Mount ISO for Transcoding
jbomengo
Post Tue May 17, 2011 9:10 pm
I have several hundred DVDs I've ripped to ISO format. Is there a way to mount the ISO for Transcoding for use with Serviio?
Post Tue May 17, 2011 9:25 pm
Re: Mount ISO for Transcoding
No, at least not yet
soldurio
Post Sun May 29, 2011 8:29 am
i don't know if this can help, but..
you can use "virtual clone cd" + "udf reader" (the udf reader for blu-ray iso's, for dvd it's not necesary)to mount .iso as a normal disk (k:/ i.e) and acces normally or add as local disk on serviio.
i'm using this under windows xp.
robertleleu
Post Sun May 29, 2011 9:18 am
thanks. However this software is only Windows.
I have now 2 .iso, and, when mounted with Gmount-iso (a linux programm) one is seen by serviio, the other not....I try to further investigate
GatsbyTheGreat
Post Tue May 31, 2011 8:43 pm
PS3 Media Server does .ISO transcoding to DLNA renderers just fine. It's written in Java and Open Source, so it might be a good place to look for a sample implementation. Also, Mencoder supports BluRay playback via libbluray
Hope this helps.
Post Tue May 31, 2011 10:56 pm
Yes, they use mencoder for ISO extraction. FFmpeg doesn't support it afaik.
Tarkin
Post Thu Jun 09, 2011 3:04 pm
GatsbyTheGreat wrote:PS3 Media Server does .ISO transcoding to DLNA renderers just fine. It's written in Java and Open Source, so it might be a good place to look for a sample implementation. Also, Mencoder supports BluRay playback via libbluray
Hope this helps.
O PS3....I wish i had one now!
Tarkin
Post Thu Jun 09, 2011 3:08 pm
soldurio wrote:i don't know if this can help, but..
Soldurio, you wetting my appetite...please tell me more...how I do I see the content of a DVD ISO in Serviio: as a straight movie? as a full blown DVD with menus?
Post Sun Jun 12, 2011 7:09 pm
dvd menus wont work over dlna afaik
javier
Post Thu Jul 07, 2011 8:08 am
You can try http://xbmc.org to mount ISO and transcoding.. it supports menu with chapters.. check out the gallery and wiki ;)
robertleleu
Post Thu Jul 07, 2011 9:58 am
xbmc is already installed in my ubuntu 11.04 but switch to full screen and freezes
