Library Corrupts itself often - any backup possible?
morci
Post Mon May 17, 2010 6:52 am
Hi
My Serviio Library gets corrupted everytime i add a large number of folder & files.
My Steps:
1 Install Serviio fresh = OK
2 Add 'Folder' to Serviio (about 375movies) = OK
3 Wait 3hrs for Library to be updated = OK
4 Any day Add another folder 'TV Shows' (about 5 series) or Add more movies (50 or more folders) = Library becomes corrupt and Serviio stops working = Corrupt Library
The only way to fix this is to
1 Remove Serviio
2 Start again (steps above)
Q1 - Is there any way to 'SAVE' my library that I can restore without having to wait such a long time for 'Library is being updated' message?
Q2 - Would you know why Serviio gets corrupt when you try to add more movies/tv shows later on?
Thanks again
Great Product
Morci
Morci
Serviio User :)
Samsung LA40B750U1F LCD | Windows XP Sp3 unpatched |System: MSI 865Neo2 -Platinum - P4 3.4Ghz - 3GB RAM
How To: Get Non Working AVI Files Playing http://forum.serviio.org/viewtopic.php?f=10&t=4780
How To: Fix FFW + REW in AVI's - when containing OpenDML format http://forum.serviio.org/viewtopic.php?f=5&t=323
Post Mon May 17, 2010 8:20 am
Re: Library Corrupts itself often - any backup possible?
Not sure about the corruption... never happened to me before. You can back it up by copying library folder.
morci
Post Mon May 17, 2010 12:08 pm
Today i tested again
I deleted 1 movie file and added 2 movie files and then received this message
"Request cannot be completed MEDIA PLAY will return to the main screen"
What does this mean exactly? How can deleting 1 media file and adding 2 Avi files cause a corruption?
Is there are way to log the internal error being created?
The only way around this is to uninstall and reinstall again.
Thanks for your help
Morci
Serviio User :)
Post Mon May 17, 2010 12:15 pm
Post the log (with debug on)
quiddgame
Post Tue Aug 28, 2012 10:44 pm
Same Issue with me, Library keeps corrupting, subfolders don't show any files in it anymore.
This happened 3 times now.
Users browsing this forum: Bing [Bot] and 46 guests
