Using Serviio on a headless server
Vin
Post Mon Jan 31, 2011 7:45 pm
Hi all,
I'm using a headless server, and headless also means no X11 libs so no X forwarding over SSH. I was messing around in the Derby DB at first, hacking in the database and stuff. That really sucked. But after a while I figured out that the Servio console uses an REST (over HTTP) API to communicate with the server component. That means
a) you can use a REST client (google for the API doc, ZIP has provided a short PDF) to query and update data
b) you port forward port 23423 using an SSH tunnel (ssh -L23423:localhost:23423 <your-server-hostname>) and just run the serviio-console on this machine
I may have missed some FAQ that points this out, but I hope this forum post helps out others facing the same troubles.
Post Mon Jan 31, 2011 7:48 pm
Re: Using Serviio on a headless server
wouldn't just the normal remote console setup work over SSH?
Post Mon Jan 31, 2011 7:55 pm
zip wrote:wouldn't just the normal remote console setup work over SSH?
he is so over thinking this when you can just use the remote console to manage the library on a headless server, no ssh required
Vin
Post Wed Feb 02, 2011 7:20 pm
Aha, so there's the missing piece of the puzzle. There's a remote mode for the console? Didn't run into that.. of course, that's a lot easier.
phn2
Post Thu Mar 17, 2011 7:34 am
A noob like me (and probl. others) are having some trouble getting remote console working. The "guide" i faq dosnt. cover it for me, anybody willing to show the way please?
best regard, Per.
I can use putty and WINscp, but cant get futher, setting up via serviio console.
Post Thu Mar 17, 2011 5:54 pm
phn2 wrote:A noob like me (and probl. others) are having some trouble getting remote console working. The "guide" i faq dosnt. cover it for me, anybody willing to show the way please?
best regard, Per.
were exactly in teh FAQ are you getting stuck?
phn2
Post Sun May 08, 2011 1:43 pm
its setting up klient and server up with ip-adr, so theyll connect?
best regards, Per.
Post Sun May 08, 2011 2:13 pm
phn2 wrote:its setting up klient and server up with ip-adr, so theyll connect?
best regards, Per.
viewtopic.php?f=5&t=142&start=10#p873
phn2
Post Sun May 08, 2011 5:23 pm
Hello.
Changed that; didnt help. The klient-side says "cannot connect to serviio, server might no be running, exiting"
I can se the server on my renderer, sony tv and ps3.
best regards, Per.
Post Sun May 08, 2011 5:53 pm
check the log of the server, is should say starting REST server on IP:port and make sure the IP is the IP of the server
patters
Post Mon May 09, 2011 7:24 am
I couldn't get this working either when I tried it (before I had a working web UI on my NAS). However,beckos has written it up carefully on the Synology Forum:
http://forum.synology.com/enu/viewtopic ... 15#p143526
It looks like the confusing bit is that you need to specify the server IP on the client and on the server itself.
phn2
Post Mon May 09, 2011 1:02 pm
Hello.
Tried again, heres the log:
011-05-09 12:51:07,183 INFO [DiscoverySSDPMessageListener] Starting DiscoverySSDPMessageListener using interface eth0 (eth0) and address 192.168.2.10, timeout = 0
2011-05-09 12:51:07,201 INFO [RendererSearchSender] Searching for Renderer devices
2011-05-09 12:51:07,201 INFO [RendererExpirationChecker] Starting RendererExpirationChecker
2011-05-09 12:51:33,266 INFO [LibraryAdditionsCheckerThread] Started looking for newly added files
2011-05-09 12:51:33,289 INFO [LibraryUpdatesCheckerThread] Started looking for updates to currently shared files
2011-05-09 12:54:47,055 DEBUG [ApplicationInstanceManager] Port is already taken. Notifying first instance.
2011-05-09 12:54:47,058 DEBUG [ApplicationInstanceManager] Successfully notified first instance.
2011-05-09 12:54:47,058 INFO [MediaServer] Serviio server instance is already running
2011-05-09 12:55:56,218 DEBUG [ApplicationInstanceManager] Port is already taken. Notifying first instance.
2011-05-09 12:55:56,221 INFO [MediaServer] Serviio server instance is already running
2011-05-09 12:55:56,221 DEBUG [ApplicationInstanceManager] Successfully notified first instance.
2011-05-09 12:56:07,365 DEBUG [ApplicationInstanceManager] Port is already taken. Notifying first instance.
2011-05-09 12:56:07,368 DEBUG [ApplicationInstanceManager] Successfully notified first instance.
2011-05-09 12:56:07,368 INFO [MediaServer] Serviio server instance is already running
Hope this helps?
Post Mon May 09, 2011 1:11 pm
Are you running 2 copies of the serviio service? Instead of one copy of the service and one copy of the service console.
phn2
Post Mon May 09, 2011 2:19 pm
Dont think so, maybe tried to start the console a couple of times...
Post Mon May 09, 2011 2:32 pm
How are you starting Serviio? are you starting it directly or running one of the scripts in http://forum.serviio.org/viewtopic.php?f=17&t=71.
phn2
Post Tue May 10, 2011 7:30 am
Hello.
