[SOLVED] LG BD670 and MKV's
• Page 1 of 2 • 1, 2
Hello All. I recently purchased the LG BD670 because it the spec sheet it stated that it can play MKV files over DLNA. However when I browse from the Bluray player ( BD670 ), I can browse to the folders but when I get to where the actual MKV file is located I receive an error message stating no file found. Any help would be appreciated and thank you in advance.
Re: LG BD670 and MKV's
guzmansoldier wrote:Hello All. I recently purchased the LG BD670 because it the spec sheet it stated that it can play MKV files over DLNA. However when I browse from the Bluray player ( BD670 ), I can browse to the folders but when I get to where the actual MKV file is located I receive an error message stating no file found. Any help would be appreciated and thank you in advance.
have you let the library fully populate this can take 24hours plus on large libraries.
Yes the files have updated. It has been a couple days now.
guzmansoldier wrote:Yes the files have updated. It has been a couple days now.
please provide an ffmpeg -i report of a file that doesnt appear. ( howto in my signiture )
Ok I have to edit this post just a little bit. I have tried many different media server programs so I got the error code messages mixed up. I am able to select the actual mkv file, but when it tries to play I receive the error message, " Cannot play this file. ".
Here is the output of the ffmpeg file.
C:\Program Files (x86)\Serviio\lib>ffmpeg.exe -i "g:\video\2012\title00.mkv"
686-mingw32-
libavutil 50.36. 0 / 50.36. 0
libavcore 0.16. 0 / 0.16. 0
libavfilter 1.72. 0 / 1.72. 0
libswscale 0.12. 0 / 0.12. 0
[matroska,webm @ 0034bd50] invalid dts/pts combination
[matroska,webm @ 0034bd50] Estimating duration from bitrate, this may be inaccur
ate
Seems stream 0 codec frame rate differs from container frame rate: 59.94 (60000/
1001) -> 29.97 (60000/2002)
Input #0, matroska,webm, from 'g:\video\2012\title00.mkv':
Duration: 02:37:45.68, start: 0.000000, bitrate: 10248 kb/s
Chapter #0.0: start 0.000000, end 289.538961
title : Chapter 00
Chapter #0.1: start 289.538961, end 714.196528
title : Chapter 01
Chapter #0.2: start 714.196528, end 931.847294
title : Chapter 02
Chapter #0.3: start 931.847294, end 1317.899628
title : Chapter 03
Chapter #0.4: start 1317.899628, end 1532.947794
title : Chapter 04
Chapter #0.5: start 1532.947794, end 1727.208528
title : Chapter 05
Chapter #0.6: start 1727.208528, end 2077.691994
title : Chapter 06
Chapter #0.7: start 2077.691994, end 2427.074361
title : Chapter 07
Chapter #0.8: start 2427.074361, end 2687.834861
title : Chapter 08
Chapter #0.9: start 2687.834861, end 2941.021128
title : Chapter 09
Chapter #0.10: start 2941.021128, end 3326.272661
title : Chapter 10
Chapter #0.11: start 3326.272661, end 3557.169994
title : Chapter 11
Chapter #0.12: start 3557.169994, end 3909.021494
title : Chapter 12
Chapter #0.13: start 3909.021494, end 4200.612794
title : Chapter 13
Chapter #0.14: start 4200.612794, end 4584.896694
title : Chapter 14
Chapter #0.15: start 4584.896694, end 4898.042861
title : Chapter 15
Chapter #0.16: start 4898.042861, end 5102.914194
title : Chapter 16
Chapter #0.17: start 5102.914194, end 5407.485128
title : Chapter 17
Chapter #0.18: start 5407.485128, end 5794.938861
title : Chapter 18
Chapter #0.19: start 5794.938861, end 6116.526794
title : Chapter 19
Chapter #0.20: start 6116.526794, end 6406.850161
title : Chapter 20
Chapter #0.21: start 6406.850161, end 6679.389094
title : Chapter 21
Chapter #0.22: start 6679.389094, end 7009.418794
title : Chapter 22
