falcon
Post Sun Nov 22, 2026 8:31 pm
Dear Kittmaster!
I installed version 2.5 on DSM 7.4.1. Do I need to buy a license or can I get one to test?
thx for help
F16falcon
kittmaster
Post Sun Nov 22, 2026 8:42 pm
I don't provide licenses, that is what you buy from Serviio, but if you just installed it, you should have 15 days until it goes from pro to base I think.
The key point, did it install, does it report the fields right in the package area, and overall... does it work???
The license only affects Mediabrowser I think, so setup your DLNA and see if it works?
Best,
Chris
F16falcon
Post Mon Nov 23, 2026 6:19 pm
ok, thanks, I'll check and test it
thx Chris
BR
F16falcon
F16falcon
Post Mon Nov 23, 2026 6:48 pm
Dear Chris!
I installed Serviio PRO v 2.5 on the
NAS Device: Synology DS925+
Memory: 32GB
DSM version: 7.4.1-90080 Update 2.
I set the rights for the libraries. I added videos to it. They were updated. TV type: LG OLED65C9PLA
Serviio appeared on it, the libraries are visible according to the settings. Videos can be played. That's it for now, I'll continue testing.
Best R.
F16falcon (Tom)
kittmaster
Post Mon Nov 23, 2026 6:55 pm
Great news, let me know how the continued testing goes.
Chris
Post Tue Nov 24, 2026 12:19 am
kittmaster wrote:The license only affects Mediabrowser I think, so setup your DLNA and see if it works?
There's more functionality than that with the Pro version, but MB is probably what people would use most. Here's the page that describes the additions:
https://www.serviio.org/buy-pro/10-unca ... ree-vs-pro
F16falcon
Post Tue Nov 24, 2026 3:39 am
Thx Dan
