will serviio use the metadata in Flac files?
zip wrote:It does use it.
zip wrote:It exctracts metadata, like author, title, etc. Similar to mp3 tags.
Cerberus wrote:A: I would like to be able to see ALL metadata tag fields,. This might need a rewritten renderer FW, I suppose.
That would be the renderer, and not serviio.
B: I would like to be able to search and choose what to play based on metadata content, i e be presented with a menu item "Album" and an item "Composer". Like what happens in iPods. Can this be controlled by just the DLNA server, or will the rendering device need to understand these menu items explicitly?
n3mmr wrote:Cerberus wrote:A: I would like to be able to see ALL metadata tag fields,. This might need a rewritten renderer FW, I suppose.
no reason why serviio couldnt do this BUT if you add to many sections, it could get abit messy and hard to use imho.
Cerberus wrote:n3mmr wrote:Cerberus wrote:A: I would like to be able to see ALL metadata tag fields,. This might need a rewritten renderer FW, I suppose.
Well, if adding composer gets us past the limit, taking "random" away would fix it, and at no conceivable loss whatsoever....
OK, I'm being provocative, but that's actually how I feel.
Configurability, now there is a possible solution...
zip wrote:Adding new categories is ok,as you can always disable then in the console
zip wrote:I mean no problem asking for new browsing categories like Composer as (if you wish it) it can be disabled in the console so that you only have those categories you like on the TV.
Users browsing this forum: Google [Bot] and 18 guests
