Q about supported file types
abbu
Post Thu May 19, 2011 7:52 am
I'm new here and I'm running serviio which is a very nice and easy to use program. Many thanks for that.
I would like to know what file types (media files) are supported. Some movies will not play on my panasonic vt20. Is this normal or can I do something about this?
I allready searched this forum but that did not help me any...
Post Thu May 19, 2011 8:25 am
Re: Q about supported file types
A lot of types are supperted, it's possible that for your TV the transcoding config is not complete.
viewtopic.php?f=5&t=1123
abbu
Post Thu May 19, 2011 12:30 pm
My OS is Win7 x64
OS = WIN7 x64
below 3 file types: a.mpg, b.wmv, c.mpeg
H:\W7\Serviio\lib>ffmpeg.exe -i l:\test\a.mpg
686-mingw32-
libavutil 50.36. 0 / 50.36. 0
libavcore 0.16. 0 / 0.16. 0
libavfilter 1.72. 0 / 1.72. 0
libswscale 0.12. 0 / 0.12. 0
[mpeg @ 0112bb60] max_analyze_duration reached
Input #0, mpeg, from 'l:\test\a.mpg':
Duration: 00:03:47.99, start: 0.330244, bitrate: 1391 kb/s
Stream #0.0[0x1e0]: Video: mpeg1video, yuv420p, 352x288 [PAR 178:163 DAR 195
8:1467], 1150 kb/s, 25 fps, 25 tbr, 90k tbn, 25 tbc
Stream #0.1[0x1c0]: Audio: mp2, 44100 Hz, 2 channels, s16, 224 kb/s
Complete name : L:\test\a.mpg
Format : MPEG-PS
File size : 37,8 MiB
Duration : 3mn 48s
Overall bit rate : 1 392 Kbps
Format : MPEG Video
Format version : Version 1
Format settings, BVOP : Ja
Format settings, Matrix : Standaard
Duration : 3mn 48s
Bit rate mode : Constant
Bit rate : 1 150 Kbps
Width : 352 pixels
Height : 288 pixels
Display aspect ratio : 4:3
Frame rate : 25,000 fps
Standard : PAL
Color space : YUV
Bit depth : 8 bits
Scan type : Progressief
Bits/(Pixel*Frame) : 0.454
Stream size : 31,0 MiB (82%)
Format : MPEG Audio
Format profile : Layer 2
Duration : 3mn 48s
Bit rate : 224 Kbps
Channel(s) : 2 kanalen
Sampling rate : 44,1 KHz
Stream size : 6,09 MiB (16%)
H:\W7\Serviio\lib>ffmpeg.exe -i l:\test\b.wmv
686-mingw32-
Seems stream 1 codec frame rate differs from container frame rate: 1000.00 (1000
/1) -> 25.00 (25/1)
Input #0, asf, from 'l:\test\b.wmv':
Application : Windows Movie Maker 2.1.4026.0
WM/ParentalRating:
WMFSDKVersion : 10.00.00.3646
WMFSDKNeeded : 0.0.0.0000
IsVBR : 0
title :
artist :
copyright :
comment :
Duration: 00:02:55.96, start: 1.579000, bitrate: 2023 kb/s
Stream #0.0(gre): Audio: wmav2, 44100 Hz, 2 channels, s16, 160 kb/s
Stream #0.1(gre): Video: wmv3, yuv420p, 720x576, 1877 kb/s, 25 tbr, 1k tbn,
1k tbc
Complete name : L:\test\b.wmv
Format : Windows Media
File size : 42.4 MiB
Duration : 2mn 55s
Overall bit rate mode : Constant
Overall bit rate : 2 024 Kbps
Maximum Overall bit rate : 2 056 Kbps
Encoded date : UTC 2005-04-25 11:41:36.828
Format : VC-1
Format profile : MP@ML
Codec ID : WMV3
Codec ID/Info : Windows Media Video 9
Codec ID/Hint : WMV3
Description of the codec : Windows Media Video 9 - Professional
Duration : 2mn 55s
Bit rate : 1 877 Kbps
Width : 720 pixels
Height : 576 pixels
Display aspect ratio : 5:4
Frame rate : 25.000 fps
Standard : PAL
Bit depth : 8 bits
Scan type : Progressive
Compression mode : Lossy
Bits/(Pixel*Frame) : 0.181
Stream size : 39.4 MiB (93%)
Language : Greek
Format : WMA
Format version : Version 2
Codec ID : 161
Codec ID/Info : Windows Media Audio
Description of the codec : Windows Media Audio 9.1 - 160 kbps, 44 kHz, stereo (A/V) 1-pass CBR
Duration : 2mn 55s
Bit rate : 160 Kbps
Channel(s) : 2 channels
Sampling rate : 44.1 KHz
Bit depth : 16 bits
Stream size : 3.36 MiB (8%)
Language : Greek
H:\W7\Serviio\lib>ffmpeg.exe -i l:\test\c.mpeg
686-mingw32-
[mpeg @ 0157bb70] max_analyze_duration reached
Input #0, mpeg, from 'l:\test\c.mpeg':
Duration: 00:04:31.40, start: 0.702044, bitrate: 2127 kb/s
8:1467], 1800 kb/s, 25 fps, 25 tbr, 90k tbn, 25 tbc
Complete name : L:\test\c.mpeg
Format : MPEG-PS
File size : 68.8 MiB
Duration : 4mn 31s
Overall bit rate : 2 127 Kbps
Format : MPEG Video
Format settings, BVOP : Yes
Format settings, Matrix : Default
Duration : 4mn 31s
Bit rate : 1 800 Kbps
Width : 352 pixels
Height : 288 pixels
Standard : PAL
Color space : YUV
Bit depth : 8 bits
Bits/(Pixel*Frame) : 0.710
Stream size : 60.2 MiB (87%)
Format : MPEG Audio
Duration : 4mn 31s
Bit rate : 224 Kbps
Delay relative to video : -80ms
Stream size : 7.25 MiB (11%)
H:\W7\Serviio\lib>
Post Thu May 19, 2011 12:36 pm
Are those files that do not play? Can you rename your existing serviio.log ad enable detailed logging (see signature) and post it here, you might have to zip it up.
