Ability to turn metadata on/off by folder
Terminus
Post Sun May 16, 2010 3:33 am
Love the metadata its great, best thing about Serviio. But the problem is if I have not renamed a movie or series yet, or I want my personal videos to be in the library too, or I record TV with a tuner card and want to watch it through Serviio, it tries to find the closest matching title from the online databases and often gets it hilariously or annoyingly wrong and clutters up the library.
Can we have an option in the shared folders dialog to turn off searching for metadata in certain folders so we can still play the videos in them via folder view, without them messing up the rest of our carefully tended library?
Post Sun May 16, 2010 9:58 am
Re: Ability to turn metadata on/off by folder
I want todo something about it. Would a checkbox somewhere be better or would you prefer some naming convention, e.g. everything in a folder called "private" to be skipped when searching for the metadata?
Britinva
Post Wed May 19, 2010 8:07 pm
zip wrote:I want todo something about it. Would a checkbox somewhere be better or would you prefer some naming convention, e.g. everything in a folder called "private" to be skipped when searching for the metadata?
What about logic:
- Is there a local metadata file (if yes use first)
- Is there full match on a online metadata (if yes use)
- if neither use filename
If Serviio sees that user is using metadata (local or online) use the structured folders like you do now. If metadata not being used then just use folder structure on the PC.
ken
Post Tue May 25, 2010 6:18 pm
This would be a very nice feature to have, I like the idea with a checkbox next to the shared folders.
Post Wed May 26, 2010 8:26 pm
Return to Feature requests
