Nokia E72 and Serviio
Post Mon May 02, 2011 7:25 pm
Re: Nokia E72 and Serviio
Andrzej wrote:
Andrzej wrote:
moltra wrote:I see in your detailed log that you are referencing the drive by the drive letter ( H:\testy DLAN mozna wykasowac\2004-09
). Is this drive local to the windows 2k machine or is it a networked drive? If it is a network drive you will need to link the folder as follows.
Hi, this is local on 2k machine only. and service should have access to it. My understanding is that serviio server "hides" entire path. Is it not like that?
I've followed your advise, and I've changed login for the service from localsystem to Administrator, and now it works (at least pictures) on Nokia E72 and on LG BD660 as well. I will experiment now more - not only with pictures but also with video to see how it works.
Thank you for effective support.
I will share results of my tests with you.
Local System Accounts are just that, installed there by default when the OS is loaded and should be disabled. You will need it to be a local user account ( administrator is one ) for serviio to work and be able to access your files.
patters
Post Thu May 05, 2011 4:56 pm
Half the services running on a Windows machine run as Local System.
Post Thu May 05, 2011 5:25 pm
patters wrote:Half the services running on a Windows machine run as Local System.
Windows CORE services maybe ;)
Coolangel
Post Mon Dec 10, 2012 10:34 am
I have locked my E72 can anyone tell me how to unlock.
buti
Post Thu Oct 31, 2013 9:28 am
Coolangel wrote:I have locked my E72 can anyone tell me how to unlock.
nokia mobiles
http://alrazaak.com/forums/38-Nokia-mobiles-Prices-Pakistan
hmm i have the same issue as you mentioned above now i crack it i have sent you pm you can check then reply me here or sent me pm back
Previous
Return to User experiences
