Sony Bravia 2010 series
Post Mon Apr 25, 2011 6:34 pm
Re: [Readme] Sony Bravia 2010 series
____________UPDATE____________
See first post
viewtopic.php?f=11&t=425#p2339
- Add following profiles on <MediaFormatProfile> section:
AVC_TS_HP_HD_MPEG1_L2_T
AVC_TS_HP_SD_MPEG1_L2_T
AVC_TS_HP_HD_MPEG1_L2_ISO
AVC_TS_HP_SD_MPEG1_L2_ISO
Che0407
Post Fri May 06, 2011 6:27 pm
Hi so much to look through here, can i ask a question please?
Which files can be played on sony bravia tv's? Can you play movies?
Sorry but just wanted to keep it simple and not bother you guys too much.
cheers
Post Sat May 07, 2011 5:19 pm
Che0407 wrote:...Which files can be played on sony bravia tv's? Can you play movies?
Read the first post of the topic.
here
THog79
Post Mon May 09, 2011 3:16 pm
My apologies if this has already been covered however i have searched and not found a response.
I have a Sony XBR HX909 and am running Serviio with great success however i've run into a couple of problems.
1) I have a few mkv files that the default audio track is in Russian. I have used MKV tools to remove the Russian track however when i go to play the newly edited mkv file, i get the response that the serveris not accessible. Does MKV tools do another change to the file making it no longer compatible with my TV? I tried replaying a few times and about 1 out of 10 tries it will start playing for a few minutes and then the message pops up again.
2) I downloaded a season of a TV show through iTunes, i note that m4v files are listed as being able to transcode however none of the files are showing up on my TV through Serviio. I ensured i had it pointing to the correct folder. Is this to do with DRM protection or is there a setting that i can change in Serviio to correct this?
Any help would be much appreciated. Thanks!
Post Mon May 09, 2011 3:32 pm
THog79 wrote:I have a Sony XBR HX909 and am running Serviio with great success however i've run into a couple of problems.
Please read this topic and provide GetProtocolInfo sink result of your XBR device?
THog79 wrote:1) I have a few mkv files that the default audio track is in Russian.
Could you provide "ffmpeg -i" result of the original file? (see my signature links)
THog79 wrote:I have used MKV tools to remove the Russian track however when i go to play the newly edited mkv file, i get the response that the server is not accessible.
What MKV tools ?
Could you provide "ffmpeg -i" result of the modified mkv file?
THog79 wrote:I tried replaying a few times and about 1 out of 10 tries it will start playing for a few minutes and then the message pops up again.
Are you Wired or Wifi connected?
THog79 wrote:2) I downloaded a season of a TV show through iTunes, i note that m4v files are listed as being able to transcode however none of the files are showing up on my TV through Serviio.
Could you provide "ffmpeg -i" result of this file?
THog79
Post Mon May 09, 2011 10:09 pm
Hello, I have tried pasting all the ffmpeg info below. I posted each one after each question. Hopefully that is the correct data. Thanks
Microsoft Windows [Version 6.0.6002]
Copyright (c) 2006 Microsoft Corporation. All rights reserved.