I can connect to Serviio from the renderers; Sony tv and ps3. Starting serviio with path to Serviio in init.d. Shows up fine i running processes. Attaching some of new log, my klint must be 192.168.2.5; right?:
2011-05-10 07:25:58,652 DEBUG [DiscoveryAdvertisementNotifier] Multicasting SSDP alive using interface eth0 (eth0) and address 192.168.2.10, timeout = 0
2011-05-10 07:25:58,654 DEBUG [DiscoveryAdvertisementNotifier] Sending 6 'alive' messages describing device b417b37c-4030-3c89-bb6e-b5e8798e235b
2011-05-10 07:25:59,260 DEBUG [WebServer] Incoming connection from /192.168.2.5:33622
2011-05-10 07:25:59,261 DEBUG [DeviceDescriptionRequestHandler] DeviceDescription request received for device b417b37c-4030-3c89-bb6e-b5e8798e235b from 192.168.2.5 (headers = [Host: 192.168.2.10:8895,Date: Tue, 10 May 2011 07:25:58 GMT,User-Agent: UPnP/1.0,X-AV-Physical-Unit-Info: pa="BRAVIA KDL-40HX800";,X-AV-Client-Info: av=5.0; cn="Sony Corporation"; mn="BRAVIA KDL-40HX800"; mv="1.7";])
2011-05-10 07:25:59,261 DEBUG [RendererDAOImpl] Reading a Renderer with ip address 192.168.2.5
2011-05-10 07:25:59,263 DEBUG [RendererDAOImpl] Reading a Renderer with ip address 192.168.2.5
2011-05-10 07:25:59,267 DEBUG [DeviceDescriptionRequestHandler] Sending DeviceDescription XML back using profile 'Sony Bravia TV'
2011-05-10 07:25:59,329 DEBUG [WebServer] Incoming connection from /192.168.2.5:33623
2011-05-10 07:25:59,330 DEBUG [ServiceDescriptionRequestHandler] ServiceDescription request received for service ConnectionManager
2011-05-10 07:25:59,332 DEBUG [ServiceDescriptionRequestHandler] Sending ServiceDescription XML back
2011-05-10 07:25:59,398 DEBUG [WebServer] Incoming connection from /192.168.2.5:33624
2011-05-10 07:25:59,399 DEBUG [ServiceDescriptionRequestHandler] ServiceDescription request received for service ContentDirectory
2011-05-10 07:25:59,400 DEBUG [ServiceDescriptionRequestHandler] Sending ServiceDescription XML back
2011-05-10 07:25:59,528 DEBUG [WebServer] Incoming connection from /192.168.2.5:33625
2011-05-10 07:25:59,529 DEBUG [ServiceControlRequestHandler] ServiceControl request received for action '"urn:schemas-upnp-org:service:ContentDirectory:1#GetSortCapabilities"' from 192.168.2.5:
2011-05-10 07:25:59,530 DEBUG [RendererDAOImpl] Reading a Renderer with ip address 192.168.2.5
2011-05-10 07:25:59,539 DEBUG [ServiceControlRequestHandler] Returning OK SOAP message
2011-05-10 07:25:59,551 DEBUG [WebServer] Incoming connection from /192.168.2.5:33626
2011-05-10 07:25:59,554 DEBUG [ServiceControlRequestHandler] ServiceControl request received for action '"urn:schemas-upnp-org:service:ConnectionManager:1#GetProtocolInfo"' from 192.168.2.5:
2011-05-10 07:25:59,554 DEBUG [RendererDAOImpl] Reading a Renderer with ip address 192.168.2.5
2011-05-10 07:25:59,602 DEBUG [ConnectionManager] Sending protocol info using profile 'Sony Bravia TV'
2011-05-10 07:25:59,620 DEBUG [ServiceControlRequestHandler] Returning OK SOAP message
2011-05-10 07:26:00,121 DEBUG [WebServer] Incoming connection from /192.168.2.5:33627
2011-05-10 07:26:00,134 DEBUG [DeviceDescriptionRequestHandler] DeviceDescription request received for device b417b37c-4030-3c89-bb6e-b5e8798e235b from 192.168.2.5 (headers = [Host: 192.168.2.10:8895,Date: Tue, 10 May 2011 07:25:59 GMT,User-Agent: UPnP/1.0,X-AV-Physical-Unit-Info: pa="BRAVIA KDL-40HX800";,X-AV-Client-Info: av=5.0; cn="Sony Corporation"; mn="BRAVIA KDL-40HX800"; mv="1.7";])
2011-05-10 07:26:00,134 DEBUG [RendererDAOImpl] Reading a Renderer with ip address 192.168.2.5
2011-05-10 07:26:00,135 DEBUG [RendererDAOImpl] Reading a Renderer with ip address 192.168.2.5
2011-05-10 07:26:00,138 DEBUG [DeviceDescriptionRequestHandler] Sending DeviceDescription XML back using profile 'Sony Bravia TV'
2011-05-10 07:26:00,206 DEBUG [WebServer] Incoming connection from /192.168.2.5:33628
2011-05-10 07:26:00,208 DEBUG [ServiceDescriptionRequestHandler] ServiceDescription request received for service ConnectionManager
2011-05-10 07:26:00,209 DEBUG [ServiceDescriptionRequestHandler] Sending ServiceDescription XML back
2011-05-10 07:26:00,290 DEBUG [WebServer] Incoming connection from /192.168.2.5:33629
2011-05-10 07:26:00,291 DEBUG [ServiceDescriptionRequestHandler] ServiceDescription request received for service ContentDirectory
2011-05-10 07:26:00,292 DEBUG [ServiceDescriptionRequestHandler] Sending ServiceDescription XML back
2011-05-10 07:26:00,410 DEBUG [WebServer] Incoming connection from /192.168.2.5:33630
2011-05-10 07:26:00,412 DEBUG [ServiceControlRequestHandler] ServiceControl request received for action '"urn:schemas-upnp-org:service:ContentDirectory:1#GetSortCapabilities"' from 192.168.2.5:
2011-05-10 07:26:00,413 DEBUG [RendererDAOImpl] Reading a Renderer with ip address 192.168.2.5
2011-05-10 07:26:00,432 DEBUG [ServiceControlRequestHandler] Returning OK SOAP message
2011-05-10 07:26:00,447 DEBUG [WebServer] Incoming connection from /192.168.2.5:33631
2011-05-10 07:26:00,457 DEBUG [DiscoveryAdvertisementNotifier] Will advertise again in 00:01:12
2011-05-10 07:26:00,463 DEBUG [ServiceControlRequestHandler] ServiceControl request received for action '"urn:schemas-upnp-org:service:ConnectionManager:1#GetProtocolInfo"' from 192.168.2.5:
2011-05-10 07:26:00,463 DEBUG [RendererDAOImpl] Reading a Renderer with ip address 192.168.2.5
2011-05-10 07:26:00,469 DEBUG [ConnectionManager] Sending protocol info using profile 'Sony Bravia TV'
2011-05-10 07:26:00,488 DEBUG [ServiceControlRequestHandler] Returning OK SOAP message
2011-05-10 07:26:09,562 DEBUG [RepositoryDAOImpl] Reading all Repositories
Post Tue May 10, 2011 9:05 am
Can you post the beginning of your server log? It should say starting REST on IP.....
