LaCie LaCinema Media Players - Serviio Profile
individual
Post Fri May 06, 2011 9:09 am
I will try to make a profile for LaCie LaCinema HD media players (mine is LaCinema MiniHD Connect) which are DLNA certified.
My model works quite well with Serviio's Generic DLNA profile, the dot is green and the device is identified by name, but external subtitles are not streamed (subtitles which are available within video container ARE streamed). If anyone can help with suggestion, so I wouldn't go trial-and-error for too long, I would very much appreciated.
Here are the supported files and features:
Video Codecs : MPEG-1, MPEG-2 / HD, MPEG-4, DIVX, DIVX HD, XVID, H.264 HD, WMV9 HD, VC-1, AVC/AVCHD (a majority of AVC/AVCHD formats have been tested and are compatible).
Video Format : AVI, MP4, MKV, WMV, DivX, DAT, MOV**, MPEG, VOB, ASF, TS, TP, TRP, M2TS, DVR-MS, DVD-Video (ISO, Video_TS)****
Subtitles : SRT, SSA, SUB, SMI, PSB, ASS
Audio Format : MP3, WMA, WAV/PCM/LPCM, AAC**, OGG, FLAC, AC3, MP4, MKA (*supports iTunes-encoded)
Subtitle Languages : Western Europe, Central Europe (Windows-1250), Central Europe (ISO), Traditional Chinese (Big5), Simplified Chinese (GB18030), Japanese (Shift-JIS), Korean (EUC-KR), Cyrillic (Windows-1251), Cyrillic (KOI8-R), Turkish, Greek (Windows-1253), Greek (ISO)
Photo : JPEG*, PNG, GIF, BMP, TIFF/TIF (*excluding progressive jpeg)
Audio Multichannel Decoding : DTS, DTS HD, Dolby 5.1: convert to stereo to play on TV
Audio Multichannel Passthrough : DTS, Dolby 5.1, Dolby true HD: raw signal sent via HDMI or optical audio to compatible audio amplifier
DTS HD: DTS signal sent via HDMI or optical audio to compatible audio amplifier
Playlist : PLS, M3U, WPL (Windows Media Player, Winamp compatible)
And here is the start. i have ammended the profiles with the following code, in a hope to make Serviio load external subtitles and automatically assign the correct profile.
   <Profile id="14" name="LaCie LaCinema Media Players" extendsProfileId="1">
      <Detection>
         <UPnPSearch>
            <ModelNumber>LaCinema.*</ModelNumber>
         </UPnPSearch>
      </Detection>
I could only manage to get Serviio to identify and asign the correct profile to the device, but EXTERNAL subtitles are not streamed yet. Any hints?
As a personal taste, I would also like to set a lower bitrate to audio streams in AAC audio container or to remux them so the AV receiver could decode them (it has a limit to up to 320kbps, although the media player can pass through AAC at any rate)... but I don't know exactly how should I handle this.
NAS: DS712+, 2x Seagate ST2000DL003
DLNA Server: Synology, Serviio, Twonky, Plex
DLNA Player: Raspberry Pi Raspbmc
DLNA Tablet: Yatse
Post Fri May 06, 2011 12:36 pm
Re: LaCie LaCinema Media Players - Serviio Profile
Is the device supposed to support external subs over DLNA? Did you get it working using any other server? The profile you're using should be ok to serve the subtitle resource to the device but if it doesn't support it (or supports it in a different way - as subs are not in the DLNA standard) then you're out of luck.
individual
Post Sat May 07, 2011 2:23 pm
Yes, Twonky Server can stream external subtitles. I have it installed and it works. Can I investigate any further, zip? Could you give me any hints?
DLNA Tablet: Yatse
Post Sat May 07, 2011 3:18 pm
Try adding this line to your profile:
<ContentDirectoryMessageBuilder>org.serviio.upnp.service.contentdirectory.PanasonicDLNAMessageBuilder</ContentDirectoryMessageBuilder>
Post Sat May 07, 2011 7:50 pm
individual wrote:I will try to make a profile for LaCie LaCinema HD media players (mine is LaCinema MiniHD Connect) which are DLNA certified.
Lacie is not DLNA certified, but DLNA Compatible...
Do you try this, to know supported formats over DLNA?
individual
Post Sun May 08, 2011 7:21 am
Illico wrote:Do you try this, to know supported formats over DLNA?
