RMVB support
nachotheix
Post Sat Apr 30, 2011 8:25 am
RMVB support
If rmvb isn't supported by ffmpeg, it'll be possible transcode this format accross Serviio?
./ffmpeg -i /Users/nacho/Movies/Baby\ Einstein/03\ meses\ Baby\ Einstein\ Bach\ -\ Aventura\ Musical.rmvb
built on Jan 12 2011 19:51:48 with gcc 4.0.1 (Apple Inc. build 5493)
configuration: --enable-static --disable-shared --bindir=/tmp/ffmpeg --disable-ffplay --disable-ffserver --enable-libmp3lame --enable-pthreads --disable-mmx --extra-ldflags=-L/tmp/static/lib --extra-cflags=-I/tmp/static/include
libavutil 50.36. 0 / 50.36. 0
libavcore 0.16. 0 / 0.16. 0
libavfilter 1.72. 0 / 1.72. 0
libswscale 0.12. 0 / 0.12. 0
[NULL @ 0x1023400] Unsupported video codec
[rm @ 0x1009600] max_analyze_duration reached
Input #0, rm, from '/Users/nacho/Movies/Baby Einstein/03 meses Baby Einstein Bach - Aventura Musical.rmvb':
title :
author :
copyright :
comment :
Duration: 00:27:07.25, start: 0.000000, bitrate: 704 kb/s
Stream #0.0: Audio: cook, 44100 Hz, stereo, s16, 64 kb/s
Stream #0.1: Video: rv40, yuv420p, 720x540, 603 kb/s, 12.05 fps, 12 tbr, 1k tbn, 12 tbc
Stream #0.2: Data: [0][0][0][0] / 0x0000
Anaerin
Post Sun May 01, 2011 9:37 pm
Re: RMVB support
Actually, that looks like rmvb is supported:
tells me that it's found a video and audio format it recognizes. I think the "Unsupported video codec" comes from the third stream in that rmvb container, which ffmpeg is displaying as
. It's possibly a closed-caption stream.
Post Mon May 02, 2011 9:35 pm
Re: RMVB support
There is already an ticket to support Real Video. Hopefully for 0.6
yummy88
Post Mon Dec 12, 2011 10:39 am
Re: RMVB support
Hi , when will Serviio support RMVB 3.0 / 4.0 transcoding? Currently, cannot browse any RMVB files.
Post Mon Dec 12, 2011 10:47 am
Re: RMVB support
not in the next version, probably in the one after
Return to Feature requests