In the serviio console is "Panasonic" auto selected or have you selected it for the correct IP address?
abbu
Post Thu May 19, 2011 12:46 pm
Yes correct, these files do not play.
Log file is attached.
The ip is added manual and set vor panasonic viera. The connection is working for avi and jpg.
//edited.
I have to ad that in status of console it says : the devicename =unknown, orange dot in front of ip.
serviio.zip
LOG FILE
(82.77 KiB) Downloaded 1042 times
Post Thu May 19, 2011 2:18 pm
We could not found ffmpeg command used on the log file...
Restart the same process describe by moltra but before post the log, try to play these files:
- rename your existing serviio.log
- start to play files
- and post it here
FILE1: *.mpg : mpeg1video(video), mp2(audio)
FILE2: *.wmv : wmv3(video), wmav2(audio)
FILE3: *.mpeg : mpeg1video(video), mp2(audio)
Do they support these formats over DLNA?
Post Thu May 19, 2011 2:36 pm
Found into the French user manual of VT20:
Photo: JPEG (4:4:4, 4:2:2 or 4:2:0), 8x8 to 30719x17279
Motion JPEG and Progressive JPEG not supported
Video : MPEG-2 (ts or ps)
AVCHD and DivX not supported over DLNA (but supported over mediaplayer (SD or USB))
Audio : Not supported over DLNA (but MP3 and AAC are supported over mediaplayer (SD or USB))
abbu
Post Thu May 19, 2011 3:43 pm
The feeling sneeks up to me as my head sticks in the bees nest.
This becomes way beyond my skills.
Isn't here a profile ready for use for a VT20 ?
Post Thu May 19, 2011 3:54 pm
abbu wrote:I played the movies before making adjustement to "panasonic"
log file attached.
Serviio delivered these files (a.mpg and c.mpeg) in native format without transcoding but your Pana did not support these formats.
abbu
Post Thu May 19, 2011 4:10 pm
so now I can watch those file types after transcoding or remuxing as described here?? : http://www.serviio.org/index.php?option ... icle&id=24
Post Thu May 19, 2011 5:03 pm
After you selected Panasonic as the render profile. Did you restart Serviio? To get serviio to recognize the new profile the program must be restarted.
abbu
Post Thu May 19, 2011 5:49 pm
<Video targetContainer="mpegts" targetVCodec="mpeg2video">
<Matches container="mpegvideo" vCodec="mp2" />
when I insert above as described the console refuses to start and exits with message that server is not running
Post Thu May 19, 2011 5:53 pm
You need to totally restart serviio after editing profiles. I always restart serviio after selecting a different profile.
How are you trying to restart serviio?
abbu
Post Thu May 19, 2011 5:57 pm
stop server + end console
then start server from start menu + start console
Post Thu May 19, 2011 6:00 pm
You need to stop Serviio not serviio console. Right click on the console icon in the system tray and select serviio not "serviio console"
abbu
Post Thu May 19, 2011 6:08 pm
it does not change anything.
restarting of console is not possible, not even after starting server again.
AFter ending like subscribed i have to stop server, start server, start console then I get the error message that server is not running : see attached
Post Thu May 19, 2011 6:14 pm
Can you open up the serviio.log file in the log directory and post it here.
See this post to see more information about the serviio.log and how to restart serviio after editing.
http://forum.serviio.org/viewtopic.php?f=5&t=7
abbu
Post Thu May 19, 2011 6:20 pm
see attached
(6.48 KiB) Downloaded 1084 times
Post Thu May 19, 2011 6:27 pm
There is a mistake in your profile file.
2011-05-19 20:03:21,411 ERROR [XmlUtils] XML Profiles.xsd didn't pass validation, reason: cvc-enumeration-valid: Value 'mp2' is not facet-valid with respect to enumeration '[vc1, mpeg4, msmpeg4, mpeg2video, mpeg1video, h264, wmv2, mjpeg, flv, vp6]'. It must be a value from the enumeration.
2011-05-19 20:03:21,411 ERROR [MediaServer] An unexpected error occured. Ending the application. Message: org.serviio.profile.ProfilesDefinitionException: Profiles XML file is not valid (according to the schema). Check the log.
Try replacing the "mp2" with "mpeg2video"
Post Thu May 19, 2011 6:56 pm
I'm stupid, lots at mistakes in my previous post:
Try this:
<Matches container="mpeg" vCodec="mpeg1video" aCodec="mp2" />
Return to Panasonic