The list was taken from their website, but here is the invoked result from Device Spy:
http-get:*:audio/L16;rate=44100;channels=1:DLNA.ORG_PN=LPCM,
http-get:*:audio/mpeg:DLNA.ORG_PN=MP3,
http-get:*:audio/x-ms-wma:DLNA.ORG_PN=WMAFULL,
http-get:*:audio/x-ms-wma:DLNA.ORG_PN=WMABASE,
http-get:*:audio/x-ms-wma:DLNA.ORG_PN=WMAPRO,
http-get:*:video/mpeg:DLNA.ORG_PN=MPEG_PS_PAL,
http-get:*:video/mpeg:DLNA.ORG_PN=MPEG_PS_NTSC,
http-get:*:video/vnd.dlna.mpeg-tts:DLNA.ORG_PN=MPEG_TS_SD_NA,
http-get:*:video/vnd.dlna.mpeg-tts:DLNA.ORG_PN=MPEG_TS_SD_NA_T,
http-get:*:video/mpeg:DLNA.ORG_PN=MPEG_TS_SD_NA_ISO,
http-get:*:video/vnd.dlna.mpeg-tts:DLNA.ORG_PN=MPEG_TS_SD_EU,
http-get:*:video/vnd.dlna.mpeg-tts:DLNA.ORG_PN=MPEG_TS_SD_EU_T,
http-get:*:video/mpeg:DLNA.ORG_PN=MPEG_TS_SD_EU_ISO,
http-get:*:video/vnd.dlna.mpeg-tts:DLNA.ORG_PN=MPEG_TS_SD_KO,
http-get:*:video/vnd.dlna.mpeg-tts:DLNA.ORG_PN=MPEG_TS_SD_KO_T,
http-get:*:video/mpeg:DLNA.ORG_PN=MPEG_TS_SD_KO_ISO,
http-get:*:video/x-ms-wmv:DLNA.ORG_PN=WMVMED_PRO,
http-get:*:video/x-ms-wmv:DLNA.ORG_PN=WMVMED_BASE,
http-get:*:video/x-ms-wmv:DLNA.ORG_PN=WMVMED_FULL,
http-get:*:video/x-ms-wmv:DLNA.ORG_PN=WMVHIGH_FULL,
http-get:*:video/x-ms-wmv:DLNA.ORG_PN=WMVHIGH_PRO,
http-get:*:video/x-ms-wmv:DLNA.ORG_PN=WMVHM_BASE,
http-get:*:video/x-ms-wmv:DLNA.ORG_PN=WMVSPLL_BASE,
http-get:*:video/x-ms-wmv:DLNA.ORG_PN=WMVSPML_BASE,
http-get:*:image/jpeg:DLNA.ORG_PN=JPEG_SM,
http-get:*:image/jpeg:DLNA.ORG_PN=JPEG_MED,
http-get:*:image/jpeg:DLNA.ORG_PN=JPEG_LRG,
http-get:*:image/jpeg:DLNA.ORG_PN=JPEG_TN,
http-get:*:audio/x-aiff:*,
http-get:*:audio/x-wav:*,
http-get:*:audio/lpcm:*,
http-get:*:audio/x-mpegurl:*,
http-get:*:audio/x-scpls:*,
http-get:*:audio/x-ms-asx:*,
http-get:*:audio/rmp:*,
http-get:*:video/mpeg2:*,
http-get:*:video/dvd:*,
http-get:*:video/x-msvideo:*,
http-get:*:video/avi:*,
http-get:*:video/mp4:*,
http-get:*:video/MP4V-ES:*,
http-get:*:video/MP4V:*,
http-get:*:video/x-mpegurl:*,
http-get:*:video/x-scpls:*,
http-get:*:video/x-ms-asx:*,
http-get:*:video/rmp:*,
http-get:*:image/tiff:*,
http-get:*:image/jpeg:*,
http-get:*:image/jpeg2000:*,
http-get:*:image/png:*,
http-get:*:image/bmp:*,
http-get:*:image/gif:*,
http-get:*:image/x-mpegurl:*,
http-get:*:image/x-scpls:*,
http-get:*:image/x-ms-asx:*,
http-get:*:image/rmp:*,