Chapter #0.23: start 7009.418794, end 7492.768328
title : Chapter 23
Chapter #0.24: start 7492.768328, end 7743.819128
title : Chapter 24
Chapter #0.25: start 7743.819128, end 8199.607794
title : Chapter 25
Chapter #0.26: start 8199.607794, end 8601.409194
title : Chapter 26
Chapter #0.27: start 8601.409194, end 9465.689000
title : Chapter 27
Stream #0.0(eng): Video: mpeg2video, yuv420p, 720x480 [PAR 32:27 DAR 16:9],
9800 kb/s, PAR 186:157 DAR 279:157, 29.97 fps, 29.97 tbr, 1k tbn, 59.94 tbc
Stream #0.1(eng): Audio: ac3, 48000 Hz, 5.1, s16, 448 kb/s
title : 3/2+1
686-mingw32-
ate
title : Chapter 00
title : Chapter 01
title : Chapter 02
title : Chapter 03
title : Chapter 04
title : Chapter 05
title : Chapter 06
title : Chapter 07
title : Chapter 08
title : Chapter 09
title : Chapter 10
title : Chapter 11
title : Chapter 12
title : Chapter 13
title : Chapter 14
title : Chapter 15
title : Chapter 16
title : Chapter 17
title : Chapter 18
title : Chapter 19
title : Chapter 20
title : Chapter 21
title : Chapter 22
title : Chapter 23
title : Chapter 24
title : Chapter 25
title : Chapter 26
title : Chapter 27
title : 3/2+1
Do you select the "LG BD player" profile? :
Your file must be transcode into MPEGTS with copy video codec (mpeg2video) and audio transcoding into mp3.
Turn on detailed logging (see my signature link) you should be able to see the FFmpeg command that is used for the transcode. Try executing the command manually in a terminal window and post the result here.
configuration: --enable-static --disable-shared --disable-shared --disable-ff
lay --disable-ffserver --enable-memalign-hack --enable-libmp3lame --arch=x86 --
nable-runtime-cpudetect --enable-w32threads --target-os=mingw32 --cross-prefix=
686-mingw32-
[matroska,webm @ 0120bd50] invalid dts/pts combination
[matroska,webm @ 0120bd50] Estimating duration from bitrate, this may be inaccu
ate
title : Chapter 00
title : Chapter 01
title : Chapter 02
title : Chapter 03
title : Chapter 04
title : Chapter 05
title : Chapter 06
title : Chapter 07
title : Chapter 08
title : Chapter 09
title : Chapter 10
title : Chapter 11
title : Chapter 12
title : Chapter 13
title : Chapter 14
title : Chapter 15
title : Chapter 16
title : Chapter 17
title : Chapter 18
title : Chapter 19
title : Chapter 20
title : Chapter 21
title : Chapter 22
title : Chapter 23
title : Chapter 24
title : Chapter 25
title : Chapter 26
title : Chapter 27
title : 3/2+1
686-mingw32-
ate
title : Chapter 00
title : Chapter 01
title : Chapter 02
title : Chapter 03
title : Chapter 04
title : Chapter 05
title : Chapter 06
title : Chapter 07
title : Chapter 08
title : Chapter 09
title : Chapter 10
title : Chapter 11
title : Chapter 12
title : Chapter 13
title : Chapter 14
title : Chapter 15
title : Chapter 16
title : Chapter 17
title : Chapter 18
title : Chapter 19
title : Chapter 20
title : Chapter 21
title : Chapter 22
title : Chapter 23
title : Chapter 24
title : Chapter 25
title : Chapter 26
title : Chapter 27
title : 3/2+1
Do you read my previous post ?
You send twice the same result.
I hope this is what you need. This is from the log file. Also according to the LG documentation it states that it will play MKV's natively, so why should we need to transcode?
2011-05-22 10:13:11,980 INFO [ContentDirectoryDefinitionParser] Parsing ContentDirectory definition
2011-05-22 10:13:12,223 INFO [BrowsingCategoriesMessages] Loaded browsing categories message bundle for locale: en
2011-05-22 10:13:16,111 WARN [ProcessExecutor] Process C:\Program Files (x86)\Serviio\bin\\..\lib/ffmpeg.exe has a return code of 1! This is a possible error.
