wrong id of movies and series?
wraithbone
Post Sun May 08, 2011 3:14 pm
Hello.
First of all i LOVE serviio!
though im missing some way to correct wrong ID's of tv series. i have even tried to see "V 2009" to be identified as 20 times the movie "The Hangover" ?!
Anyone else have these problems? if so how do i fix this ? :-/
Post Sun May 08, 2011 3:33 pm
Re: wrong id of movies and series?
that would be a problem with the online metadata source rather than serviio.
wraithbone
Post Sun May 08, 2011 3:39 pm
I do agree. Serviio does its part. But im missing a way to correct the wrong results.
A good example is Plex for the mac. It has a great interface to correct match errors. Let me search for other matches and so on.
Is there no interface or way to do this in serviio ? in some config files maybe?
How does serviio match the names of the series ? on folder names, file names, a combo?
Im not after serviio - in fact its a f****** GREAT program! the best i've seen! - Just need to learn how to correct the errors.
Thanks! :)
Post Sun May 08, 2011 5:23 pm
Post Sun May 08, 2011 5:54 pm
give us a file name example, including the folder name.
wraithbone
Post Sun May 08, 2011 6:04 pm
Thank you i will read the thread :)
i deleted the V 2009 series as it annoyed me. still have these though:
Filename: spongebob.squarepants.s01.pizza.delivery.xvid-lol.avi
i can find more examples later if you need them?
wraithbone
Post Sun May 08, 2011 6:49 pm
`Btw. The result of the above series is "Spongebob The Movie"
Post Sun May 08, 2011 8:27 pm
the episode name is not following the naming convention described here: http://www.serviio.org/index.php?option ... icle&id=12
Post Mon May 09, 2011 11:29 am
One thing that I have started doing, it before I load in a series to serviio. I go to http://www.thetvdb.com and verify how series name is formatted there. That way I can ensure that the file name has this information correct. This ensures that the file gets the correct metadata.
Post Mon May 09, 2011 2:42 pm
moltra wrote:One thing that I have started doing, it before I load in a series to serviio. I go to http://www.thetvdb.com and verify how series name is formatted there. That way I can ensure that the file name has this information correct. This ensures that the file gets the correct metadata.
+1 same process
wraithbone
Post Wed May 11, 2011 12:53 pm
Thanks everyone. Thats the info i needed :)
I'll go fix my filenames now! :)
Christopher_Povey
Post Tue Jun 07, 2011 5:50 pm
Where do you find the filename layout on that site? For example I have "Sanctuary.US.s03e12.avi". It does not appear under the "Series" tab, yet Sanctuary is on that website!
Note to OP: V.2009.s02e01.avi adds to the "Series" tab correctly...
Chris
Running Serviio on Intel Q6700 Windows 7 Ultimate x64 PC feeding a Sony BDP-S570, Pansonic TX-L37G20B, and a XBox 360.
Managed with Serviidroid via HTC One X
Post Wed Jun 08, 2011 8:55 am
You can turn on detailed logging and you'll see what search term it's actually using when talking to the online site. Serviio does parse the filename, removes bits and pieces from it to try to guess the most appropriate name, but ion some case that might not work as expected.
Christopher_Povey
Post Wed Jun 08, 2011 5:17 pm
zip wrote:You can turn on detailed logging and you'll see what search term it's actually using when talking to the online site. Serviio does parse the filename, removes bits and pieces from it to try to guess the most appropriate name, but ion some case that might not work as expected.
It didn't like the US bit. Once removed it added them to the series tab with the episode name.
Chris
ThaDraGun
Post Thu Aug 18, 2011 11:12 pm
I'm having some problems with names too.
Here are 2 movies that don't show up in "Movies" listing and they don't have the movie cover either.
Iron Man (2008)
Iron Man 2 (2010)
Edit: There are quite a few that Im having a problem with, here are some more:
Gone Baby Gone (2007)
127 Hours (2010)
44 Inch Chest (2009)
Green Hornet, The (2011)
Knight and Day (2010)
Robin Hood (2010)
Skyline (2010)
That's how they are named.. I thought it was because the year was wrong or something but if I do a search on themoviedb.org they do show up. Weird.
Post Sun Aug 21, 2011 7:42 pm
+1 same process
i use a renamer program to Auto rename all my eps correctly before adding to my library, its in teh third party forum if you wish to try it.
Post Mon Aug 22, 2011 9:42 am
ThaDraGun wrote:I'm having some problems with names too.
Iron Man (2008)
Iron Man 2 (2010)
127 Hours (2010)
Robin Hood (2010)
Skyline (2010)
It's possible that themoviedb.org was down or could not be connected to while the metadata scan was running. Try to click 'Refresh video metadata' to scan for all your videos again.
Return to User experiences