http-get:*:application/ogg:*,file:*:audio/x-ms-wma:*,file:*:audio/x-aiff:*,file:*:audio/mpeg:*,file:*:audio/x-wav:*,file:*:audio/lpcm:*,file:*:audio/x-mpegurl:*,file:*:audio/x-scpls:*,file:*:audio/x-ms-asx:*,file:*:audio/rmp:*,file:*:video/mpeg:*,file:*:video/mpeg2:*,file:*:video/dvd:*,file:*:video/x-msvideo:*,file:*:video/mp4:*,file:*:video/MP4V-ES:*,file:*:video/MP4V:*,file:*:video/x-mpegurl:*,file:*:video/x-scpls:*,file:*:video/x-ms-asx:*,file:*:video/rmp:*,file:*:image/tiff:*,file:*:image/jpeg:*,file:*:image/jpeg2000:*,file:*:image/png:*,file:*:image/bmp:*,file:*:image/gif:*,file:*:image/x-mpegurl:*,file:*:image/x-scpls:*,file:*:image/x-ms-asx:*,file:*:image/rmp:*,file:*:application/ogg:*,rhapsody:*:audio/x-ms-wma:*,rhapsody:*:audio/x-mpegurl:*,rhapsody:*:audio/x-rhap-radio:*,uvox:*:audio/mpeg:*,
http-get:*:image/sls:*,
http-get:*:application/x-dtcp1;CONTENTFORMAT=image/jpeg:*,unicast:*:video/mpeg2ts:*,multicast:*:video/mpeg2ts:*,rtsp:*:video/mp4:*,rtsp:*:misc/sdp:*
DLNA Tablet: Yatse
individual
Post Sun May 08, 2011 7:33 am
@zip: THAT HELPED! External subtitles are now streamed by Serviio to LaCinema MiniHD! One note though, if subtitles are available in video container and are alos external, only external one is available, not both. If no external subtitle is available, then the one in video container is displayed.
Could you give me a hint on how I should limit the bandwidth of AAC stream to 320kbps?
Thank you!
DLNA Tablet: Yatse
Post Sun May 08, 2011 10:11 am
You'd have to transcode all your aac streams to ac3 with the aBitrate set to 320 - but it'll make a lot of your videos that would normally play natively to be transcoded.
individual
Post Sat May 14, 2011 1:07 pm
@zip: I wonder if you could tell me how to write the transcoding profile for AAC audio to be at lower bitrate, everything else being left just the same, regardless the video container/codec. I tried for a while, but I can't get it to work...
I tried by doing this:
<Video targetContainer="mpeg" targetACodec="aac" aBitrate="320">
   <Matches container="asf" aCodec="aac" />
   <Matches container="flv" aCodec="aac" />
   <Matches container="mpeg" aCodec="aac" />
   <Matches container="mpegts" aCodec="aac" />
   <Matches container="mpegvideo" aCodec="aac" />
   <Matches container="avi" aCodec="aac" />
   <Matches container="mp4" aCodec="aac" />
   <Matches container="matroska" aCodec="aac" />
Thank you in advance.
DLNA Tablet: Yatse
Post Sat May 14, 2011 6:23 pm
Do you have a look at the detailed logging file, you could find error or warning?
individual
Post Sun May 15, 2011 6:56 am
Illico wrote:Do you have a look at the detailed logging file, you could find error or warning?