C:\Users\Trevor>cd "\program files\serviio\lib
C:\Program Files\Serviio\lib>ffmpeg.exe -i "C:\Users\Trevor\Documents\Videos\Breaking Bad Season 3 HD\Breaking Bad S3E3 Original.mkv"
configuration: --enable-static --disable-shared --disable-shared --disable-ffplay --disable-ffserver --enable-memalign-hack --enable-libmp3lame --arch=x86 --enable-runtime-cpudetect --enable-32threads --target-os=mingw32 --cross-prefix=i686-mingw32-
libavutil 50.36. 0 / 50.36. 0
libavcore 0.16. 0 / 0.16. 0
libavfilter 1.72. 0 / 1.72. 0
libswscale 0.12. 0 / 0.12. 0
[matroska,webm @ 003dbf40] max_analyze_duration reached
[matroska,webm @ 003dbf40] Estimating duration from bitrate, this may be inaccurate
Seems stream 0 codec frame rate differs from container frame rate: 47.95 (5994/125) -> 23.98 (5994/250)
Input #0, matroska,webm, from 'C:\Users\Trevor\Documents\Videos\Breaking Bad Season 3 HD\Breaking Bad S3E3 Original.mkv':
title : Breaking Bad 3x03 - I.F.T. @ RuTracker.org
Duration: 00:47:12.73, start: 0.000000, bitrate: 1344 kb/s
Chapter #0.0: start 0.000000, end 255.025000
title : Chapter 01
Chapter #0.1: start 255.025000, end 963.487000
title : Chapter 02
Chapter #0.2: start 963.487000, end 1559.061000
title : Chapter 03
Chapter #0.3: start 1559.061000, end 2106.500000
title : Chapter 04
Chapter #0.4: start 2106.500000, end 2794.500000
title : Chapter 05
Chapter #0.5: start 2794.500000, end 2832.736000
title : Chapter 06
Stream #0.0(eng): Video: h264, yuv420p, 1280x720 [PAR 1:1 DAR 16:9], 23.98 fps, 23.98 tbr, 1k tbn, 47.95 tbc
title : Breaking.Bad.S03E03.720p.WEB-DL.DD5.1.H.264-RTARHD
Stream #0.1(rus): Audio: ac3, 48000 Hz, 5.1, s16, 448 kb/s
title : Dolby Digital 5.1 @ 448 kbps @ Foxlight
Stream #0.2(rus): Audio: ac3, 48000 Hz, 5.1, s16, 448 kb/s
title : Dolby Digital 5.1 @ 448 kbps @ Kubik-V-Kube
Stream #0.3(eng): Audio: ac3, 48000 Hz, 5.1, s16, 448 kb/s
Stream #0.4(rus): Subtitle: ass
title : Russian @ ASS @ Forced
Stream #0.5(rus): Subtitle: ass
title : Russian @ ASS @ Full
Stream #0.6(eng): Subtitle: ass
title : English @ ASS
Stream #0.7: Attachment: [0][0][0][0] / 0x0000
filename : corbel_0.ttf
Stream #0.8: Attachment: [0][0][0][0] / 0x0000
filename : GARA_0.ttf
Stream #0.9: Attachment: [0][0][0][0] / 0x0000
filename : Candara_0.ttf
Stream #0.10: Attachment: [0][0][0][0] / 0x0000
filename : HermesCTT Regular_0.ttf
Stream #0.11: Attachment: [0][0][0][0] / 0x0000
filename : GOTHIC_0.ttf
What MKV tools ? MKVvergeGUI
C:\Program Files\Serviio\lib>ffmpeg.exe -i "c:\users\trevor\documents\videos\breaking bad season 3 hd\breaking bad s3e3 modified.mkv"
configuration: --enable-static --disable-shared --disable-shared --disable-ffplay --disable-ffserver --enable-memalign-hack --enable-libmp3lame --arch=x86 --enable-runtime-cpudetect --enable-w32threads --target-os=mingw32 --cross-prefix=i686-mingw32-
[matroska,webm @ 002ebf40] max_analyze_duration reached
[matroska,webm @ 002ebf40] Estimating duration from bitrate, this may be inaccurate
Input #0, matroska,webm, from 'c:\users\trevor\documents\videos\breaking bad season 3 hd\breaking bad s3e3 modified.mkv':
Duration: 00:47:12.73, start: 0.000000, bitrate: 448 kb/s
title : Chapter 01
title : Chapter 02
title : Chapter 03
title : Chapter 04
title : Chapter 05
title : Chapter 06
Stream #0.1(eng): Audio: ac3, 48000 Hz, 5.1, s16, 448 kb/s
Stream #0.2(rus): Subtitle: ass
Stream #0.3(rus): Subtitle: ass
Stream #0.4(eng): Subtitle: ass
Stream #0.5: Attachment: [0][0][0][0] / 0x0000
Stream #0.6: Attachment: [0][0][0][0] / 0x0000
Are you Wired or Wifi connected? Wired
C:\Program Files\Serviio\lib>ffmpeg.exe -i "C:\Users\Trevor\Music\iTunes\iTunesMusic\TV Shows\Breaking Bad\03 I.F.T. (HD).m4v"
[mov,mp4,m4a,3gp,3g2,mj2 @ 014fbf30] max_analyze_duration reached
Seems stream 1 codec frame rate differs from container frame rate: 2997.00 (2997/1) -> 23.98 (2997/125)
Input #0, mov,mp4,m4a,3gp,3g2,mj2, from 'C:\Users\Trevor\Music\iTunes\iTunes Music\TV Shows\Breaking Bad\03 I.F.T. (HD).m4v':
major_brand : M4V
minor_version : 0
compatible_brands: M4V mp42isom
creation_time : 2010-04-27 07:21:02
title : I.F.T.