phn2
Post Tue May 10, 2011 3:32 pm
Here goes:
I think the repeated request from 192.168.2.5 is WINscp from klient machine trying to connect?
2011-05-10 15:30:42,515 DEBUG [ApplicationInstanceManager] Listening for application instances on socket 44331
2011-05-10 15:30:42,556 INFO [MediaServer] ------------------------------------------------------------------------
2011-05-10 15:30:42,556 INFO [MediaServer] Serviio DLNA media streaming server v 0.5.2 (rev. 4e3210bd9ff3)
2011-05-10 15:30:42,556 INFO [MediaServer] Petr Nejedly 2009-2011
2011-05-10 15:30:42,556 INFO [MediaServer] http://www.serviio.org
2011-05-10 15:30:42,557 INFO [MediaServer]
2011-05-10 15:30:42,557 INFO [MediaServer] Java 1.6.0_20-Sun Microsystems Inc.
2011-05-10 15:30:42,557 INFO [MediaServer] OS Linux i386 2.6.32-30-generic
2011-05-10 15:30:42,557 INFO [MediaServer] File encoding: US-ASCII
2011-05-10 15:30:42,557 INFO [MediaServer] ------------------------------------------------------------------------
2011-05-10 15:30:45,498 INFO [RestletServer] Starting Restlet server exposed on localhost:23423
2011-05-10 15:30:45,660 INFO [DBSchemaUpdateExecutor] Checking if DB schema needs to be updated
2011-05-10 15:30:45,699 DEBUG [DBLogDAOImpl] Checking if script 'script-0.1.sql' has been run
2011-05-10 15:30:51,035 DEBUG [DBLogDAOImpl] Checking if script 'script-0.1.1.sql' has been run
2011-05-10 15:30:51,037 DEBUG [DBLogDAOImpl] Checking if script 'script-0.2.sql' has been run
2011-05-10 15:30:51,039 DEBUG [DBLogDAOImpl] Checking if script 'script-0.3.1.sql' has been run
2011-05-10 15:30:51,041 DEBUG [DBLogDAOImpl] Checking if script 'script-0.4.sql' has been run
2011-05-10 15:30:51,043 DEBUG [DBLogDAOImpl] Checking if script 'script-0.4.1.sql' has been run
2011-05-10 15:30:51,045 DEBUG [DBLogDAOImpl] Checking if script 'script-0.4.2.sql' has been run
2011-05-10 15:30:51,046 DEBUG [DBLogDAOImpl] Checking if script 'script-0.5.sql' has been run
2011-05-10 15:30:51,048 DEBUG [DBLogDAOImpl] Checking if script 'script-0.5.1.sql' has been run
2011-05-10 15:30:51,751 INFO [ProfilesDefinitionParser] Parsing Profiles definition
2011-05-10 15:30:51,812 DEBUG [ProfilesDefinitionParser] Parsing profile definition for profile 1
2011-05-10 15:30:52,761 INFO [ProfilesDefinitionParser] Added profile 'Generic DLNA profile' (id=1)
2011-05-10 15:30:52,763 DEBUG [ProfilesDefinitionParser] Parsing profile definition for profile 2
2011-05-10 15:30:53,084 INFO [ProfilesDefinitionParser] Added profile 'Samsung TV (B-series)' (id=2)
2011-05-10 15:30:53,086 DEBUG [ProfilesDefinitionParser] Parsing profile definition for profile 3
2011-05-10 15:30:53,257 INFO [ProfilesDefinitionParser] Added profile 'XBox 360' (id=3)
2011-05-10 15:30:53,259 DEBUG [ProfilesDefinitionParser] Parsing profile definition for profile 4
2011-05-10 15:30:53,402 INFO [ProfilesDefinitionParser] Added profile 'Playstation 3' (id=4)
2011-05-10 15:30:53,407 DEBUG [ProfilesDefinitionParser] Parsing profile definition for profile 5
2011-05-10 15:30:53,574 INFO [ProfilesDefinitionParser] Added profile 'Samsung TV (A-series)' (id=5)
2011-05-10 15:30:53,576 DEBUG [ProfilesDefinitionParser] Parsing profile definition for profile 6
2011-05-10 15:30:53,676 INFO [ProfilesDefinitionParser] Added profile 'DirecTV HD-DVR' (id=6)
2011-05-10 15:30:53,678 DEBUG [ProfilesDefinitionParser] Parsing profile definition for profile 7
2011-05-10 15:30:53,940 INFO [ProfilesDefinitionParser] Added profile 'Samsung TV / player (C/D-series)' (id=7)
2011-05-10 15:30:53,943 DEBUG [ProfilesDefinitionParser] Parsing profile definition for profile 8
2011-05-10 15:30:54,008 INFO [ProfilesDefinitionParser] Added profile 'LG BD player' (id=8)
2011-05-10 15:30:54,010 DEBUG [ProfilesDefinitionParser] Parsing profile definition for profile 9