Yes, the connection is reset. here is what happens in between these resets:
2011-05-14 15:55:21,688 DEBUG [WebServer] I/O error: Connection reset
2011-05-14 15:55:21,690 DEBUG [WebServer] Incoming connection from /192.168.116.246:43072
2011-05-14 15:55:21,691 DEBUG [ResourceTransportRequestHandler] GET /resource/298/MEDIA_ITEM/MATROSKA$0 HTTP/1.0, headers = [Host: 192.168.116.254:8895,Content-Length: 0,Range: bytes=0-,User-Agent: INTEL_NMPR/2.1 DLNADOC/1.50 dma/3.0 alphanetworks]]
2011-05-14 15:55:21,692 DEBUG [RendererDAOImpl] Reading a Renderer with ip address 192.168.116.246
2011-05-14 15:55:21,693 DEBUG [ResourceTransportRequestHandler] Resource request accepted. Using client 'IPAddress=/192.168.116.246, Profile=LaCie LaCinema Media Players'
2011-05-14 15:55:21,694 DEBUG [ResourceTransportRequestHandler] Request for resource 298 and type 'MEDIA_ITEM' received
2011-05-14 15:55:21,694 DEBUG [MediaItemDAOImpl] Reading a MediaItem (id = 298)
2011-05-14 15:55:21,696 DEBUG [VideoDAOImpl] Reading a Video (id = 298)
2011-05-14 15:55:21,698 DEBUG [VideoDeliveryEngine] Delivering item '298' for client 'IPAddress=/192.168.116.246, Profile=LaCie LaCinema Media Players'
2011-05-14 15:55:21,698 DEBUG [VideoDeliveryEngine] Delivering file 'A Marine Story 2010.mkv' in native format
2011-05-14 15:55:21,698 DEBUG [MediaItemDAOImpl] Getting file of media item 298
2011-05-14 15:55:21,713 DEBUG [MediaItemDAOImpl] Marking MediaItem (id = 298) as read
2011-05-14 15:55:21,717 DEBUG [LocalContentCacheDecorator] Cleared cache (local_resetafterplay)
2011-05-14 15:55:21,717 DEBUG [ResourceTransportRequestHandler] Creating stream entity with length: 1796175087
2011-05-14 15:55:21,718 DEBUG [ResourceTransportRequestHandler] Sending file back
2011-05-14 15:55:21,718 DEBUG [ResourceTransportRequestHandler] HTTP/1.1 206 Partial Content, headers = [[Content-Type: video/x-matroska,Content-Range: bytes 0-1796175086/1796175087,Content-Length: 1796175087,Date: Sat, 14 May 2011 13:55:21 GMT,Server: Linux, UPnP/1.0 DLNADOC/1.50, Serviio/0.5.2,Cache-control: no-cache,transferMode.dlna.org: Streaming]]
2011-05-14 15:55:21,720 DEBUG [WebServer] I/O error: Connection reset
And attached is the log after trying to transcode audio into ac3 instead of aac.
The result is the same: The file doesn't play.
(11.68 KiB) Downloaded 745 times
DLNA Tablet: Yatse
Post Sun May 15, 2011 9:58 am
individual wrote:...Yes, the connection is reset. here is what happens in between these resets:
This file is treamed in Native format, does lacie support MKV over DLNA ? not sure according to the specifcation...
You probably need to transcode into MPEG2TS.
On your latest log file, it seems "Generic Profile" is selected not your "Lacie Profile"...
individual
Post Sun May 15, 2011 1:58 pm
Is is supporting mkv over dlna.
DLNA Tablet: Yatse
individual
Post Wed May 25, 2011 8:53 am
I can't seem to find a way to transcode/remux .mp4 with AAC audio so that it can be played through LaCie profile.... I tried everything. The log only shows that the connection is reset.
This is the file I tried to transcode:
Complete name                    : \\nas\video\Movies - 1080p\Saving 1080p\Saving.mp4
Format                           : MPEG-4
Format profile                   : Base Media
Codec ID                         : isom
File size                        : 3.99 GiB
Duration                         : 2h 41mn
Overall bit rate                 : 3 532 Kbps
Encoded date                     : UTC 2011-05-04 06:00:21
Tagged date                      : UTC 2011-05-04 06:00:21
Format profile                   : High@L4.0
Format settings, CABAC           : Yes
Format settings, ReFrames        : 4 frames
Codec ID                         : avc1
Codec ID/Info                    : Advanced Video Coding
Duration                         : 2h 41mn
Bit rate mode                    : Variable
Bit rate                         : 3 307 Kbps
Maximum bit rate                 : 18.2 Mbps
Width                            : 1 920 pixels
Height                           : 1 032 pixels
Display aspect ratio             : 1.860
Frame rate mode                  : Constant
