need some help
cooltwou
Post Tue May 10, 2011 4:01 am
need some help
i have this program on my computer & i was try to use it last year & i had it showing up on the Samsung tv my dad has but then i got a pop or something like that saying to use windows media player & i clicked that & now it shows windows media player instead of this program what do i do to fix it where this shows up instead of windows media player
Post Tue May 10, 2011 10:59 am
Re: need some help
What is the model number of the TV?
Post Tue May 10, 2011 11:40 am
Re: need some help
when on the media server page press the RED button and select serviio ( should be same on all models )
you can see it on bottom left corner of the image, although maybe in slightly different place on your model. :)
cooltwou
Post Tue May 10, 2011 3:11 pm
Re: need some help
it is a series 6 it is either 6400 or 6500 & when you hit the device but this program does not show there are 2 that show up the tversity that i use upstairs & windows media player
Post Tue May 10, 2011 3:51 pm
Re: need some help
is serviio deffinately running?
have you tried disabling the WMP network service ?
cooltwou
Post Tue May 10, 2011 4:33 pm
Re: need some help
it says the sever is running & how do i disabling the WMP network service
Post Tue May 10, 2011 4:51 pm
Re: need some help
Post Tue May 10, 2011 5:27 pm
Re: need some help
Follow ths steps below to disable Windows Media Player (WMP) Network Sharing Service.
1. Open Control Panel and in Control Panel's left pane, click on Classic View.
2. In Control Panel's right pane, double-click on Administrative Tools.
3. In Administrative Tools double-click on the Services icon.
4. If the user Account Control dialog box appears, click on the [Continue] button.
5. In the Services window that appears, locate "Windows Media Player Network sharing Service" and double-click on it.
6. In the Windows Media Player Network sharing Service Properties dialog box, in the Startup type: drop-down-list, select Disabled.
7. Click on the [Apply] button, then on the [OK] button.
Now if you go back to the Services window, the value next to Windows Media Player Network Sharing Service in the Startup Type column should be Disabled.
