Netgear EVA2000
danilo
Post Sat May 08, 2010 5:18 pm
Netgear EVA2000
Netgear EVA2000 is a small box that is able to add DLNA capability to any TV. So far the automatic detecting is working fine (I'm using it to play only avi/divx video streams). I will add more testing experience if I will find any compatibility issue.
Piero
Post Sun May 16, 2010 8:47 am
Re: Netgear EVA2000
I'm testing Serviio with EVA2000 too. Basically, it works fine; but I can't find a way to obtain any "extended" metadata (cd covers, DVD posters) on the player (...and that's the reason why I'm trying Serviio, replacing uShare :( )
I understand that it's probably an EVA2000 issue, but I try to ask my question anyway: which are the player's minimum requirements, in order to have Serviio working with fanart/covers/posters... ? It's clear that a "DLNA compatible" player is not enough...
Thank you in advance for your answer (...and help, I hope) :)
Regards
Post Sun May 16, 2010 9:56 am
Re: Netgear EVA2000
Not sure about thisplayer but some don't support that (e.g. xbox).
Piero
Post Sun May 16, 2010 10:06 am
Re: Netgear EVA2000
Thank you for your quick answer, zip.
But, again: which are the player's minimum requirements, in order to have Serviio working with fanart/covers/posters... ?
In other words: how can I know (in advance) if a DLNA player wil (or will not) support cover/posters?
Thank you again :)
Regards
Post Sun May 16, 2010 10:39 am
Re: Netgear EVA2000
I would say go to a forum and ask people who already have it. DLNA spec doesn't say thumbnails have to be supported (for example small screen devices don't have enought space for images).
Return to User experiences