Frame rate                       : 23.976 fps
Bits/(Pixel*Frame)               : 0.070
Stream size                      : 3.73 GiB (94%)
Writing library                  : FASM Quality Enhancer Bitrate Squeezer 3.4 (c)2010 Fachman
Encoded date                     : UTC 2011-05-04 03:31:44
Tagged date                      : UTC 2011-05-04 06:03:23
Color primaries                  : BT.709-5, BT.1361, IEC 61966-2-4, SMPTE RP177
Transfer characteristics         : BT.709-5, BT.1361
Matrix coefficients              : BT.709-5, BT.1361, IEC 61966-2-4 709, SMPTE RP177
Format                           : AAC
Format/Info                      : Advanced Audio Codec
Format profile                   : HE-AAC / LC
Codec ID                         : 40
Duration                         : 2h 41mn
Bit rate                         : 222 Kbps
Maximum bit rate                 : 287 Kbps
Channel(s)                       : 6 channels
Channel positions                : Front: L C R, Side: L R, LFE
Sampling rate                    : 48.0 KHz / 24.0 KHz
Stream size                      : 257 MiB (6%)
Language                         : English
Encoded date                     : UTC 2011-05-04 03:34:07
And this is the last profile I tried to use:
<Detection>
<UPnPSearch>
</UPnPSearch>
</Detection>
That is a hard transcode profile for mp4 but I couldn't do it with this either:
  <Matches container="mp4" aCodec="aac"/>
The file doesn't play on LaCie through SERVIIO. However, if I try to play the file directly from shared folder, it plays well, only it doesn't have audio, due to a limitation in LaCie player, which doesn't passthrough AAC sound to my Onkyo AV receiver. That's why I need to transcode AAC audio into something to be passed through to the receiver.
Any help and suggestion would be greatly appreciated. Thank you!
DLNA Tablet: Yatse
Post Wed May 25, 2011 9:39 am
individual wrote:Any help and suggestion would be greatly appreciated. Thank you!
Could you enable detailed logging (see signature), restart serviio, try to show the file on the TV....then post log result here ?
individual
Post Wed May 25, 2011 10:01 am
Media Info:
Complete name : \\nas\video\Movies - 720p\2011 The Rite\The Rite 2011.mp4
Format : MPEG-4
Codec ID : isom
File size : 2.71 GiB
Duration : 1h 53mn
Overall bit rate : 3 409 Kbps
Encoded date : UTC 2011-04-26 02:13:34
Tagged date : UTC 2011-04-26 02:13:34
Format : AVC
Format profile : High@L4.1
Format settings, ReFrames : 3 frames
Codec ID : avc1
Duration : 1h 53mn
Bit rate : 3 000 Kbps
Maximum bit rate : 27.9 Mbps
Width : 1 280 pixels
Height : 536 pixels
Display aspect ratio : 2.35:1
Color space : YUV
Bit depth : 8 bits
Bits/(Pixel*Frame) : 0.182
Stream size : 2.36 GiB (87%)
Writing library : x264 core 75 r1251kMod e553a4c
Encoding settings : cabac=1 / ref=3 / deblock=1:0:0 / analyse=0x3:0x113 / me=umh / subme=7 / psy=1 / psy_rd=1.0:0.0 / mixed_ref=1 / me_range=12 / chroma_me=1 / trellis=2 / 8x8dct=1 / cqm=0 / deadzone=21,11 / chroma_qp_offset=-2 / threads=3 / nr=0 / decimate=1 / mbaff=0 / bframes=3 / b_pyramid=0 / b_adapt=2 / b_bias=0 / direct=1 / wpredb=1 / keyint=250 / keyint_min=25 / scenecut=40 / rc_lookahead=60 / rc=cbr / mbtree=1 / bitrate=3000 / ratetol=1.0 / qcomp=0.50 / qpmin=10 / qpmax=51 / qpstep=4 / vbv_maxrate=24000 / vbv_bufsize=24000 / ip_ratio=1.40 / aq=1:1.00
Tagged date : UTC 2011-04-26 02:16:54
Format : AAC
Format profile : LC
Codec ID : 40
Duration : 1h 53mn
Bit rate : 439 Kbps
Maximum bit rate : 546 Kbps
Stream size : 357 MiB (13%)
Encoded date : UTC 2011-04-26 02:16:28
Transcoding settings used:
Log file attached. Thank you!
serviio.zip
(35.67 KiB) Downloaded 674 times
DLNA Tablet: Yatse
individual
Post Thu May 26, 2011 7:40 am
By now I have done every possible attempt to transcode MP4 with AAC audio into something that is playable to LaCie media player, and while I do can play the file if I access it from a shared folder (again, without sound - my Onkyo receiver wrongly identifies the AAC multichannel stream as Dolby but no sound is getting through), any attempt to play with transcoding activated in Serviio results in either:
- file not playing or,
- LaCie being hung up and restarting.