artist : Breaking Bad
album : Breaking Bad, Season 3
genre : Drama
track : 3
date : 2010-04-04T07:00:00Z
copyright : ┬® 2010 Sony Pictures Television Inc. All Rights Reserved.
description : Walt ignores SkylerÔÇÖs demands, increasing the tension between them and pushing her to break bad.
show : Breaking Bad
episode_id : 0303
synopsis : Walt ignores SkylerÔÇÖs demands, increasing the tension between them and pushing her to break bad. Saul entreats Jesse to persuade Walt to keep cooking. Still suffering from panic and anxiety attacks, Hank crosses a line at work.
Duration: 00:47:09.54, start: 0.000000, bitrate: 4586 kb/s
Stream #0.0(eng): Audio: aac, 48000 Hz, stereo, s16, 151 kb/s
Stream #0.1(eng): Video: drmi / 0x696D7264, 1280x720, 4042 kb/s, PAR 1:1 DAR 16:9, 23.98 fps, 23.98 tbr, 2997 tbn, 2997 tbc
Stream #0.2(eng): Audio: drms / 0x736D7264, 48000 Hz, 6 channels, 384 kb/s
Post Tue May 10, 2011 7:02 pm
THog79 wrote:_____________________________
... Stream #0.0(eng): Video: h264, yuv420p, 1280x720 [PAR 1:1 DAR 16:9], 23.98 fps, 23.98 tbr, 1k tbn, 47.95 tbc
... Stream #0.1(rus): Audio: ac3, 48000 Hz, 5.1, s16, 448 kb/s
... Stream #0.2(rus): Audio: ac3, 48000 Hz, 5.1, s16, 448 kb/s
... Stream #0.3(eng): Audio: ac3, 48000 Hz, 5.1, s16, 448 kb/s
... Stream #0.4(rus): Subtitle: ass
... Stream #0.5(rus): Subtitle: ass
... Stream #0.6(eng): Subtitle: ass
Does this original play on your Sony device, or do you have same result than your modified version?
THog79 wrote:I have used MKVmergeGUI tools to remove the Russian track however when i go to play the newly edited mkv file, i get the response that the server is not accessible.
______________________________
Could you provide "MediaInfo" result of your modified file?
This mkv file must be remuxed into mpeg2 transport stream with video codec copy ac3 audio transcoded
Turn on detailed logging (see signature) you should be able to see the FFmpeg command that is used for the transcode.
Try executing the command manually in a terminal window and post the (log or error) result here.
_________________
03 I.F.T. (HD).m4v"
drmi video codec is not supported by serviio.
drms audio codec is not supported by serviio.
Check the detailed logging file, you will probably found errors about that.
Zip, do you want I to create a ticket for that?
Post Tue May 10, 2011 8:01 pm
I assume drmX codecs mean it's a drm protected file so will not play on anything.
Post Tue May 10, 2011 8:36 pm
zip wrote:I assume drmX codecs mean it's a drm protected file so will not play on anything.
i can confirm DRMS and DRMI are digital rights management protected files and will not play.
there are ways to remove the protection and convert teh files but i will not talk about that here as it is totaly illegal.
THog79
Post Tue May 10, 2011 11:32 pm
Thanks for the help everyone. Illico, yes the original file plays fine on my tv, the edited one removing the Russian audio track does not. From what I understand there is no way to select the audio track through Serviio so the only way was to remove it. I didn't select any other options when remuxing, just unchecked the Russian track. I'll try playing with the options to ensure the output is in the right format.
Guess there isn't a lot I can do (legally) with the iTunes files. Good way to force people to buy an Apple TV. Seems like a waste when the tv already has DLNA.
Cheers
Post Wed May 11, 2011 9:50 am
Re: Sony Bravia 2010 series
____________INFO____________
This topic has become too large, so it has been closed.
You will found the sticky Readme-only topic : [Readme] Sony Bravia 2010 series
For support, create new specific topic
Previous
