Xbox 360 fast forward
soccer_fan1
Post Sun May 01, 2011 10:06 pm
First I would like to say that this program is absolutly great. The addition of the pictures to the Xbox videos was wonderful.
The only issue I'm currently having is with fast forward/skip on a video file.
The current Xbox profile trancodes the videos as follows:
<Video targetContainer="asf" targetVCodec="wmv2" targetACodec="wmav2" maxVBitrate="15360" forceStereo="true">
<Matches container="mpeg" />
<Matches container="mpegts" />
<Matches container="mpegvideo" />
<Matches container="avi" />
<Matches container="wtv" />
When I try to fast forward it states that the action is not available.
Any ideas as to what this might be happening?
Post Mon May 02, 2011 9:41 pm
Re: Xbox 360 fast forward
Which file were you playing?
soccer_fan1
Post Tue May 03, 2011 12:56 am
AVI files mostly.
Here's teh export from GSpot
A View to a Kill (1985).avi F:\Movies\Movies\A View to a Kill (1985)\A View to a Kill (1985).avi 735,042,828 1 AVI(.AVI) Split 504 500 OpenDML (AVI v2.0), 0 678 DivX 3 Low-Motion Codec(s) are Installed DIV3 2.313 2:05:44 188586 25.000 1.000 25.000 0.179 2.313 592 256 96 CBR 2 0x0055 MPEG-1 Layer 3 Codec(s) are Installed 32000 .
Post Tue May 03, 2011 11:07 am
You changed the profile to transcode all avi's and maybe the xbox doesn't support time based seek. Try reverting back to the stock xbox profile and play the avi then.
soccer_fan1
Post Fri May 06, 2011 12:45 am
Thank you for the quick reply. The original Xbox profile allows for fast forward of some but not others. I believe it allowd for fast forward the files that are not being transcoded and the Xbox can play natively.
For example:
This fast forwards with the original profile but the audio is choppy. I think because the video is not being transcoded by the audio is.
20,000 Leagues Under the Sea (1954).avi F:\Movies\Movies\20,000 Leagues Under the Sea (1954)\20,000 Leagues Under the Sea (1954).avi 702,528,512 1 AVI(.AVI) Split 42 AVI v1.0, 0 600 XviD 1.1.0 Final Codec(s) are Installed XVID 2.143 2:06:55 182561 23.976 MPEG-4 B-VOP 1.000 23.976 0.103 2.143 720 336 128 CBR 2 0x0055 MPEG-1 Layer 3 Codec(s) are Installed 48000 .
This one does not fast forward. I belive that both the video and audio are being transcoded.
Thank you for your help.
Post Fri May 06, 2011 10:12 am
In the original original profile no AVI's were transcoded (apart from those with msmpeg4 codec). Looks like transcoding is preventing ffwd so I'd stick with the original profile. If audio is choppy it's down to the player or the file as the file is playing natively (which you could confirm by looking into the detailed log)
soccer_fan1
Post Sat May 07, 2011 12:02 am
I found a workaround. Once the video start playing, it is being transcoded and saved in the temp directory. If i wait for a few minutes until the video is completely transcoded it still does not fast forward. I stop the playback and go back to the main screen. I can click on resume and now it fast forwards.
Post Sat May 07, 2011 7:43 pm
soccer_fan1 wrote:...If i wait for a few minutes until the video is completely transcoded it still does not fast forward. I stop the playback and go back to the main screen. I can click on resume and now it fast forwards.
Zip, do you have an idea how we could explain that?