2011-05-10 15:30:54,454 INFO [ProfilesDefinitionParser] Added profile 'Sony Bravia TV' (id=9)
2011-05-10 15:30:54,457 DEBUG [ProfilesDefinitionParser] Parsing profile definition for profile 10
2011-05-10 15:30:55,140 INFO [ProfilesDefinitionParser] Added profile 'Sony BD Player' (id=10)
2011-05-10 15:30:55,143 DEBUG [ProfilesDefinitionParser] Parsing profile definition for profile 12
2011-05-10 15:30:55,320 INFO [ProfilesDefinitionParser] Added profile 'Panasonic Viera' (id=12)
2011-05-10 15:30:55,324 DEBUG [ProfilesDefinitionParser] Parsing profile definition for profile 13
2011-05-10 15:30:55,572 INFO [ProfilesDefinitionParser] Added profile 'Toshiba Rezga' (id=13)
2011-05-10 15:30:55,578 DEBUG [FFMPEGWrapper] Invoking FFMPEG to check if it exists of path ffmpeg
2011-05-10 15:30:55,585 DEBUG [ProcessExecutor] Starting ffmpeg
2011-05-10 15:30:56,265 INFO [AbstractTranscodingDeliveryEngine] Cleaning transcode engine and its data
2011-05-10 15:30:56,274 DEBUG [ConfigEntryDAOImpl] Reading all ConfigEntries
2011-05-10 15:30:56,315 INFO [WebServer] Socket buffer set to 65535 bytes
2011-05-10 15:30:56,409 INFO [WebServer] WebServer starting on port 8895
2011-05-10 15:30:56,448 INFO [Device] Created UPnP Device with UUID: b417b37c-4030-3c89-bb6e-b5e8798e235b, bound address: 192.168.2.10
2011-05-10 15:30:56,521 INFO [CompositeCacheManager] Creating cache manager from config file: /cache.ccf
2011-05-10 15:30:56,542 INFO [ThreadPoolManager] thread_pool.default PoolConfiguration = useBoundary = [true] boundarySize = [2000] maximumPoolSize = [150] minimumPoolSize = [4] keepAliveTime = [300000] whenBlockedPolicy = [RUN] startUpSize = [4]
2011-05-10 15:30:56,551 INFO [CompositeCacheConfigurator] Setting default auxiliaries to null
2011-05-10 15:30:56,551 INFO [CompositeCacheConfigurator] No special CompositeCacheAttributes class defined for key [jcs.default.cacheattributes], using default class.
2011-05-10 15:30:56,555 INFO [CompositeCacheConfigurator] setting defaultCompositeCacheAttributes to [ useLateral = true, useRemote = true, useDisk = true, maxObjs = 100, maxSpoolPerRun = -1, diskUsagePattern = 0 ]
2011-05-10 15:30:56,556 INFO [CompositeCacheConfigurator] No special ElementAttribute class defined for key [jcs.default.elementattributes], using default class.
2011-05-10 15:30:56,556 INFO [CompositeCacheConfigurator] setting defaultElementAttributes to [ IS_LATERAL = true, IS_SPOOL = true, IS_REMOTE = true, IS_ETERNAL = true, MaxLifeSeconds = -1, IdleTime = -1, CreateTime = 1305041456556, LastAccessTime = 1305041456556, getTimeToLiveSeconds() = -1, createTime = 1305041456556 ]
2011-05-10 15:30:56,568 INFO [CompositeCacheConfigurator] No special ElementAttribute class defined for key [jcs.region.local_resetafterplay.elementattributes], using default class.
2011-05-10 15:30:56,606 INFO [LRUMemoryCache] initialized LRUMemoryCache for local_resetafterplay
2011-05-10 15:30:56,606 INFO [CompositeCache] Constructed cache with name [local_resetafterplay] and cache attributes [ useLateral = true, useRemote = true, useDisk = true, maxObjs = 1000, maxSpoolPerRun = -1, diskUsagePattern = 0 ]
2011-05-10 15:30:56,607 INFO [CompositeCacheConfigurator] No special ElementAttribute class defined for key [jcs.region.local_default.elementattributes], using default class.
2011-05-10 15:30:56,607 INFO [LRUMemoryCache] initialized LRUMemoryCache for local_default
2011-05-10 15:30:56,607 INFO [CompositeCache] Constructed cache with name [local_default] and cache attributes [ useLateral = true, useRemote = true, useDisk = true, maxObjs = 1000, maxSpoolPerRun = -1, diskUsagePattern = 0 ]
2011-05-10 15:30:56,608 INFO [CompositeCacheConfigurator] Parsed regions [local_resetafterplay, local_default]
2011-05-10 15:30:56,608 INFO [CompositeCacheConfigurator] Finished configuration in 61 ms.