If transcoding is deactivated, then the file can be played through Serviio, but without sound, of course; same as if it was played directly from shared folder...
I even tried to force audio to stereo in the transcoding profile, and also setting downmix to stereo in the Serviio's console, but with the same results.
So I came up to these conclusions:
a) LaCie player might pass through raw AAC multichannel (or stereo) streams, but Onkyo AV receiver cannot handle it for some reason, although the manual shows that it can play AAC files, but does not specify if it can play multichannel streams, so I asume the receiver can only play stereo files with the correct bitrate and sample frequency. I don't know exactly what LaCie media player takes out for audio though, but something might be wrong since the receiver "sees" AAC as DolbyD.
b) For some reasons which I can't understand yet, Serviio can't transcode this MP4 with AAC file into something that LaCie can play correctly. I tried everything for audio: ac3, lpmc, forceStereo... nothing worked. As for video, I tried to leave the stream as it is (H264) or to transcode it into mpeg2video, but it didn't worked.
So, now I am puzzled and left with no other ideas... Any help or suggestion are to be greatly appreciated! Thanks in advance.
DLNA Tablet: Yatse
Post Thu May 26, 2011 8:13 am
individual wrote:b) For some reasons which I can't understand yet, Serviio can't transcode this MP4 with AAC file into something that LaCie can play correctly. I tried everything for audio: ac3, lpmc, forceStereo... nothing worked. As for video...
Are you sure you try different audio ac3, lpcm, forcestereo, etc...do you check the temporary file format ( *.stf) with "ffmpeg -i" command
individual wrote:I tried to leave the stream as it is (H264) or to transcode it into mpeg2video, but it didn't worked.
What do you mean by "didn't worked"? idid ffmpeg failed or your TV did not support the format?
individual
Post Thu May 26, 2011 9:51 am
ffmpeg -i The\ Rite\ 2011.mp4
  built on Apr  8 2011 17:16:26 with gcc 4.2.3
  configuration: --arch=arm --enable-armv5te --prefix=/opt --extra-cflags=-I/opt        /include --extra-ldflags=-L/opt/lib --enable-static --disable-shared --disable-f        fplay --disable-ffserver --enable-libmp3lame
  libavutil     50.36. 0 / 50.36. 0
  libavcore      0.16. 0 /  0.16. 0
  libavcodec    52.108. 0 / 52.108. 0
  libavformat   52.92. 0 / 52.92. 0
  libavdevice   52. 2. 3 / 52. 2. 3
  libavfilter    1.72. 0 /  1.72. 0
  libswscale     0.12. 0 /  0.12. 0
Seems stream 0 codec frame rate differs from container frame rate: 47.95 (500000        0/104271) -> 23.98 (24000/1001)
Input #0, mov,mp4,m4a,3gp,3g2,mj2, from 'The Rite 2011.mp4':
    major_brand     : isom
    minor_version   : 1
    compatible_brands: isomavc1
    creation_time   : 2011-04-26 02:13:34
  Duration: 01:53:42.37, start: 0.000000, bitrate: 3408 kb/s
    Stream #0.0(und): Video: h264, yuv420p, 1280x536 [PAR 1:1 DAR 160:67], 2966        kb/s, 23.98 fps, 23.98 tbr, 24k tbn, 47.95 tbc
    Stream #0.1(und): Audio: aac, 48000 Hz, 5.1, s16, 438 kb/s
      creation_time   : 2011-04-26 02:16:28
By "didn't worked" I meant "file not playing or, LaCie being hung up and restarting".
Just for the sake of clarity, LaCie MiniHD Connect is a media player, not a TV.
DLNA Tablet: Yatse
Manuel
Post Thu Dec 20, 2012 3:43 pm
Reviving this thread coz i keep getting same problem......this is what is preinstalled on the serviio version i DLed.....
<Profile id="15" name="LaCie LaCinema Media Player"   extendsProfileId="1">
      <Detection>
         <UPnPSearch>
         </UPnPSearch>
      </Detection>
with the above subs dont load......if i try to change the line to
then i get an error for the service........any ideas?
Thank you in advance!!!