2011-05-22 10:13:19,376 INFO [LibraryAdditionsCheckerThread] Added file 'title00.mkv' (title: G-Force) to Library
2011-05-22 10:13:23,575 ERROR [ResourceTransportRequestHandler] Error while processing resource, sending back 500 error. Message: FFmpeg execution failed
at org.serviio.delivery.resource.AbstractTranscodingDeliveryEngine.retrieveTranscodedResource(AbstractTranscodingDeliveryEngine.java:116)
at org.serviio.delivery.resource.AbstractDeliveryEngine.deliver(AbstractDeliveryEngine.java:89)
at org.serviio.delivery.MediaResourceRetrievalStrategy.retrieveResource(MediaResourceRetrievalStrategy.java:116)
at org.serviio.upnp.webserver.ResourceTransportRequestHandler.handleRequest(ResourceTransportRequestHandler.java:115)
2011-05-22 10:13:23,591 ERROR [ResourceTransportRequestHandler] Error while processing resource, sending back 500 error. Message: FFmpeg execution failed
2011-05-22 10:13:23,742 ERROR [ResourceTransportRequestHandler] Error while processing resource, sending back 500 error. Message: FFmpeg execution failed
2011-05-22 10:13:23,755 ERROR [ResourceTransportRequestHandler] Error while processing resource, sending back 500 error. Message: FFmpeg execution failed
2011-05-22 10:13:23,770 ERROR [ResourceTransportRequestHandler] Error while processing resource, sending back 500 error. Message: FFmpeg execution failed
2011-05-22 10:13:23,930 WARN [EventDispatcher] Couldn't send event message for subscription e0f31888-d44e-4276-ad06-65a97a159c63, will keep trying until subscription expires
2011-05-22 10:13:23,975 ERROR [ResourceTransportRequestHandler] Error while processing resource, sending back 500 error. Message: FFmpeg execution failed
2011-05-22 10:13:23,981 ERROR [ResourceTransportRequestHandler] Error while processing resource, sending back 500 error. Message: FFmpeg execution failed
2011-05-22 10:13:24,767 INFO [LibraryAdditionsCheckerThread] Added file 'title00.mkv' (title: Ghost Rider) to Library
2011-05-22 10:13:28,952 WARN [EventDispatcher] Couldn't send event message for subscription e0f31888-d44e-4276-ad06-65a97a159c63, will keep trying until subscription expires
2011-05-22 10:13:31,931 INFO [LibraryAdditionsCheckerThread] Added file 'title00.mkv' (title: G.I. Joe: The Rise of Cobra) to Library
2011-05-22 10:13:33,963 WARN [EventDispatcher] Couldn't send event message for subscription e0f31888-d44e-4276-ad06-65a97a159c63, will keep trying until subscription expires
2011-05-22 10:14:41,228 INFO [LibraryAdditionsCheckerThread] Added file 'title04.mkv' (title: Gladiator) to Library
2011-05-22 10:14:43,968 WARN [EventDispatcher] Couldn't send event message for subscription e0f31888-d44e-4276-ad06-65a97a159c63, will keep trying until subscription expires
2011-05-22 10:14:45,796 INFO [LibraryAdditionsCheckerThread] Added file 'title00.mkv' (title: The Godfather) to Library
2011-05-22 10:14:48,970 WARN [EventDispatcher] Couldn't send event message for subscription e0f31888-d44e-4276-ad06-65a97a159c63, will keep trying until subscription expires
2011-05-22 10:14:51,651 INFO [LibraryAdditionsCheckerThread] Added file 'title00.mkv' (title: The Godfather: Part III) to Library
2011-05-22 10:14:53,971 WARN [EventDispatcher] Couldn't send event message for subscription e0f31888-d44e-4276-ad06-65a97a159c63, will keep trying until subscription expires
2011-05-22 10:14:58,064 INFO [LibraryAdditionsCheckerThread] Added file 'title00.mkv' (title: Gone Baby Gone) to Library
2011-05-22 10:15:03,124 INFO [LibraryAdditionsCheckerThread] Added file 'title00.mkv' (title: title00) to Library
2011-05-22 10:15:03,979 WARN [EventDispatcher] Couldn't send event message for subscription e0f31888-d44e-4276-ad06-65a97a159c63, will keep trying until subscription expires
2011-05-22 10:15:08,980 WARN [EventDispatcher] Couldn't send event message for subscription e0f31888-d44e-4276-ad06-65a97a159c63, will keep trying until subscription expires
2011-05-22 10:15:09,330 INFO [LibraryAdditionsCheckerThread] Added file 'title00.mkv' (title: Gridiron Gang) to Library
guzmansoldier wrote:I hope this is what you need.