2011-05-10 15:30:56,611 DEBUG [DiscoveryManager] UPNP device b417b37c-4030-3c89-bb6e-b5e8798e235b (192.168.2.10) is available
2011-05-10 15:30:56,614 INFO [EventDispatcher] Starting EventDispatcher
2011-05-10 15:30:56,615 INFO [EventSubscriptionExpirationChecker] Starting EventSubscriptionExpirationChecker
2011-05-10 15:30:56,615 INFO [DiscoveryAdvertisementNotifier] Starting DiscoveryAdvertisementNotifier
2011-05-10 15:30:56,622 INFO [DiscoverySSDPMessageListener] Starting DiscoverySSDPMessageListener using interface eth0 (eth0) and address 192.168.2.10, timeout = 0
2011-05-10 15:30:56,634 INFO [RendererSearchSender] Searching for Renderer devices
2011-05-10 15:30:56,634 INFO [RendererExpirationChecker] Starting RendererExpirationChecker
2011-05-10 15:30:56,639 DEBUG [RendererSearchSender] Multicasting SSDP M-SEARCH using interface eth0 (eth0) and address 192.168.2.10, timeout = 0
2011-05-10 15:30:56,683 DEBUG [RendererSearchSender] Sending 1 'm-search' messages
2011-05-10 15:30:56,707 DEBUG [DiscoveryAdvertisementNotifier] Multicasting SSDP alive using interface eth0 (eth0) and address 192.168.2.10, timeout = 0
2011-05-10 15:30:56,710 DEBUG [DiscoveryAdvertisementNotifier] Sending 6 'alive' messages describing device b417b37c-4030-3c89-bb6e-b5e8798e235b
2011-05-10 15:30:56,712 DEBUG [DiscoverySSDPMessageListener] Received a valid M-SEARCH message for search target urn:schemas-upnp-org:device:MediaRenderer:1 from address /192.168.2.10:56643
2011-05-10 15:30:56,716 DEBUG [DiscoverySSDPMessageListener] Received a valid M-SEARCH message for search target urn:schemas-upnp-org:device:MediaRenderer:1 from address /192.168.2.10:56643
2011-05-10 15:30:56,718 DEBUG [DiscoverySSDPMessageListener] Received a valid M-SEARCH message for search target urn:schemas-upnp-org:device:MediaRenderer:1 from address /192.168.2.10:56643
2011-05-10 15:30:57,358 DEBUG [WebServer] Incoming connection from /192.168.2.5:60673
2011-05-10 15:30:57,378 DEBUG [DeviceDescriptionRequestHandler] DeviceDescription request received for device b417b37c-4030-3c89-bb6e-b5e8798e235b from 192.168.2.5 (headers = [Host: 192.168.2.10:8895,Date: Tue, 10 May 2011 15:30:56 GMT,User-Agent: UPnP/1.0,X-AV-Physical-Unit-Info: pa="BRAVIA KDL-40HX800";,X-AV-Client-Info: av=5.0; cn="Sony Corporation"; mn="BRAVIA KDL-40HX800"; mv="1.7";])
2011-05-10 15:30:57,379 DEBUG [RendererDAOImpl] Reading a Renderer with ip address 192.168.2.5
2011-05-10 15:30:57,449 DEBUG [RendererDAOImpl] Reading a Renderer with ip address 192.168.2.5
2011-05-10 15:30:58,514 DEBUG [DiscoveryAdvertisementNotifier] Will advertise again in 00:00:10
2011-05-10 15:31:01,096 DEBUG [DeviceDescriptionRequestHandler] Sending DeviceDescription XML back using profile 'Sony Bravia TV'
2011-05-10 15:31:02,355 DEBUG [WebServer] Incoming connection from /192.168.2.5:60674
2011-05-10 15:31:02,357 DEBUG [ServiceDescriptionRequestHandler] ServiceDescription request received for service ConnectionManager
2011-05-10 15:31:02,389 DEBUG [ServiceDescriptionRequestHandler] Sending ServiceDescription XML back
2011-05-10 15:31:02,425 DEBUG [WebServer] Incoming connection from /192.168.2.5:60675
2011-05-10 15:31:02,427 DEBUG [ServiceDescriptionRequestHandler] ServiceDescription request received for service ContentDirectory
2011-05-10 15:31:02,495 DEBUG [ServiceDescriptionRequestHandler] Sending ServiceDescription XML back
2011-05-10 15:31:02,562 DEBUG [WebServer] Incoming connection from /192.168.2.5:60676
2011-05-10 15:31:02,569 DEBUG [ServiceControlRequestHandler] ServiceControl request received for action '"urn:schemas-upnp-org:service:ContentDirectory:1#GetSortCapabilities"' from 192.168.2.5:
2011-05-10 15:31:02,570 DEBUG [RendererDAOImpl] Reading a Renderer with ip address 192.168.2.5
2011-05-10 15:31:02,690 DEBUG [RendererSearchSender] Finished searching for Renderer devices
2011-05-10 15:31:03,393 DEBUG [ServiceControlRequestHandler] Returning OK SOAP message
2011-05-10 15:31:03,402 DEBUG [WebServer] Incoming connection from /192.168.2.5:60677
2011-05-10 15:31:03,404 DEBUG [ServiceControlRequestHandler] ServiceControl request received for action '"urn:schemas-upnp-org:service:ConnectionManager:1#GetProtocolInfo"' from 192.168.2.5:
2011-05-10 15:31:03,404 DEBUG [RendererDAOImpl] Reading a Renderer with ip address 192.168.2.5
2011-05-10 15:31:03,412 DEBUG [ConnectionManager] Sending protocol info using profile 'Sony Bravia TV'
2011-05-10 15:31:03,493 DEBUG [ServiceControlRequestHandler] Returning OK SOAP message
2011-05-10 15:31:03,839 DEBUG [WebServer] Incoming connection from /192.168.2.5:60678
