avoiding transcoding by reencoding files for Sony BDPS370
n3mmr
Post Tue May 03, 2011 7:27 am
Suppose I want to reencode a video file to an ideal format for serviio to serve to an EU Sony BDP S370:
I e:
there will be no reason for serviio to transcode the file on the fly
The resulting stream will play back on the BDP370 with the maximum quality and versatility possible.
The resulting file can be put on a data DVD and played back on the BDP370 directly with results that are as close to optimum as currently possible
How should I reencode a video file to achieve that?
What would be the ideal vcodec, acodec and file format to use as a target?
I'm guessing (yes. This is a bewilderingly complex subject.) that an ideal container format would be mpegts and the file extension would then be m2ts, and the ideal vcodec should be mpeg2video.
Is this the right choice?
For the acodec I'm in the dark.
Post Tue May 03, 2011 5:08 pm
Re: avoiding transcoding by reencoding files for Sony BDPS37
Post Sat May 07, 2011 7:32 pm
n3mmr wrote:...
Yes I think, the right choice should be M2TS (MPEG2TS) with AVC/H264 video and AC3 audio (multichannels), profile something like AVC_TS_HD_EU
Users browsing this forum: Google [Bot] and 5 guests
