DTS Audio Encoded MKV issues
dpolak
Post Fri May 13, 2011 12:04 am
Everyone,
I have Serviio running on SuSE Linux and it will not play or display MKV files encoded with DTS audio. Serviio on Windows 7 works fine, but not Linux.
Does anyone know how to resolve this?
Thank you!
Regards,
Don
Post Fri May 13, 2011 1:22 am
Re: DTS Audio Encoded MKV issues
dpolak wrote:Everyone,
Thank you!
Regards,
Don
make sure you use the ffmpeg from the download page and then you wont have this issue. :)
Post Fri May 13, 2011 9:10 am
I assume it's the same problem as here: viewtopic.php?f=5&t=2403
Post Fri May 13, 2011 3:35 pm
zip wrote:I assume it's the same problem as here: viewtopic.php?f=5&t=2403
i made the same conclusion zip :)
dpolak
Post Sun May 15, 2011 2:11 pm
Thanks guys. I went and downloaded both files from the downloads page. I used checkinstall to create RPMs of the files because I was having difficulties and before making a mess I wanted a good way to keep my server clean.
When I compiled lame as instructed in the README.txt it worked fine. When I did it for ffmpeg, using the config line in the README.txt for MacOS, it errored out.
Does anyone out there have it running on OpenSuSE 11.2-3? I have no issues with the system other than the DTS encoding and it would be nice to fix rather than remuxing the files.
Any help would be greatly appreciated!
Don