2011-05-10 15:31:03,841 DEBUG [DeviceDescriptionRequestHandler] DeviceDescription request received for device b417b37c-4030-3c89-bb6e-b5e8798e235b from 192.168.2.5 (headers = [Host: 192.168.2.10:8895,Date: Tue, 10 May 2011 15:31:02 GMT,User-Agent: UPnP/1.0,X-AV-Physical-Unit-Info: pa="BRAVIA KDL-40HX800";,X-AV-Client-Info: av=5.0; cn="Sony Corporation"; mn="BRAVIA KDL-40HX800"; mv="1.7";])
2011-05-10 15:31:03,841 DEBUG [RendererDAOImpl] Reading a Renderer with ip address 192.168.2.5
2011-05-10 15:31:03,843 DEBUG [RendererDAOImpl] Reading a Renderer with ip address 192.168.2.5
2011-05-10 15:31:03,846 DEBUG [DeviceDescriptionRequestHandler] Sending DeviceDescription XML back using profile 'Sony Bravia TV'
2011-05-10 15:31:03,877 DEBUG [WebServer] Incoming connection from /192.168.2.5:60679
2011-05-10 15:31:03,880 DEBUG [ServiceDescriptionRequestHandler] ServiceDescription request received for service ConnectionManager
2011-05-10 15:31:03,881 DEBUG [ServiceDescriptionRequestHandler] Sending ServiceDescription XML back
2011-05-10 15:31:03,918 DEBUG [WebServer] Incoming connection from /192.168.2.5:60680
2011-05-10 15:31:03,919 DEBUG [ServiceDescriptionRequestHandler] ServiceDescription request received for service ContentDirectory
2011-05-10 15:31:03,920 DEBUG [ServiceDescriptionRequestHandler] Sending ServiceDescription XML back
2011-05-10 15:31:03,987 DEBUG [WebServer] Incoming connection from /192.168.2.5:60681
2011-05-10 15:31:03,988 DEBUG [ServiceControlRequestHandler] ServiceControl request received for action '"urn:schemas-upnp-org:service:ContentDirectory:1#GetSortCapabilities"' from 192.168.2.5:
2011-05-10 15:31:03,989 DEBUG [RendererDAOImpl] Reading a Renderer with ip address 192.168.2.5
2011-05-10 15:31:04,004 DEBUG [ServiceControlRequestHandler] Returning OK SOAP message
2011-05-10 15:31:04,015 DEBUG [WebServer] Incoming connection from /192.168.2.5:60682
2011-05-10 15:31:04,017 DEBUG [ServiceControlRequestHandler] ServiceControl request received for action '"urn:schemas-upnp-org:service:ConnectionManager:1#GetProtocolInfo"' from 192.168.2.5:
2011-05-10 15:31:04,017 DEBUG [RendererDAOImpl] Reading a Renderer with ip address 192.168.2.5
2011-05-10 15:31:04,024 DEBUG [ConnectionManager] Sending protocol info using profile 'Sony Bravia TV'
2011-05-10 15:31:04,087 DEBUG [ServiceControlRequestHandler] Returning OK SOAP message
2011-05-10 15:31:08,516 DEBUG [DiscoveryAdvertisementNotifier] Multicasting SSDP alive using interface eth0 (eth0) and address 192.168.2.10, timeout = 0
2011-05-10 15:31:08,518 DEBUG [DiscoveryAdvertisementNotifier] Sending 6 'alive' messages describing device b417b37c-4030-3c89-bb6e-b5e8798e235b
2011-05-10 15:31:09,125 DEBUG [WebServer] Incoming connection from /192.168.2.5:60698
2011-05-10 15:31:09,127 DEBUG [DeviceDescriptionRequestHandler] DeviceDescription request received for device b417b37c-4030-3c89-bb6e-b5e8798e235b from 192.168.2.5 (headers = [Host: 192.168.2.10:8895,Date: Tue, 10 May 2011 15:31:08 GMT,User-Agent: UPnP/1.0,X-AV-Physical-Unit-Info: pa="BRAVIA KDL-40HX800";,X-AV-Client-Info: av=5.0; cn="Sony Corporation"; mn="BRAVIA KDL-40HX800"; mv="1.7";])
2011-05-10 15:31:09,128 DEBUG [RendererDAOImpl] Reading a Renderer with ip address 192.168.2.5
2011-05-10 15:31:09,130 DEBUG [RendererDAOImpl] Reading a Renderer with ip address 192.168.2.5
2011-05-10 15:31:09,136 DEBUG [DeviceDescriptionRequestHandler] Sending DeviceDescription XML back using profile 'Sony Bravia TV'
2011-05-10 15:31:09,170 DEBUG [WebServer] Incoming connection from /192.168.2.5:60699
2011-05-10 15:31:09,171 DEBUG [ServiceDescriptionRequestHandler] ServiceDescription request received for service ConnectionManager
2011-05-10 15:31:09,173 DEBUG [ServiceDescriptionRequestHandler] Sending ServiceDescription XML back
2011-05-10 15:31:09,226 DEBUG [WebServer] Incoming connection from /192.168.2.5:60700
2011-05-10 15:31:09,227 DEBUG [ServiceDescriptionRequestHandler] ServiceDescription request received for service ContentDirectory
2011-05-10 15:31:09,229 DEBUG [ServiceDescriptionRequestHandler] Sending ServiceDescription XML back
2011-05-10 15:31:09,296 DEBUG [WebServer] Incoming connection from /192.168.2.5:60701
2011-05-10 15:31:09,297 DEBUG [ServiceControlRequestHandler] ServiceControl request received for action '"urn:schemas-upnp-org:service:ContentDirectory:1#GetSortCapabilities"' from 192.168.2.5:
2011-05-10 15:31:09,297 DEBUG [RendererDAOImpl] Reading a Renderer with ip address 192.168.2.5
2011-05-10 15:31:09,312 DEBUG [ServiceControlRequestHandler] Returning OK SOAP message
2011-05-10 15:31:09,321 DEBUG [WebServer] Incoming connection from /192.168.2.5:60702
2011-05-10 15:31:09,325 DEBUG [ServiceControlRequestHandler] ServiceControl request received for action '"urn:schemas-upnp-org:service:ConnectionManager:1#GetProtocolInfo"' from 192.168.2.5:
2011-05-10 15:31:09,325 DEBUG [RendererDAOImpl] Reading a Renderer with ip address 192.168.2.5