Yes, but the we need the detailed logging file. See signature link to enabled detailed logging file.
guzmansoldier wrote:Here you go.
This is not the detailed logging file. See viewtopic.php?f=5&t=7
Do you restart serviio service after modification?
I did restart the servio service via windows service console. I did exactly as the instructions stated. Change the config file to DEBUG, restart the service, and tried to play an MKV movie. Am I doing something wrong?
Do I need to restart the serviio service in windows and restart the server in the Serviio console?
What do I need to look for in the log file so that way I am for sure it worked, before I resend.
I have tried it again and this time I shut down the service made the change and then started up the service. I hope this helps.
OK,
So now could you start this command line locally (into a windows terminal) and post the error log here:
C:\Program Files (x86)\Serviio\bin\\..\lib/ffmpeg.exe -i F:\Video\2012\title00.mkv -y -vcodec copy -copyts -acodec libmp3lame -ab 192k -ac 6 -map 0:0 -map 0:1 -sn -f mpegts C:\Windows\TEMP\Serviio\transcoding-temp-2-MPEG2TS.stf
C:\Users\DaMaN>C:\"Program Files (x86)"\Serviio\bin\\..\lib/ffmpeg.exe -i F:\Vi
.st
686-mingw32-
[matroska,webm @ 02af2e40] invalid dts/pts combination
[matroska,webm @ 02af2e40] Estimating duration from bitrate, this may be inaccu
ate
Input #0, matroska,webm, from 'F:\Video\2012\title00.mkv':
title : Chapter 00
title : Chapter 01
title : Chapter 02
title : Chapter 03
title : Chapter 04
title : Chapter 05
title : Chapter 06
title : Chapter 07
title : Chapter 08
title : Chapter 09
title : Chapter 10
title : Chapter 11
title : Chapter 12
title : Chapter 13
title : Chapter 14
title : Chapter 15
title : Chapter 16
title : Chapter 17
title : Chapter 18
title : Chapter 19
title : Chapter 20
title : Chapter 21
title : Chapter 22
title : Chapter 23
title : Chapter 24
title : Chapter 25
title : Chapter 26
title : Chapter 27
title : 3/2+1
Output #0, mpegts, to 'C:\Windows\TEMP\Serviio\transcoding-temp-2-MPEG2TS.st':
Stream #0.0(eng): Video: mpeg2video, yuv420p, 720x480 [PAR 186:157 DAR 279:
57], q=2-31, 9800 kb/s, 90k tbn, 29.97 tbc
Stream #0.1(eng): Audio: libmp3lame, 48000 Hz, 5.1, s16, 192 kb/s
title : 3/2+1
Stream mapping:
Stream #0.0 -> #0.0
Stream #0.1 -> #0.1
Error while opening encoder for output stream #0.1 - maybe incorrect parameters
such as bit_rate, rate, width or height
.st
686-mingw32-
ate
title : Chapter 00
title : Chapter 01
title : Chapter 02
title : Chapter 03
title : Chapter 04
title : Chapter 05
title : Chapter 06
title : Chapter 07
title : Chapter 08
title : Chapter 09
title : Chapter 10
title : Chapter 11
title : Chapter 12
title : Chapter 13
title : Chapter 14
title : Chapter 15
title : Chapter 16
title : Chapter 17
title : Chapter 18
title : Chapter 19
title : Chapter 20
title : Chapter 21
title : Chapter 22
title : Chapter 23
title : Chapter 24
title : Chapter 25
title : Chapter 26
title : Chapter 27
title : 3/2+1
title : 3/2+1
Stream mapping:
Stream #0.0 -> #0.0
Stream #0.1 -> #0.1
Try this
C:\Program Files (x86)\Serviio\bin\\..\lib/ffmpeg.exe -i F:\Video\2012\title00.mkv -y -vcodec copy -copyts -acodec libmp3lame -ab 384k -ac 6 -map 0:0 -map 0:1 -sn -f mpegts C:\Windows\TEMP\Serviio\transcoding-temp-2-MPEG2TS.stf