2011-05-10 15:31:09,333 DEBUG [ConnectionManager] Sending protocol info using profile 'Sony Bravia TV'
2011-05-10 15:31:09,369 DEBUG [ServiceControlRequestHandler] Returning OK SOAP message
2011-05-10 15:31:09,643 DEBUG [WebServer] Incoming connection from /192.168.2.5:60703
2011-05-10 15:31:09,645 DEBUG [DeviceDescriptionRequestHandler] DeviceDescription request received for device b417b37c-4030-3c89-bb6e-b5e8798e235b from 192.168.2.5 (headers = [Host: 192.168.2.10:8895,Date: Tue, 10 May 2011 15:31:08 GMT,User-Agent: UPnP/1.0,X-AV-Physical-Unit-Info: pa="BRAVIA KDL-40HX800";,X-AV-Client-Info: av=5.0; cn="Sony Corporation"; mn="BRAVIA KDL-40HX800"; mv="1.7";])
2011-05-10 15:31:09,645 DEBUG [RendererDAOImpl] Reading a Renderer with ip address 192.168.2.5
2011-05-10 15:31:09,647 DEBUG [RendererDAOImpl] Reading a Renderer with ip address 192.168.2.5
2011-05-10 15:31:09,650 DEBUG [DeviceDescriptionRequestHandler] Sending DeviceDescription XML back using profile 'Sony Bravia TV'
2011-05-10 15:31:09,682 DEBUG [WebServer] Incoming connection from /192.168.2.5:60704
2011-05-10 15:31:09,683 DEBUG [ServiceDescriptionRequestHandler] ServiceDescription request received for service ConnectionManager
2011-05-10 15:31:09,684 DEBUG [ServiceDescriptionRequestHandler] Sending ServiceDescription XML back
2011-05-10 15:31:09,726 DEBUG [WebServer] Incoming connection from /192.168.2.5:60705
2011-05-10 15:31:09,727 DEBUG [ServiceDescriptionRequestHandler] ServiceDescription request received for service ContentDirectory
2011-05-10 15:31:09,728 DEBUG [ServiceDescriptionRequestHandler] Sending ServiceDescription XML back
2011-05-10 15:31:09,792 DEBUG [WebServer] Incoming connection from /192.168.2.5:60706
2011-05-10 15:31:09,793 DEBUG [ServiceControlRequestHandler] ServiceControl request received for action '"urn:schemas-upnp-org:service:ContentDirectory:1#GetSortCapabilities"' from 192.168.2.5:
2011-05-10 15:31:09,794 DEBUG [RendererDAOImpl] Reading a Renderer with ip address 192.168.2.5
2011-05-10 15:31:09,804 DEBUG [ServiceControlRequestHandler] Returning OK SOAP message
2011-05-10 15:31:09,813 DEBUG [WebServer] Incoming connection from /192.168.2.5:60707
2011-05-10 15:31:09,815 DEBUG [ServiceControlRequestHandler] ServiceControl request received for action '"urn:schemas-upnp-org:service:ConnectionManager:1#GetProtocolInfo"' from 192.168.2.5:
2011-05-10 15:31:09,815 DEBUG [RendererDAOImpl] Reading a Renderer with ip address 192.168.2.5
2011-05-10 15:31:09,829 DEBUG [ConnectionManager] Sending protocol info using profile 'Sony Bravia TV'
2011-05-10 15:31:09,875 DEBUG [ServiceControlRequestHandler] Returning OK SOAP message
2011-05-10 15:31:10,322 DEBUG [DiscoveryAdvertisementNotifier] Will advertise again in 00:00:10
2011-05-10 15:31:20,323 DEBUG [DiscoveryAdvertisementNotifier] Multicasting SSDP alive using interface eth0 (eth0) and address 192.168.2.10, timeout = 0
2011-05-10 15:31:20,324 DEBUG [DiscoveryAdvertisementNotifier] Sending 6 'alive' messages describing device b417b37c-4030-3c89-bb6e-b5e8798e235b
2011-05-10 15:31:20,931 DEBUG [WebServer] Incoming connection from /192.168.2.5:60708
2011-05-10 15:31:20,932 DEBUG [DeviceDescriptionRequestHandler] DeviceDescription request received for device b417b37c-4030-3c89-bb6e-b5e8798e235b from 192.168.2.5 (headers = [Host: 192.168.2.10:8895,Date: Tue, 10 May 2011 15:31:19 GMT,User-Agent: UPnP/1.0,X-AV-Physical-Unit-Info: pa="BRAVIA KDL-40HX800";,X-AV-Client-Info: av=5.0; cn="Sony Corporation"; mn="BRAVIA KDL-40HX800"; mv="1.7";])
2011-05-10 15:31:20,932 DEBUG [RendererDAOImpl] Reading a Renderer with ip address 192.168.2.5
2011-05-10 15:31:20,934 DEBUG [RendererDAOImpl] Reading a Renderer with ip address 192.168.2.5
2011-05-10 15:31:20,938 DEBUG [DeviceDescriptionRequestHandler] Sending DeviceDescription XML back using profile 'Sony Bravia TV'
2011-05-10 15:31:20,983 DEBUG [WebServer] Incoming connection from /192.168.2.5:60709
2011-05-10 15:31:20,984 DEBUG [ServiceDescriptionRequestHandler] ServiceDescription request received for service ConnectionManager
2011-05-10 15:31:20,985 DEBUG [ServiceDescriptionRequestHandler] Sending ServiceDescription XML back
2011-05-10 15:31:21,024 DEBUG [WebServer] Incoming connection from /192.168.2.5:60710
2011-05-10 15:31:21,025 DEBUG [ServiceDescriptionRequestHandler] ServiceDescription request received for service ContentDirectory
2011-05-10 15:31:21,027 DEBUG [ServiceDescriptionRequestHandler] Sending ServiceDescription XML back
2011-05-10 15:31:21,090 DEBUG [WebServer] Incoming connection from /192.168.2.5:60711
2011-05-10 15:31:21,092 DEBUG [ServiceControlRequestHandler] ServiceControl request received for action '"urn:schemas-upnp-org:service:ContentDirectory:1#GetSortCapabilities"' from 192.168.2.5:
2011-05-10 15:31:21,092 DEBUG [RendererDAOImpl] Reading a Renderer with ip address 192.168.2.5
2011-05-10 15:31:21,103 DEBUG [ServiceControlRequestHandler] Returning OK SOAP message
2011-05-10 15:31:21,113 DEBUG [WebServer] Incoming connection from /192.168.2.5:60712
2011-05-10 15:31:21,114 DEBUG [ServiceControlRequestHandler] ServiceControl request received for action '"urn:schemas-upnp-org:service:ConnectionManager:1#GetProtocolInfo"' from 192.168.2.5:
2011-05-10 15:31:21,115 DEBUG [RendererDAOImpl] Reading a Renderer with ip address 192.168.2.5
2011-05-10 15:31:21,121 DEBUG [ConnectionManager] Sending protocol info using profile 'Sony Bravia TV'
2011-05-10 15:31:21,160 DEBUG [ServiceControlRequestHandler] Returning OK SOAP message
2011-05-10 15:31:21,437 DEBUG [WebServer] Incoming connection from /192.168.2.5:60713
2011-05-10 15:31:21,440 DEBUG [DeviceDescriptionRequestHandler] DeviceDescription request received for device b417b37c-4030-3c89-bb6e-b5e8798e235b from 192.168.2.5 (headers = [Host: 192.168.2.10:8895,Date: Tue, 10 May 2011 15:31:20 GMT,User-Agent: UPnP/1.0,X-AV-Physical-Unit-Info: pa="BRAVIA KDL-40HX800";,X-AV-Client-Info: av=5.0; cn="Sony Corporation"; mn="BRAVIA KDL-40HX800"; mv="1.7";])
2011-05-10 15:31:21,440 DEBUG [RendererDAOImpl] Reading a Renderer with ip address 192.168.2.5
2011-05-10 15:31:21,441 DEBUG [RendererDAOImpl] Reading a Renderer with ip address 192.168.2.5
2011-05-10 15:31:21,445 DEBUG [DeviceDescriptionRequestHandler] Sending DeviceDescription XML back using profile 'Sony Bravia TV'
2011-05-10 15:31:21,476 DEBUG [WebServer] Incoming connection from /192.168.2.5:60714
2011-05-10 15:31:21,477 DEBUG [ServiceDescriptionRequestHandler] ServiceDescription request received for service ConnectionManager
2011-05-10 15:31:21,478 DEBUG [ServiceDescriptionRequestHandler] Sending ServiceDescription XML back
2011-05-10 15:31:21,516 DEBUG [WebServer] Incoming connection from /192.168.2.5:60715
2011-05-10 15:31:21,517 DEBUG [ServiceDescriptionRequestHandler] ServiceDescription request received for service ContentDirectory
2011-05-10 15:31:21,518 DEBUG [ServiceDescriptionRequestHandler] Sending ServiceDescription XML back
2011-05-10 15:31:21,583 DEBUG [WebServer] Incoming connection from /192.168.2.5:60716
2011-05-10 15:31:21,584 DEBUG [ServiceControlRequestHandler] ServiceControl request received for action '"urn:schemas-upnp-org:service:ContentDirectory:1#GetSortCapabilities"' from 192.168.2.5:
2011-05-10 15:31:21,585 DEBUG [RendererDAOImpl] Reading a Renderer with ip address 192.168.2.5
2011-05-10 15:31:21,596 DEBUG [ServiceControlRequestHandler] Returning OK SOAP message
2011-05-10 15:31:21,607 DEBUG [WebServer] Incoming connection from /192.168.2.5:60717
2011-05-10 15:31:21,609 DEBUG [ServiceControlRequestHandler] ServiceControl request received for action '"urn:schemas-upnp-org:service:ConnectionManager:1#GetProtocolInfo"' from 192.168.2.5:
2011-05-10 15:31:21,609 DEBUG [RendererDAOImpl] Reading a Renderer with ip address 192.168.2.5
2011-05-10 15:31:21,616 DEBUG [ConnectionManager] Sending protocol info using profile 'Sony Bravia TV'
2011-05-10 15:31:21,641 DEBUG [ServiceControlRequestHandler] Returning OK SOAP message
2011-05-10 15:31:22,128 DEBUG [DiscoveryAdvertisementNotifier] Will advertise again in 00:01:01
2011-05-10 15:31:22,703 INFO [LibraryAdditionsCheckerThread] Started looking for newly added files
2011-05-10 15:31:22,711 DEBUG [RepositoryDAOImpl] Reading all Repositories
2011-05-10 15:31:22,730 INFO [LibraryUpdatesCheckerThread] Started looking for updates to currently shared files
2011-05-10 15:31:22,731 DEBUG [RepositoryDAOImpl] Reading all Repositories
2011-05-10 15:32:23,436 DEBUG [DiscoveryAdvertisementNotifier] Multicasting SSDP alive using interface eth0 (eth0) and address 192.168.2.10, timeout = 0
2011-05-10 15:32:23,539 DEBUG [DiscoveryAdvertisementNotifier] Sending 6 'alive' messages describing device b417b37c-4030-3c89-bb6e-b5e8798e235b
2011-05-10 15:32:25,343 DEBUG [DiscoveryAdvertisementNotifier] Will advertise again in 00:01:29
Post Tue May 10, 2011 4:47 pm
It says
so the -Dserviio.remoteHost is not done properly. The line above must include the IP you use with this parameter - and it must be the IP that your console can connect to (IP of this Serviio server).
phn2
Post Tue May 10, 2011 6:46 pm
Hello.
Finally som succes; when searching for Dserviio on this forum turns up
To be able to connect from the xp client you have to:
a- modify the ServiioConsole.exe.vmoptions on the xp side, so that it includes the ip of the server. Just add the line
-Dserviio.remoteHost=192.168.xxx.yyy
in the text file
Still tinkering, but think it works now...
Thx all!
Return to User experiences
